Question about Canon PowerShot A530 Digital Camera
Memory card error
Hi! yesterday, i removed the memory card from my canon A530 from its memory card slot. when i inserted another memory card, the lcd showed" "memory card error" "card locked!" i inserted the other memory card but it still showed the same message. what is wrong with my digicam?what should i do about it? thank you for taking time to solve my problem. God bless!
  • 2 more comments
  • cnoreenv Mar 05, 2008
    dear aignome,
    i did exactly what you suggested. (I didn't see breakages nor dusts either.) however, nothing happened. anyway, thank you for you help. :)
  • Anonymous Mar 06, 2008
    Same problem...nothing seems to help..
  • aaallleeexxx Mar 07, 2008
    i have this problem. does anyone post what you're actually supposed to do??
    i need helpp here ]:
  • Anonymous Mar 23, 2014
    Memory card is almost impossible to remove. How to get it out without damage
  • 68 Answers
Check the slot and see if the pins inside are fine, no breakages, free from dust etc. Try turning the camera on and off (completely remove batteries etc).
Posted on Mar 05, 2008
Memory card error could it be the little battery
No, but it might be that new 4GB SDHC card if you're trying to use such in an A530. Please see this article for troubleshooting steps for memory card error problems.
Sep 11, 2011 | Canon PowerShot A530 Digital Camera
My a530 says" no memory
1. Go into the menu and find "reset" and follow the on-screen instructions. 2. Go into the menu and find "format" and follow the on-screen instructions.
Then, try your cards.
Aug 02, 2011 | Canon PowerShot A530 Digital Camera
I TOOK SOME PHOTOS WITH THE CANON POWER SHOT A530 (ABOUT FIVE). I DO NOT KNOW HOW TO VIEW THE INTERNAL MEMORY PHOTOS. ALSO CAN I HAVE THEM SWITCHED TO THE SD CARD? I DID'NT KNOW AT THE TIME THE CARD WAS...
First, promise to never use the internal memory again. Go into the menu and there should be an entry for "copy" which should allow you to copy the internal memory to a memory card. After that, you should "format" the camera with no card inserted to erase the internal memory.
Jan 21, 2011 | Canon PowerShot A530 Digital Camera
Brand new 4 GB Sony memory card. I get a card locked/memory card failure.
The A530 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and won't work. You need to use cards 2GB and smaller with the A530.
Dec 15, 2010 | Canon PowerShot A530 Digital Camera
I leave tomorrow HELP I have a Canon Powershot A530 and when I put in an 4GM memory card I get Memory Card Error
The A530 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it will fit into the slot, it won't work there. You need to go with SD cards 2GB and smaller.
Sep 28, 2010 | Canon PowerShot A530 Digital Camera
My card says it is locked on my canon powershot A530 how do i unlock it?
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Jul 27, 2010 | Canon PowerShot A530 Digital Camera
Memory Card Error
Chances are that the contacts in the card slot are either dirty or worn out. First thing I would try would be to try blow out the card slot. I suggest caned air, You could use a straw and Puffs of breath, but keep it dry. If that doesn’t work put a lint free cloth over a piece of cardboard about the same size as a memory stick. Be vary careful that it is not thicker then the memory stick. Dampen the end with Alcohol (Denatured Alcohol is best but standard rubbing alcohol might work in a pinch). I repeat, dampen with alcohol not dripping wet. Remove the battery just to be sure. Insert the swab into the card slot a half of a dozen times when you pull it out look to see if you see any residue on the swab. Hopefully you see dark stripes on the cloth. Let the camera sit with an empty slot (and no battery) for a hour before you try it again.
If all that fails the last chance (short of replacing the card reader) try to put some electrical tape on the memory stick on the side opposite from the gold contacts, be carful not to cover the contacts. Try one piece of type at a time and DON’T force the memory stick into the slot This will slightly increase the pressure on the contacts inside the card reader slot. If you have to resort to this be carful that the tape sticks completely and that it is neatly trimmed, you don’t want the type coming off inside the cameras. If this works you will need to add tape to all memory sticks used in this camera. I would NOT use any “taped” sticks in any other readers without removing the tape first.
Feb 12, 2008 | Cameras
Unable to download pictures from canon A530 digital camera
Try removing the memory card and inserting it again.
Also, does the computer detect the camera properly?
Oct 18, 2007 | Canon PowerShot A530 Digital Camera
Canon PowerShot A530 Digital Camera Logo
322 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
