Question about Olympus DS-30 Digital Voice Recorder
Olympus DS30 voice recorder play speed issue
I recently bought an Olympus DS 30 voice recorder.
I recorded 3-4 songs in my own voice and was able to play it back fine and everything worked perfect.
I just tried it again this morning and the play back has become SLOW.
I see in the menu that there is a setting for "Play speed".... I selected F.Play and set it to 1.5 (got a message that the speed is set).
However, the playback of all my recordings so far is still SLOW.
How do I change the play speed ?
Thanks
  • 3 more comments
  • Anonymous Jul 07, 2008
    I have the same problem.
  • doughewitt Nov 09, 2008
    you described how to play back at x0.5, x0.625, x0.75, x0.875  x1.125, x1.25, x1.375, x1.5
    but not 1.0. i want actual speed and my DS 30 doesnt seem to know how to do that.
    Doug
  • x-licious Nov 12, 2008
    Yeah, I either sound like Theodore the chipmunk or a Disney cartoon whale.
  • Anonymous Dec 14, 2008
    I have the same problem, when i initially purchased the machine, it worked fine until one day i may have accidentally hit a wrong button and now i cannot get it at NORMAL speed again. Also read manual and no help
  • odeta Feb 04, 2009
    but it not work I cant change s.play.to f.play
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Posted on Dec 29, 2008
    Problem Solver:
  • 17 Answers
The Olympus DS-30 gas SIX Playing Mode you can adjust them like follow :
1-While the recorder is stopped or during playback, press the MENU button for 1 second or longer
2- Press the + or – button to choose “Play Speed”.
3-Press the OK . The playback speed setup process begins.
4-Press the + or – button to choose between “S. Play” and “F. Play”.
5-Press the OK Start setting each of “S. Play” and “F. Play”.
6-Press the + or – button to set the playback speed.
S. Play: x0.5, x0.625, x0.75, x0.875
F. Play: x1.125, x1.25, x1.375, x1.5
If the recorder goes to the menu screen during playback, move the cursor to change the playback speed accordingly.
7-Press the OK button to complete the setup screen.
If the 0 button is pressed, the setting will be canceled and it will return to the menu.
Press the OK button 1 second or longer to go back to the menu screen in Step 1.
8-Press the STOP button to close the menu. If the recorder goes to the menu screen during playback, press the 0 button to close the menu screen.
Hope this help
Posted on Apr 05, 2008
  • Brett Jones
    Brett Jones Oct 15, 2013
    How do I just go back to normal play speed. It looks like I go back and forth between fast and slow speed, but cant return to normal speed.
Peejay59..THANK YOU so much, you the best you solve my problem.
Posted on Feb 04, 2009
My Olympus digital voice recorder DS-30 recorder says memory full - but I only have about 4 or 5 hours of recording on it. help!
Check your operators manual....amount of recording time is dependent on "quality" mode of recoring.
If you have lost your manual go to www.olympusamerica.com
Oct 10, 2010 | Olympus DS-30 Digital Voice Recorder
Olympus DS-30
sometimes formatting will reset the file number... format through the recorder..
Mar 04, 2009 | Olympus DS-30 Digital Voice Recorder
DS-30 Serial Number
the serial key is on the package, or you may need to call olympus support
Oct 13, 2008 | Olympus DS-30 Digital Voice Recorder
Olympus ds-30 voice recorder
I don't think the serial number is required to install the software. I didn't see DS-30 information on the Olympus website. DS-40 was the closest one. No information was availbable regarding serial numbers.
I have a VN-4100PC and don't recall being asked for a serial number. The software is the same thing for all Olympus players.
Aug 21, 2008 | Olympus DS-30 Digital Voice Recorder
Playback speed problems...
The Play button controls speed of play back. If you hold the button two long it changes the speed. Press Play and then release and press again until the speed you are looking for is obtained. Be careful not to push the play button mulitple times once it is correct.
Apr 26, 2008 | Olympus DS-2 Digital Voice Recorder
Help! My Voice recorder is stuck in Slow playback/record
To switch back to normal press the PLAY button during
playback.
"Every time the PLAY button is pressed, the playback speed will switch."
Mar 31, 2008 | Olympus DS-40 Digital Voice Recorder
Can't use my voice recorder anymore
try to connect the recorder to the PC and with the Olympus DSS Player Version 7 change the folders name to default
Mar 05, 2008 | Olympus DS-50 Digital Voice Recorder
System Error
it would appear that the files needed to operate the recorder have been deleted and need to be uploaded to the recorder... if you dont have them on your computer, then you will need to send to repair center
Aug 15, 2007 | Olympus DS-30 Digital Voice Recorder
Olympus DS-30 Digital Voice Recorder Logo
1,489 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
