Question about HP mx705 17" CRT Monitor
Monitor dims My monitor menu just comes on, I turn it off and it comes back on. Sometimes it comes on and dims to 1%. This happens sometimes every few seconds sometimes with minutes between. Is there anyone who knows how to solve this problem. this monitor is one and half years...
  • sachin mohan Mar 09, 2008
    the menu screen appears and brightness increases to 100 .
  • repsrealty Jul 29, 2008
    Monitor menu just comes on, I turn it off and it comes back on. Sometimes it comes on and keeps flashing. This problem has become so frequint it makes viewing impossible.
  • 151 Answers
Your monitor in hardware problem front panel keys short in side.change menu switch on boar.or command section problem.check ic or componets relate it.
Posted on Mar 03, 2008
Primare spa21 amplifier, Sometimes when I turn it on from standby mode only 1 speaker works till I adjust the volume then both speakers come on and the problem doesnt happen till I switch off then back...
I have not had the same problem, but you can try and reload factory setting. This can help if there is no sound or with other strange symptoms. Connect video out from amp to a TV/monitor and push menu and find the memory menu. If this help you must remember to store the new setting or else it will return to the previouse settings.
Nov 06, 2011 | Audio Players & Recorders
I have SyncMaster 940nw LCD monitor, which works strangely: screen is often black(sometimes I can see unclear flickering), power indicator is double blinking one time per second. Menu doesn't show up...
The problem is in the inverter board which powers the back lights behind the screen. The cause is bad capacitors that sometimes bulge at the top indicating they are open. The board needs to be changed or an attempt made to repair the old one. Now you indicated a second problem with the menu not coming up, you probably would be further ahead to replace the monitor.
Feb 17, 2011 | Computers & Internet
My monitor is about 6 years old. Some weeks ago, when I powered on, a grey streak started appearing and moved top to bottom before the normal image came on. Lately, the monitor blinks on and off when I...
2003 is the first one made, 14 years old it sure can be.
new to you sure,.
all monitors, from 2000 to 2010 year, are backlighted with
crude CCFL maps, that last for 2 years (shortest life full time)
the all go bad, ever one , if USED, lots.
they all: endup soon.
1: dim
2: yellow tubes.
3: flicker ands strobe (not the data just the back lamps)
4: dead.
5: totally interminttant.
just like the forecent lamps im garage and for the same reasons.
6: the osd goes dead to when above happens. menu key on monitor front, but not data seen with flash light trick.
learn when 4 happens, above, do this.
buy monitor 2011 and newer, and this pain above goes byebye
at the introduction of wonderful, LED backlamps.
Oct 16, 2017 | HP Compaq FP 7317 17" Flat Panel LCD...
Have ViewSonic LCD monitor . I have had this ongoing annoying problem that comes and goes. Does anyone know how I can resolve it? I don't want to pay money for a new one or take it into a shop (too...
Failed caps just like all the Viesonic as shown in my albums here:<br /> <a href=""></a><br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href=""></a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href=""></a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <a href=""><span style="mso-spacerun: yes"> </span></a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
Aug 25, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
W2361VG Monitor "OSD Locked" and service menu
This just means the On Screen Display (OSD) is locked. Press and hold the menu button on the front panel for 10 seconds.
Aug 29, 2009 | LG L1915S 19" LCD Monitor
Sony SDM HS93 works fine, but: Monitor will not turn on with power button, if I plug in A/C cord power light goes on, monitor works. Sometimes the monitor comes on too bright, other times, too dim....
i get same..controls not working ,,sometimes menu button works and one arrow button..button "ok" button doesnt work and up arrow...brightness not working.
i get black box in upper left corner...quite diffucult to get rid of.
Feb 25, 2008 | Sony SDM HS93 19" LCD Monitor
LCD Monitor blacks in and out for 1-2 seconds
does your monitor have an external transformer as the psu ?
If so, try disconnecting at mains for about 5 seconds and re-connect. failing that we'll need to dig deeper.
Jan 06, 2008 | Samsung SyncMaster 205BW LCD Monitor
Hp ms705 menu comes on without prompt
Even my monitor HPM704 does the same thing from 12Mar08. I bought this monitor an year before. It looks like this batch of monitors have issues from factory itself. Plan to get support from customer care.
Dec 28, 2007 | HP mx705 17" CRT Monitor
Cornea flatscreen mp704 monitor
i have a similar problem i believe the power button on the monitor is faulty,sometimes it works sometimes it doesnt.what works for me is to hold the button until the monitor comes on and release the button quickly.
good luck.
Dec 26, 2007 | Cornea MP800 18.1 in. Flat Panel LCD...
Compaq FP 7317 LCD Monitor
Check the buttons on your monitor for possible shorts. Sometimes pressing a sequence of buttons while turning the monitor on will lock the OSD.
Aug 02, 2007 | Compaq FP 7317 17" LCD Monitor
HP mx705 17" CRT Monitor Logo
119 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
