Question about Pioneer AVH-P6500DVD Car DVD Player
Remote wire What color is the remote wire coming from the harness of the dvd? trying to hook up an amplifier and cant figure it out. Please help
    Problem Solver:
  • 9 Answers
Should be a blue one. Blue wires signify POWER OUT (was originally designed for electronic ariels!)
Posted on Mar 06, 2008
  • 78 Answers
This is correct you utilise the auto antenna remote wire which is blue.
Posted on Mar 04, 2008
Blue is the normal colour
Amplifier is not turning on due to no signal from the remote wire. I dont know if I have the correct wire connected together to my remote wire that came in my wiring kit. What Color is the remote wire...
If the unit is aftermarket and it has a harness, the wire will be blue. If not, visit installr.com and find ur Car model and the wiring harness codes will show which wire is the ignition remote wire on. That is the wire you need to hook up your amp to.
Jul 23, 2011 | Car Audio & Video
I have a 92 marquis, and ive just changed out the factory stereo with a aftermarket. How can i hookup the amp that came with the bose system??
If you bought a wiring adapter kit for the aftermarket stereo, the unit should hook up directly to the stock bose system. Note: If there is sound coming from the speakers after installation, the amp IS hooked up...the speaker wiring is routed to the factory amplifier, not the stereo itself, the stereo wiring is just signal leads to the amplifier. In some instances, you may have to connect the amp remote wire to the remote wire coming from the aftermarket stereo(blue wire). I hope this helps. Any other questions, just reply.
Feb 06, 2011 | 1992 Mercury Grand Marquis
I would like 2 connect mazda wire harness to nextar ncd50.HOW CAN I CONNECT that can u plz explain me
It depends on if you have an after market wiring harness that adapts the factory harness to the new cd player, or trying to hard wire into the factory wires in the car. First off, if you don't have a aftermarket harness, i would strongly suggest picking one up from Wal-Mart or automotive store, they are around $20 and save a lot of time. If hooking up this way, you just have to match the color wires to the same color of wires on the cd player. Red to Red, which is power, Yellow to Yellow which is Constant power, Black to Black which is Ground, Blue is only used when you have a power antenna that goes up when the car is turned on or if you have a amplifier, you can hook up the remote power to it, otherwise, leave it off. Then you will have your speaker wires which the fronts are White and White/Black, and Grey and Grey/Black. The rears are Green and Green/Black and Purple and Purple/Black. The ones with the Black striped go with the other matching colors with the black stripe. Then you would just plug in the factory harness to the aftermarket, and aftermarket to the cd player. If you are trying to hard wire into the factory wires, you will have to cut of the harness, find a Haynes or Chilton book at an automotive store and find what wires are what and use the color codes from above to hook back up, factory wires are always different colors. Once again, I strongly advise not to do it this way though. Hope this helps. Good luck.
Mar 12, 2010 | Car Audio & Video
I cant figure out my amp wire color code
every amp is wired the same its pretty easy... the red wire is your positive and needs to be hooked up to the battery.. black is the ground and needs to be touching something metal in your car. blue wire is remote start wire it goes from your radio to amp then plug your red and white rca cables from amp to radio
Dec 15, 2009 | Pioneer Car Audio & Video
Pioneer dehp3100ub.stock speakers wont work with unit?
If the vehicle has a premium sound package - you need to use the remote wire to turn on the factiry amplifier.
If you want to use the power from the radio for the speakers, you must buy and install a factory amplifier bypass harness.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 19, 2009 | Pioneer DEH-P3600 CD Player
What does the system control wire get hooked up tooo??????
it's just a remote wire it goes from your amp to the car stereo. usually on the wire harness for your cd player the color is BLUE but it should be labeled.
Mar 10, 2009 | Pioneer GM-5300T Car Audio Amplifier
Where does the remote wire from an amplifier hook up to.
you connect it at the fuse box at the kick panel on the driver side beneath the steering wheel there you will find the fuse box the diagram is on the back of the fuse cover you can connect it there or if you have a wiere harness for an after market stereo than it should be there it's usually a blue wire
Feb 19, 2009 | 2006 Scion xB
Vm9410 missing amp remote wire on harness
if you cant find that blue with white strap wire, you can tap the wire coming from your acc to remotely trun on your amplifier. some players dont come with a remote wire for the amplifier and power antenna.ü
Jan 06, 2009 | Jensen VM9410 Car DVD Player
Remote wire
there should be a remote wire for your amplifier on the back of your stereo if you have an aftermarket stereo. It's usually a blue wire, if not you can always hook it to the same remote wire as the one your stereo is running off of.
Oct 19, 2008 | Dual XDMR-7700 CD Player
Need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
you'll need a small 12 v lamp to figure out which one has the power terminals. after mapping that out you need to find a small battery and hook it up to a pair of wires to figure out to which speaker the wires go to.
note : new car radios don't use the chassis ground as common (negative).. the head unit has a negative and positive wire for EACH speaker.
Mar 13, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer AVH-P6500DVD Car DVD Player Logo
140 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
