Question about Smeg Kitchen Ranges
Smeg SAR93 gas stove ignition is stuck on - Smeg Kitchen Ranges
Smeg mod nu.sar93xlpg gas cooktop is 20 years old and in good condition The gas igniter recently has been sparking once every 5 mins. works fine except one spark every 5 minutes,any ideas
probably find that after so long the igniter is starting to fail
call smeg and see if there is a replacement one available
there may be after market units from your local gas shop
Jun 25, 2016 | Smeg Cooktops
The igniter on my SMEG gas stove does not work
They do go bad from time to time. you can get a new one at appliancepros.com or you can goole appliance parts and it will give you many vendors to chose from
May 07, 2014 | Smeg Ovens
The igniter does not work on my SMEG gas stove
Hi it is probably the igniter pack under the controls depending on the model it could be a fairly large single pack with a pressure switch wired from each knob or individual switches. You will need to remove the panel and see where it is then test each one, don't touch it they really bite, if you need more help let me know. Ray
May 07, 2014 | Cooktops
One of my igniter in my smeg gas cook top does not spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 30, 2011 | Smeg 23 in. SE64 Gas Cooktop
I want to change my smeg oven element please smeg
i hate my electric oven how can i change it to a gas stove
Feb 13, 2010 | Ovens
GE gas stove switch igniting though stove is off!
You have a bad ignitor switch. One or more of them (4) is stuck.
You need a volt/ohn meter to check the switches, one attached to each surface burner to find out which is bad.
Feb 19, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Stuck auto ignition
try easing each knob upwards a bit.
Jul 15, 2008 | Smeg 23 in. SE64 Gas Cooktop
Stuck auto ignition
Either one of the ignition switches are stuck down internally or the ignition pack is faulty, no other possible cause. Regards Advisor
Aug 29, 2007 | Smeg 23 in. SE64 Gas Cooktop
Kitchen Ranges Logo
171 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
