PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Deep freeze
By ganesh_khati on Mar 03, 2008
today i install deep freeze std evl 6 first it says reboot and it will install auto. i click ok but now i didnt see any icon in taskbar menu or start up menu or on the desktop there says press shift+alt+cnrl+f6 but it didnt work and now i cant access to drive c and in start up menu all progrems are not commings
Comments:
Mar 06, 2008
- no my friend i didnt get problem exact , u tell me solution that uninstall the software thats the problem , i cant find software icon in system tray or in start menu, and to uninstall this software it must be in thawed state, i want to say that i didnt find any icon or way to uninstall it
Same Problem
May 03, 2009
-   i have it also-   Guest
Jan 06, 2009
-   ncvn -   Guest
Sep 27, 2008
-   m also having this prob. -   Guest
Aug 17, 2008
-   Cant Unfreeze my PC,DeepFreeze icon isnt showing on the taskbar...-   jojoa
Jul 11, 2008
-   today i install deep freeze std evl 6 first it says reboot and it will install auto. i click ok but now i didnt see any icon in taskbar menu or start up menu ,Icant access to drive c and in start up menu all progrems are not comming. I cant access the run command. even add or remove pgms is not opening.
i dont want to re format,, help meee
hoping, remya.ramraj@gmail.com-   remyaa
Best Solution
posted on Mar 06, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Go to start->control panel->Add remove.
Click it the window will open in that see your software is their are not. If their means remove it. if ts not their means go to taskbar see
that the deep freeze std evl 6 exe file is their or not. You did not install properly. Check any same file name is in the program files.
Solution #2
posted on Mar 03, 2008
Somewhat Helpful)
goldflack
Rank: Wiz
Rating: 81%, 142 votes
Remove the deep freeze std evl 6 and then restart the system.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Sep 16, 2009
Very Helpful)
davidkr
Rank: Apprentice
Rating: 100%, 1 votes
hi.. ! i am working in internet cafe , from yestarday hotmail is not working they say you have to install new version of windows massenger. i can install the new version of windows live .but i have deep freeze in my every computer.but i can't see the deep freze icone in my textbar its show but when i go to put mouce corser its desapiar i wnat to disable the depfreze .pliz help me any one.. what sholud i do ..? and when i try to reinstall the deep freez then computer says " disable first the allraday insatall deep frezz , pliz help me. thanx.
Was this helpful?
Yes
No
Solution #4
posted on Apr 07, 2009
Very Helpful)
brutalnails
Rank: Wiz
Rating: 84%, 42 votes
This problem generally occurs on workstations running an nVidia nForce based motherboard chipset. nForce IDE drivers report the characteristics of devices attached to the IDE controllers in a certain way that prevents Deep Freeze from functioning properly.
nForce IDE drivers with version numbers earlier than v6.66 "WHQL" will display this type of behavior. To resolve this issue, it is recommended that the workstation be updated to the latest version of the nForce IDE drivers. If updated versions of the IDE drivers are not available for your specific platform, remove the IDE drivers for Deep Freeze to function properly.
In some cases, workstations may be configured with an IDE or SATA raid controller. In such a scenario, updating the driver may require that the operating system be re-loaded. Also, the updated driver should be used to allow Windows to see the RAID array during Windows installation.
Please note that if updated SATA / IDE RAID drivers are not available, the system will not be able to run Deep Freeze when the computer boots from the SATA RAID controller. To resolve this issue, configure your computer with the hard disks connected to a non-RAID controller that can be seen by Windows without the use of the SATA RAID Driver.
Was this helpful?
Yes
No
Solution #5
posted on Nov 16, 2008
Somewhat Helpful)
cabdirisaaqa
Rank: Apprentice
Rating: 75%, 1 votes
haye gaalo
Was this helpful?
Yes
No
Solution #6
posted on Nov 27, 2009
Not Rated)
bijayojha88
Rank: Apprentice
Rating: 79%, 6 votes
fren u press ctrl + shirt +double click on dep freez logo then enter password there are three option slect last option click ok then take restat compu then unstail la
Was this helpful?
Yes
No
Solution #7
posted on Nov 21, 2009
Not Rated)
hazil33
Rank: Guide
Rating: 75%, 2 votes
To uninstall first of all
1.)Locate the installation file you used to install Deep Freeze on your computer. By default, the name of this file is called DF5Std.exe in which 5 stands for the version and for version 6 it willl be DF6Std.exe..!!
i think it will be there in yo local c(windows installation drive itself..else leave it go search for it..)
2.)Run the installation file DF5Std.exe or DF6Std.exe(setup)
2a.)Select the option to "Uninstall"
**Deep Freeze is uninstalled and your computer is rebooted.
Was this helpful?
Yes
No
Solution #8
posted on Sep 02, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
no icon means you can't unfreeze or thaw deepfreeze...and you cannot uninstall it if it is frozen state...not in control panel..if it were that easy you could just uninstall deepfreeze everytime
jrw
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
How to apply this layout on my account?
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
please send me Acer extensa4630z display problam solution system is power is on butthere is no... (More)
Answer
It just wont work, it does read some cds but will not download programs or burn etc...
7 Other Users Have The Same Problem - Continued
Comment by vichoose, posted on May 28, 2008
today i install deep freeze std evl 6 first it says reboot and it will install auto.i cant find software icon in system tray or in start menu, and to uninstall this software it must be in thawed state, i want to say that i didnt find any icon or way to uninstall it
Comment by saji_d, posted on Apr 25, 2008
how can get unfreezer of deep[ freez 6
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
