Question about Microsoft Windows Server Standard 2003 for PC
Desktop get blank in domain controller
We have a domain controller of win2k serverin our office.After implimenting group policy in several O.U. and Sites then rebooting domain controller there is no icon in desktop.Please help me to come out of the problem.
Manash Kumar Chatterjee
Right click on desktop find a arrange icon-->then click show desktop icon
Posted on Apr 18, 2008
  • 101 Answers
The desktop is still there you have just not started the explorer.exe
You will be working blind so you have to do this one key at a time.
Press the windows key
then Alt+R
type explorer.exe and press return.
You have probably disabled it in group policy somewhere.
Posted on Mar 23, 2008
U can troubleshoot it with the help of Recovrery console.
insert window 2k cd in cdrom and boot from cd .
when it display three message continue setup press enter
2. to repair a system using recover console press R
so u press R
and go to c:\winnt\system32\config
and type del system
and type cd \
go c:\winnt\repair
and type this command
copy system c:\winnt\system32\config
and type exit
now reatart ur system
and most probably ur problem will be solve.
Posted on Mar 10, 2008
  • 277 Answers
Try to reinstall the os
Posted on Mar 08, 2008
We have a KM bizhub 250, and we upgraded our server to a SBS 2008 Server. Now our scanning is not working. What could be the problem?
If this server is also a domain controler that is usually caused by the following setting:
Microsoft Network Server: Digitally Sign Communications (Always), The default setting for domain controllers is enabled, for others is not configured or disabled. This usually causes problems when acessing the share from devices are not cable of Digitally Sign Communications, like some multifunctionals/scanners or linux machines. This does not happen on all machines since some are capable of Digitally Sign Communications. Usually older machines have this issue.
So, try to disable this setting on the server, on the Domain controller security policy and Default Domain Policy.
Administrative Tools
Local Policies
Security options
Microsoft Network Server: Digitally signed communication (always) -> should be changed to DISABLE
Execute Gpupdate /force or reboot the server to apply the policy change
You will not be able to change this setting trough gpedit , local computer policy since it is overrided by the Domain security policy.
On server 2008 one way to get there is the following:
Server Manager
Group Policy Manager
Forest: ...
Computer configuration
Windows Settings
Security Settings
Local Policies
Security Options
- Define This Policy
- Disabled
Execute Gpupdate /force or reboot to apply policy
Trough gpedit you will be able to see the option but not change it, so I suggest that after the change you cannot scan to the folder check trough gpedit if it is disabled.
If it is not disabled, disable it at the top of the hierarchy. Something may be overriding the setting.
If it still does not work try the following, togheter with the previous setting
Domain member: Digitally encrypt or sign secure channel data (always) -> disabled
Dont forget to execute Gpupdate /force or reboot to apply policy each time you change something.
are you scanning to the server using \\server_ip_address\shared_folder or \\server_name\shared_folder?
Just wondering about name resolution.
Is the domain field configured in the machine? if not you might have to specify the user for authentication like for example: user@domain.local
Dec 23, 2010 | Konica Minolta bizhub C250 All-In-One...
May 2008 domain controller is up and running but i cannot join it with my windows 7 laptop, "domain path not found"
Ah this is an easy one, make sure the laptops MAC address (this can be found by going into the laptops command line and typing 'ipconfig /all') Then you need to go into Doman users and computers (active directory) and add that MAC address to the computers group.
If this doesn't work...make sure your laptop is connecting through the same network. use the cmd line tool Ipconfig /all to find out the ip address of your server and your laptop. If your laptop's default gateway doesn't match that of your server' could be cross networking. Try the "ping" command like this go to the command line on your laptop and type Ping <ip address for server> if you can ping it, you can connect with it....also check your group policy that enables wireless connections.
Dec 15, 2009 | Dell Dimension 3000 PC Desktop
In my pc my task manager is no working longer, so how can i fix it, and uses it again.
Verify that the "Local Group Policy" or "Domain Group Policy" doesn’t block you from using
Task Manager in the Local Group Policy
1. Go to "Start" -> "Run" -> Type "Gpedit.msc" and press on "Enter" button.
2. Navigate to "User Configuration" -> "Administrative Templates" -> "System" -> "Ctrl+Alt+Del Options"
3. In the right side of the screen verity that "Remove Task Manager"" option set to "Disable" or "Not Configured".
4. Close "Gpedit.msc" MMC.
5. Go to "Start" -> "Run" -> Type "gpupdate /force" and press on "Enter" button.
For the "Domain Group Policy" Verify correct registry settings::
1. Go to "Start" -> "Run" -> Write "regedit" and press on "Enter" button.
2. Navigate to the following registry keys and verity that following settings set to default:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\LocalUser\Software\Microsoft\Windows\CurrentVersion\Policies\System]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
3. Reboot the computer.
Jun 06, 2009 | Microsoft Computers & Internet
Disabled task manager
1. Verity that the "Local Group Policy" or "Domain Group Policy" doesn’t block you from using
"Task Manager".
1.1 "Local Group Policy"
a. Go to "Start" -> "Run" -> Write "Gpedit.msc" and press on "Enter" button.
b. Navigate to "User Configuration" -> "Administrative Templates" -> "System" -> "Ctrl+Alt+Del Options"
c. In the right side of the screen verity that "Remove Task Manager"" option set to "Disable" or "Not Configured".
d. Close "Gpedit.msc" MMC.
e. Go to "Start" -> "Run" -> Write "gpupdate /force" and press on "Enter" button.
Note: If you are using Windows 2000, please follow KB q227302 instead stage "e".
Using SECEDIT to Force a Group Policy Refresh Immediately
1.2 "Domain Group Policy"
a. Contact you local IT support team.
2. Verity correct registry settings::
a. Go to "Start" -> "Run" -> Write "regedit" and press on "Enter" button.
Warning: Modifying your registry can cause serious problems that may require you to reinstall your operating system.
Always backup your files before doing this registry hack.
b. Navigate to the following registry keys and verity that following settings set to default:
Windows Registry Editor Version 5.00
c. Reboot the computer.
May 23, 2009 | Microsoft Windows XP Professional SP2
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
Logon issue in a domain trust - Win 2003
Are you logging in through terminal services? If so you need to give the user "allow logon through terminal services" permission in group policy.
Otherwise you need to give the user "allow logon locally" permission on the domain controller.
Mar 20, 2009 | Microsoft Windows Server Standard 2003 for...
Remote Desktop Connection doesn't work with SP3
If you're not using passwords ( i.e. a blank password ) there is a "Policy" setting which accepts blank passwords in SP2 but MS changed their mind in SP3 it's a no-no. Look carefully in group policy settings. It is hard to find. Ask for specific help setting policies. Need the policy to accept blank passwords.
Dec 26, 2008 | Microsoft Windows XP Professional With...
Group policy problem
This a known issue with Microsoft, they descibe how to handle it here:
Sep 24, 2008 | Computers & Internet
How to by-pass windows' screeensaver password
hi dear
in the login box
press ctrl+alt +del
fill user name : administrator
and left the passord blank
Mar 21, 2008 | Toshiba Satellite A60 Notebook
Microsoft Windows Server Standard 2003 for PC Logo
56 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
