Question about Samsung 710V 17" LCD Monitor
Not optimum mode recommended mode 1024 x 768 60hz
I try the first solution which is adjust the screen resulotion in the control panel settings,but it theres nothing happen it still flashing the "not optimum mode recommended mode 1024x768 60hz?"...what the second solution it might be???tnx a lot...mwahhhhhhh
  • 1 more comment
  • pedltn Jul 16, 2008
    I have a 510N samsung and i have the same problem... floating like screen saver telling me not optimim mode reccommended. mode 1024x768 60 Hz
  • cenk erdinc Nov 05, 2008
    same screen savr look banner
    what is that
    an elc problm or what?
  • disel1 Apr 06, 2009
    my monitor shows icons larger and small and when i run the autoadjust it stays the same. but if i change the resolution for higher standard, then the icons stays very small, so i can't read them..
    what shall i do
    thanks
    Manuel from Portugal
Hook up a different monitor and set resolution to no higher than 1024 x 768. Samsung monitor will then work fine. It appears that something fails in the monitor and it will no longer support anything higher than this.
Posted on Sep 29, 2008
Look for the monitor driver to install and update thru device manager. Let device detech as the samsung 510 monitor.
Posted on Sep 27, 2008
  • Doris Low Nov 04, 2008
    pls reply if is work.
Change frequency to 85hz
Posted on Mar 03, 2008
2 Suggested Answers
SOURCE: not optimum mode 510v 17" LCD Monitor
Samsung have a lot of liquid crystal display there. The solution is simple: the replacement of an MCU will be able to repair.
Samsung LCD MCU sales:
http://www.dgdw.cn/lcd%20mcu/SAMSUNG%20MCU%20English.htm
SKYPE: cqrising
Posted on Dec 07, 2008
Not optimum mode recommended mode 1280x1024 60hz syncmaster 712 n pop up occasionly I have to shut down computer
Your video card and computer memory may not be sufficient to run in the recommended "optimum performance mode" that Samsung and Windows both suggest. Please try setting your display setting at a lower resolution such as 1080 x 760 which is still quite excellent. Otherwise you may need to buy a better video card or increase system memory to run the higher mode graphics.
Good Luck!
Jan 11, 2011 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Screen stating not at optimum mode requesting 1280x1024hzm i have raedeon video card
Samsung syncmaster 170n monitor shows black with screen stating not at optimum mode requesting 1280x1024hzm , how do I fix this?
Oct 15, 2009 | Computers & Internet
Floating box non optimum mode recommended mode
You need to adjust the Display screen resolution.
  1. Control Pannel
  2. Display
  3. Settings
  4. Screen Resolution
Sep 22, 2009 | Samsung Computers & Internet
Monitor stops working and box start floating around on screen with "Not Optimum Mode -- Recommended Mode 1280 X 1024 60 Hz." Replacement monitor works on computer.
check if your monitor has an auto-adjust button, this will help you autoadjusting the recommended resolution so that there are no problems, if not, you can try to rightclick on windows desktop and go to properties>configuration, set the resolution there
Sep 16, 2009 | Computers & Internet
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Cannot display this video mode optimum resulotion 1280*1024 60hz
Chances are that the video driver for XP and 2003 differs (even if only slightly). You might want to start the 2003 in "Safe Mode" first to lower both the Screen Resolution and Screen Refresh Rate to the lowest possible. Thereafter do an update on the video card driver compatible with 2003 from the Dell.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 30, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Not optimum mode 510v 17" LCD Monitor
well, you need to change the EEPROM on the AD board.
Mar 04, 2008 | Samsung 710V 17" LCD Monitor
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Samsung 710V 17" LCD Monitor Logo
3,585 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
