Question about Alpine CDE-9852 CD Player
Alpine cde 9852
Hi i have brought the Soundstream sst6.6 tarantula 2 way speakers and they are 3 ohm. On my pioneer head unit it says nothing under 4 ohms can be run off deck, but i have a Alpine cde 9852 but i have lost the owners manual and dont know if i can run the speakers off it. I do have an amp coming to run them but it will be a while before i get it.
Bozo21- Yes in fact you can run the speakers,most speakers dont run the actual load rated. An 8ohm speaker for example may check at 6 or 10 ohm.Also the speaker wire you are using will add to the ohms. cooltekMar,4/08
Posted on Mar 04, 2008
In actuality the resistance of the speaker depends on the frequency the speaker is playing. For example, a speaker may have a 3 ohm resistance at 80 Hz and a 9 ohm resistance at 300 Hz. If you were to make a plot of resistance versus frequency you would get what is called the impedance curve of the speaker. Also, speakers act in some ways as inductors and capacitors so a true model of a speaker must include those components as well. How does this affect the sound you ask? Well if you have an amp that has very weak current capability it may work fine into perfect 4 ohm loads but when you connect our real speaker which has an impedance dip at 80 Hz the amp may have difficulty and smear sounds that have 80 Hz components. These are minor but audible effects. This is why it is good to get a 2 ohm stable amp even if you never plan on running 2 ohm loads.
Is 1998 taurus compatible with alpine cde-9852
Hello, you can install this head unit into the taurus as long as you are confident in wiring the unit in yourself. the colour wires from the car WILL NOT match the colours from the CD player, although a experienced installer will be able to splice the wires together in the orrect way to make it work!
I hope this helpsRegardsGrant
Nov 19, 2011 | Alpine CDE-9852 CD Player
The radio plays for a minute or two and then there is no sound. The head unit stays on and works but no sound. What do I do?
make sure all speaker connections and power grnd connections are soldered and either taped or heat shrunk
Jul 26, 2010 | Alpine CDE-9852 CD Player
Dead Alpine CDE-9852 Stereo
its the fuse behind your deck( Alpine unit has its own fuse) YOU WILL NEED to remove your deck to access this fuse
Jan 16, 2010 | Alpine CDE-9852 CD Player
Subwoofer for alpine cde-9843
In short, no.
The CDE-9843 cannot drive a sub of the type you mention without an amp, but you can fit a sub with it's own built-in amp.
As standard, the head unit has a basic in-built amp supplying 4 x 16w RMS at 4ohms but there is the facility via the unit's own menu to turn off the in built amp and use the output sockets as a pre-amp feed, but in reality if you want to drive an amp you'd be better off to start with a more highly specified head unit to begin with, even the next model up, the CDE-9845 is better suited as there are pre-outs for front and rear speakers.
User instructions are available from here.
If my reply has been of assistance then please return the favour by rating my answer.
Nov 09, 2009 | Alpine CDE-9841 CD Player
I'm having trouble connecting my alpine cde-9852 to my 96 jeep cherokee. is there a wiring diagram online for this? thanks
Constant 12V+ Pink Switched 12V+ Purple/White Ground Black Illumination Light Blue/Red Dimmer Orange Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers 5 1/4" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange
Jul 11, 2009 | Alpine CDE-9852 CD Player
Adjusting the time on an Alpine CDE-9852
Hello bitterswe834,
To set the time, do this:
1. Press TITLE repeatedly until the time is displayed.
2. Press and hold TITLE for at least 2 seconds while the time is displayed. The time indication will blink.
3. Use the volume control to adjust the hours while the time indication is blinking.
4. When the hour has been adjusted, press MODE.
5. Turn the volume control to adjust the minutes while the time indication is blinking.
Hope this helps.
May 24, 2009 | Alpine CDE-9852 CD Player
How do I attach the KCE-422i iPod adaptet to my Alpine CDE-9852?
Very easily, just pull the head unit out. Plug the adapter into the round receptacle, run your cable to a convienient place and plug your Ipod in, switch the source to ipod and listen away. Good luck
-Andrew Hawkins
Aug 27, 2008 | Alpine Car Audio & Video
Ipod connection
Take it to the dealer who installed the Alpine and have him plug in a short extension cable for you.
Apr 22, 2007 | Alpine CDE-9852 CD Player
Alpine CDE-9852 CD Player Logo
175 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
