Question about Frigidaire FDBB1940D Dishwasher
Dish washer won't wash
Last week problem started, can hear some water comming into washer, only at botton, but won't come into arms to wash,soap will drop on door, an floor of washer it will run ,in cycle... heat for drying.. etc but won't wash.. is their a filter of some sort ??? are is it the pump ?? how would you check. how can you test unit with door open to see what is going on. you can hear also some water going out of unit ?? thanks in advance MAT
  • 1 more comment
  • MatL Mar 05, 2008
    the problem i have i don't feel it is the hose, unit been in place for 3 years but i did check it the water is getting in at pump but not being picked up by pump... is their a screen on pump??? or do you think it is the pump??? can pump be taken apart, and inside part's replaced??
  • Fridig_air Sep 08, 2008
    I have the same problem! Dishwasher works fine except for the washing. Bottom spinner does not work but some water does fill from the side squirters. Drains fine and dries fine. I asked our repliance repair man and he said it's most likely the pump which is a costly repair... anyone have any ideas???
  • alphadogs Dec 30, 2008
    i have a frigidaire dishwasher model #FDB510LCS0 that will fill, drain and dry but suddenly won't wash. i can hear it click through the wash cycle.
    Sergeant:
  • 351 Answers
Is the drain hose to low causing the dishwasher to fill and drain at the same time,if the water level is to low the motor wont wash the soap out of the dispenser.hope this helps
Posted on Mar 03, 2008
How should I wash the water dish in the bowl?
The water dish should be washed in the same way as the food dish with water and soap. Just make sure you thoroughly rinse out the water so there won't be taste of soap.
Sep 02, 2012 | Alessi Cats
Dishes not clean after running. Dishes and glasses have a white residue on them after drying. Water is turned on and seems to ok. When I open the washer after the wash cycle starts there are several...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back if you need more informatiion.
Daniel
Nov 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
Dishes not getting clean
Are dishes too greasy!
Check incoming water for free flow
Add correct quantity of soap as per manual. Use dish washer friendly soap. Fill rinse aid liquid in the dispenser meant for it.
Select a different cycle programe and give a try.
May 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
White film is all over my inside of the dish washer & dishes
This sounds like excess soap or not enough water. You may also have really hard water.
Turn on machine wait until it starts running see how much water is inside. there should be a 1/2 to 1" +/- in the bottom but not enough that the wash arm would be touching and not enough that the door would be leaking when you open it. This could also be a circulation problem set wash arms a certain way and observe that they have moved when you open after running for a minute or 2.
Please let me know if I can do anything else to help.
Apr 13, 2010 | GE Dishwashers
LG LDS5811 top rack not cleaning
I Have the same issue, it sounds like the arms try and start up 4 times then each time power back down, the top arm is not spinning at all. On the fifth time a I hear grinding and then the mid and lower arms spin, soap streaks down the door, nothing stuck in any of the arms, 16 months old, 750.00 out of pocket for junk!
Oct 08, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Soap is not disolving. Falls out of holder and stays on door and floor of washer.
Are dishes also not coming clean? Most likely, there is not enough water chruning in the tub to rinse soap out of cup during wash cycle. Sufficient wash action will wash the soap out of the cup and dissolve it in the water within a few seconds of the cup opening.
Most likely causes are:
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Hope this help. Good luck.
Sep 11, 2009 | Dishwashers
Dishwasher runs but does not get dishes clean
1.) Confirm that the holes of the spray arms are not blocked with debris.
2.) Run a short cycle with an empty dishwasher and no dishwasher soap. Run the dishwasher until you hear it finish filling with water and begins the wash cycle. Add up to two cups of white vinegar to the water and allow to wash and drain. Feel free to do the same when the dishwasher fills again.
3.) Only use a brand name powder detergent (e.g. Electrosol or Cascade) in any dishwasher. Do not use a gel or tablet in any dishwasher. Do not fill the dispenser fully.
Test your dishwasher with a standard load of dirty dishes.
If problems continue, confirm that the heating element is working properly. The heating element is vital to getting clean dishes with modern dishwashers and DW detergent.
Please report back what you find.
Apr 08, 2009 | KitchenAid 24 in. KUDP01IL Stainless Steel...
Have the Kenmore Limited Edition dishwasher, model # 665.15892100. When dishwasher is running, you can hear the soap container flip open. However, @ end of washer's completion, and main door is opened, the...
check the wash arms to see if food has not cloged the holes stopping water getting through
if these are clean the machine may not have enough water entering machine
also check how you stack machine
Feb 02, 2008 | Dishwashers
Frigidaire FDBB1940D Dishwasher Logo
334 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
