Question about Panasonic AG-VP320 DVD Player/VCR
NV-VP32 The DVD drawer keeps opening!
If you just press it once it should open then close then in about thirty seconds it will open again. it will stay open until you close it.
Posted on Mar 30, 2008
VCR Recording OK but cant see tape content
VCR may not be tuned to the right channel. If you are using your VCR for the tuner then your tv is set to channel 3. Check your cabling again as well. From the wall to the VCR. From the VCR to the TV. You also need to make sure that you programmed the VCR for all of the channels. Just like you would for a TV.
Jan 20, 2013 | Panasonic Nv-Vp32 Dvd Vcr Combo 110-220...
DVD player. NV-VP32 shows F09 error. No buttons are working. Have unplugged and waited 5 mins then re-plugged and it still shows F09 error.
Hello
F09 indicates electrical overload. If you've got some basic soldering skills, you might open the case and check for a ruptured capacitor and try replacing it. Repair costs range about $50 a hour, plus parts, but parts usually only add another $10 or less. Check with a repair shop and see what the usual cost is, on average.
Apr 16, 2011 | Panasonic DMR-ES30VS DVD Recorder/VCR
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
The disc drawer will not open. How can I get it
There will be a small hole in the front tray of the DVD, use a straightened paper clip, or similar stiff wire, & push it into the hole and gently push in, until you hear/feel a "Click" gently keep pushing 7 it should now come open,
Feb 17, 2010 | Memorex MVD2042 DVD Player
Panasonic NV-VP32
F09 means 5 volt regulation problems
At the back left corner of the dvd draw on the power supply board there are 2X capacitors C1260 10 volt 1000uf and C1262 10 uf 1000uf .Replace them .Problem solved
May 02, 2008 | Panasonic DVD-RV62EBS DVD Player
F09 error message on Panasonic NV-VP32 dvd player/video combo
2 x 1000mF capacitors in the power supply trying to burst.
Mar 28, 2008 | Televison & Video
Multi regional DVD player?
To my knowledge, yes it is. The Panasonic NV-VP32 will play all DVDs.
However, to be able to view multi region DVDs (PAL/NTSC), the Panasonic NV-VP32 must be connected to a multi system TV (capable of both PAL/NTSC).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Panasonic DVD-S52 DVD Player
Panasonic AG-VP320 DVD Player/VCR Logo
208 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
