Question about Logitech Z-5300 Computer Speakers
Using Without WIRED REMOTE
Hello Experts,
I have logitech z-5300 and for decoding i m using Creative DDTS-100.
Everything is awesome, everything is working fine but the only problem which i was aware of is the Power Button and channel volume adjustments which is on Speakers own Remote so it needs to switch on all the times.
All i want is to DISCONNECT the Wired Remote and wish the speakers to RUN without using the REMOTE with full volume output (RAW OUTPUT) to the Decoder so it can be adjusted by the decoder.
Hope you understand what i need
any possiblity
Regards
  • 1 more comment
  • Orexio Mar 05, 2008
    hello Tony
    thanks for your reply,
    let me explain a little bit more there is a SERIAL CONNECTOR at the back of SUBWOOFER suppose to connect WIRED REMOTE.
    The speakers are connected to the DECODER and DECODER is connected to the sound card's digital connection.
    you are right the way you are saying it should work but in Logitech Z-5300 you cant bypass the remote. even the standby button is on the remote if we disconnect the remote from the speaker we are not even able to switch on.
    there are 2 power switch one is at the back of subwoofer (main)  and other is on the remote (Standby button) i want to bypass the Remote so that speakers can be turn on without touching the remote so it can be adjusted by the Decoder
    hope this might clear the situation
    Ali
  • Orexio Mar 28, 2008
    anyone ?
  • Anonymous Jan 01, 2009
    you will need to turn speakers on from remote anyway
  • 38 Answers
All I could suggest is run the decoder off the line-out of your soundcard, then regardless of what the volume or power setting is to your speakers, the signal will still come through?
Tony
Posted on Mar 04, 2008
I want to buy a creative inspire m 5300 wired remote volume control
SOLUTION: Dudes, Had the same issue, got an old PS2 mouse (same plug), cut off the plug, fiddled with different combinations. Joining 2 wires turns it on, another 2 puts the volumn to full...
Jasonxart
Feb 05, 2012 | Audio Players & Recorders
Hello Sir, As I wish to buy a home theatre speaker system.And my budget is upto Rs.5500.I have searched for the same in internets,I found two products that are compatible to me.The products are iball...
Both the speakers you have mentioned are multimedia speakers and don't have Dolby Digital, ProLogic or DTS decoders built in. So if your DVD player does not have 5.1 analogue out , only two speakers will work.
Among the two the creative sounds better but like you mentioned the I ball has a remote and higher output on paper !!.
My recommendation is Logitech X-540.Check the link below.
http://reviews.logitech.com/7061/234/logitech-x-540-5-1-speaker-system-reviews/reviews.htm
Mar 17, 2011 | Audio Players & Recorders
As I remember it, the EX 100 was plug and play on my XP PC. The batteries are NOT a problem - as they check OK. I periodically have both mouse and keyboard FREEZE After restarting XP computer everything...
Connect an additional wired keyboard to your pc. And when the freeze happens check if the pc responds at all, using the wired keyboard. If its not responding , its an indication of a faulty PSU or motherboard.
Mar 08, 2011 | Logitech Cordless EX 100 Mouse
I have a logitech 890. The remote only turns the tv on and off but nothing else.
this remote has a help button to resolve setup issues. you should see a message on the screen ask ing if you need help. If not this function can be activated using the setup software. Try using the remote to watch TV. Then press the help button(be sure to have the remote pointed at the TV). The remote will attempt to fix itself. the screen will then ask if that fixed the problem-choose yes or no. Continue to follow the prompts until everything is the way you want it.
This should get everything working for you. I assume you did connect the remote to your computer and went through the setup software.
I use this remote and I love it. Just be sure when using it to give time for it to send commands to all the devices.
Nov 06, 2009 | Logitech Harmony 890 LCD Remote Control
Creative DDTS-100 Problem
It might be intereference that's being amplified. Try moving the power pack away from other things. I got the same when it was positioned near a 360 power brick.
May 30, 2009 | Creative Labs DDTS-100 Digital Decoder...
Sound qulity ?`creative t7900 ddts 100
You must balance your speakers. It is not the DDTS-100. I had the same thing with active speakers. Check your speakers separately though. If it still sounds like it sound comes from underneath the surface, the speakers are maybe broke. If not, get a new DDTS-100.
May 28, 2008 | Creative Labs DDTS-100 Digital Decoder...
Ddts - 1 creative digital decoder -- Alternative
you can buy them off e bay i got mine for about 50 quid but no remote
Jan 08, 2008 | Creative Labs DDTS-100 Digital Decoder...
Problem with starting the speakers
Xplode
Good day and happy holidays
you have to look at back of your comp, if you has a 5.1 speaker first, like Creative Audigy, live, or X-FI, then according with the cables, colors, must be, Green . black, according for output sound, see manual for the cables and put at back according.
Nov 27, 2007 | Logitech Z-5300 Computer Speakers
Creative DDTS-30 Dolby Headphone Decoder
You can slide a flat screwdriver underneath the black faceplate and prise it up; it is glued on and will stick back down easily on its own. The screws you need to access are underneath.
Nick
Nov 09, 2007 | Radio Communications
Logitech Z-5300 Computer Speakers Logo
946 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
