Question about Kodak EasyShare M853 Digital Camera
Lens error 122
I dropped my camera while taking a picture..and now it's not working it gives me a white screen and says Lens Error 122, .....something. how can i fix it
  • 8 more comments
  • eymanr Mar 04, 2008
    I took it to the local repairer and the inner lens was broken it needs to be replaced...
  • Anonymous Mar 04, 2008
    I had the same thing just happen to me...
    how much does it cost you to get it repaired locally?
  • eymanr Mar 14, 2008
    I live in the Middle East. it cost me about 40$...
    You can call your local repairer and ask them..
  • Anonymous May 10, 2008
    same problem. how much does it cost in canada?
    and what type of place would i take it to get it fixed?
  • 123meyay33 May 25, 2008
    i dropped my camera when looking at my pictures. then i picked it up and saw that the lense was stuck and it said error 122.I got my camera on febuary 24th and now its nothing to me. how much would it cost in the us california?
  • Anonymous Sep 19, 2008
    can i fix it:((
  • chels27mielk Oct 04, 2008
    my battery died so then my camer lens was stuck out and i put it in my purse and someone stepped on it now the little lens is like half in half out and it gives me like error lens 122, somthin
  • Anonymous Mar 24, 2009
    Well my lens fell out of the camra and i think the battery died so it got stuck out and now the battery is dead and i have no cord wat dhould i do???
  • dani-anne May 12, 2009
    My friend's and I were taking pictures with my camera, and my friend tried giving the camera to my other friend and it dropped. The lens was stuck but we managed to put it back so that it would turn off etc; The problem now is that the picture is pink and blurry. But when I press down on the lens it goes back to normal. But then again, as soon as I let go it goes back to being pink and blurry.
    I already checked my local repair stores, and it's $70 for sending it to another place which will tell me how much it's going to cost. I don't have that much money and I need a way of doing this myself.
    Any ideas?
    Thanks
  • 123meyay33 May 11, 2010
    I dropped my camera and it says error 122 what should i do???
Solution 2: umm your gay tat didnt help at all
mine lens is sticking out but not thw whole way
WHAT DO I DO
i dont have enough money to repair it.wel depends how much it is
Posted on Sep 23, 2008
Look all you have to do is turn the outer lens (hear it click ) then it'll work!
Posted on Aug 19, 2008
  • 3 Answers
I never dropped my camera, but I have this issue.
Posted on Aug 18, 2008
Well..i didnt drop my camera..i put it down after looking at it. cut it back on and then it said lens error: 122, 1, 0. 0.
so after researching i found that..you can get it fixed for $60.
or if you have the warranty they will replace it.
but i have the kodak-M853.easy share..
hope that helps someone =)
Posted on Jul 28, 2008
Hmmm these digital cams are so damn fragile!! the old onesare way better,, u drop and what ever u do the won't break!!
i dont know how much it costs to repair it in ur country..u can cll the company and ask them how much it costs to change the lense...sorry couldn't help u!!
Posted on May 27, 2008
Oh sorry it i gave u a wrong number..it cost 40 Jds which is almost 58 $US
Posted on Mar 15, 2008
I just drop my camera while i was taking a picture
it said lens error 122, how do i fix that
without going to a repair
Posted on Mar 14, 2008
Ok,white screen is LCDproblum or flex conecting pro,error 122 is ur lens barrel stuckup or mechanical gears problum this is repareable u try ur local repairer
Posted on Mar 04, 2008
SOURCE:
Lens error 122
Hey blondgal12,
From your description you should most likely have your camera looked at by an authorized service technician and get and estimate on a repair done. The manufacturer usually has a list of authorized service technicians in your local area, or you could try looking in the yellow pages. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 05, 2008 | Cameras
Camera lens might be broken
My friend droped my camera and the lens is sideways. i can look at my pictures, but when i want to take a picture it is black and says lens error. what should i do?
May 21, 2008 | Casio EXILIM EX-Z70 Digital Camera
KODAK LENS ERROR 122 1 0 0
if your looking where it says lens error 122 then when you turn it on it will say it i have the same problem but worse
May 11, 2008 | Kodak EasyShare M853 Digital Camera
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Dropped camera- screen is white
OK. I think you should replaced damaged camera LCD. And you should take care of camera lens.
KAT
thu241@gmail.com
Myitkyina, Myanmar
Jan 08, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Lens Error, restart camera
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try:
Oct 03, 2007 | Canon PowerShot A530 Digital Camera
White screen, won't take pictures, battery door won't open!!
Sony customer support is the place to go but I suspect a new camera is likely to be a more economic option
Jul 28, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Kodak EasyShare M853 Digital Camera Logo
804 people viewed this question
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
