Question about Sony Cyber-shot DSC-W55 Digital Camera
Downloading photos from new F40fd
I already have a previous version of finepix viewer that I use regularly but now I have a new F40fd. Do I need to install the new software which came with the camera. If I do will it affect the version and photos I already have stored in finepix albums.
  • primrose12 Mar 06, 2008
    Thanks guys. I got it all installed this morning and everything is working fine. I didn't lose any old photos. Big sigh of relief.
  • 68 Answers
If you like the finepix viewer for whatever reason, then upgrade to the new version. It will not remove your photos unless you are prompted to do so and click yes. You can always copy them to another directory temporarily if you are worried. 99% of photo viewer software will save the previous settings.
Posted on Mar 05, 2008
    Genius:
  • 2,985 Answers
!, There is no need for Software supplied with ANY camera to be installed- t is best left in the box.
Windows will detect and camera a put uo the Scanner/Camera Wizard from whence you can direct images to exazctly where you want them.
So remove any software- none required..
All images are stored by default in My Document/My pictures or [and check this before you delete any software]
My Computer/'C'/Programs/FinePix to check.
Posted on Mar 04, 2008
After downloading photos, instead of them opening in Finepix viewer screen (to allow me to rotate & crop etc) I keep getting a 'Finepix Viewer - Desktop' screen. This does not show the pictures...
Hi pamelaknott3,
In this case you would have to check the autorun settings in your finepix viewer sofware , there may be a setting which would indicate autorun or autostart for the finepix viewer desktop application , once you discover it , you would have to disable it, if not then please try uninstalling the finepix software and then reinstalling it so that it loads the default settings that was ok for you earlier.
Hope this helps ..:)
If you have any further queries, just get back to me and I would love to help you out.
Jun 20, 2011 | Cameras
Fujifilm finepix f40fd
The lens needs to be dismantled and reset.
If your camera is under warranty then fuji will replace for free. If not then it may cost around £90 to have the lens unit replaced.
Cost of repair will depend on where you take it to get it repaired and will undoubtedly be more than the cost of a new camera.
However.....
It can be repaired for as little as £30 if you look hard enough ;-)
Nov 13, 2009 | Fuji FinePix F40fd Digital Camera
Zoom error showing on display screen of my daughters fuji finepix f40fd digital camera. Unable to press button to take photos and when I try to turn camera off the zoom lens goes in and out twice before...
The lens Is trying to close properly but the focus mechanism has a problem, most likely jammed, so the lens cannot correctly close or work properly.
It will need to be opened up and reset.
Please email me. My email address is listed in my tips section on my profile.
Aug 28, 2009 | Fuji FinePix F40fd Digital Camera
Photos saving to camera internal memory not to memory card.
go into memory on menu and choose change memory settings from internal to card
Mar 16, 2009 | Fuji FinePix F40fd Digital Camera
Downloading photos
did you install the FinePix Viewer software? It makes the job lots easier.
Aug 26, 2008 | Fuji FinePix S8000fd Digital Camera
Photos
Hi
I only use WINDOWS so this solution is not applicable for MAC or LINUX
1) Connect cable to camera ( camera is turned off). There is a picture on page 131 of the manual
2) Connect other end of cable to PC ( PC should already be on)
3) Turn camera on by pressing PLAY button on the back and holding until camera starts. This method of turning on and off means the lens will not operate and so is ideal for when connecting to computer. Your camera LCD should like up and it should display "USB" on a white background.
4) If you have not installed the drivers (from the installation CD-ROM) then windows will try to install the software and depending on the WINDOWS version then you may be prompted to insert the CD-ROM.
5) Once drivers are installed you should get a confirmation that hardware is ready for use. If you have already installed the drivers and Finepix viewer then finepix viewer should open automatically. Finepix crashes on my PC (Windows VISTA is rubbish!) so I just use windows explorer.
6) The camera appears as an external drive in windows exploere. Look for FinePix S8000fd. Expand the folder contents until you get to a folder called 100_FUJI. The pictures from the camera are in here.
7) Use copy and paste to copy from Camera to a folder of your choice. I have a folder called "Photos" and other folders inside it arranged by date.
8) When you have finished you must turn the camera off before disconnecting. Press and hold the PLAY button until LCD swithces off and disconnect cable from PC then camera
Hope this helps
Jun 15, 2008 | Fuji FinePix S8000fd Digital Camera
Fuji FinePix F40fd aoto focus
Camera fault sounds like make sure the A/F sensor window is not obscured Fuji Tech Support will know more.
Jul 12, 2007 | Fuji FinePix F40fd Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
74 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
