Question about Samsung SGH-d807 Cellular Phone
Cell won't charge
My cell phone will not charge when i plug in the charger. it doesn't "accept" the charge. nothing happens when it's plugged in, it doesn't show that it is charging or anything. I have a back up charger and neither one will work. Help!!!!
Going crazy!!
  • 8 more comments
  • badphone Mar 05, 2008
    Last night out of the blue, my phone would not charge. I took it into the local ATT store and they said there is nothing they can do and offered to sell me a new phone at full cost. There is no connection between the charger and my phone. They tested my charger and battery and both are fine. It seems like this is a common problem from searching the internet.
  • bumcellphone Mar 09, 2008
    Phone just one day would **t charge anymore. Tried a**ther charger and battery to ** avail.
  • Anonymous Mar 13, 2008
    my cell won't charge either.
    not sure if I should buy another charger.
    Has anyone tried?
  • cellsucks Mar 13, 2008
    mine won't work either. The charger does not charge as of today. Not sure whether to buy another charger. Scared it might not work either.
  • Anonymous Mar 16, 2008
    My samsung SGH-d807 would not charge either (as of 3/7/08)
    Mine would not charge either.
  • cptfury Mar 26, 2008
    my D-807 will not charge let alone accept the charger as well.. i used my cousin's charger which he has the same phone.. but still it did not work.. mine is because the charger receiver part in the phone is broken i think.. maybe that might be it for you guys as well.. i dont know what to do now because if i send it in i will probably get a razr or something.. but i paid for this phone not a piece of poop..
  • jelca32 Sep 15, 2008
    i had the same problem, at&t sent me a replacement phone and the same thing happened 6 months later to the new (it was actually refurbished being that this model is discontinued) phone. I have been unable to charge my phone for the past month, it isn't under warranty. I love the phone, a solution would be great.
  • prettykool Oct 04, 2008
    my phone was working great and everything then i left it for an hour and bam it just stopped working and charging. i went to a plug outside of my room and it started charing but i disconnected and its been dead since 9/21/08 the phone won't turn on or anything. ive had the phone forover a year
  • Anonymous Oct 18, 2008
    Mine stopped charging too, its been about a year and a half and just completely stopped charging.
New battery doesn't work. The connection port for the charger appears to be the issue in my case. I think it may be damaged & this was also after a year.
Posted on Oct 07, 2008
MAYBE TRY A NEW BATTERY
Posted on Apr 02, 2008
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
Phone won't come on
my name is Larry and i have the exact same phone. If ur lg isnt turning on and wont charge it could be couple things . either the charging port on ur phone needs replaced and or ur charger has gone bad i would take it to a cell phone repair shop close to you.
Mar 25, 2013 | Net10 LG Optimus Logic Cell Phone
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
My Nokia E73 won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 15, 2012 | Nokia E73 Mode Cell Phone
Battery will not charge
There are only three likely solutions.
1. The charge port on your phone is broken (Most likely)
2. The battery has reached a thermal cutoff and will no longer accept a charge.
3. The charger cable is bad.
If you can try another battery or put that battery into another phone you can isolate that problem. If you can charge something else with your charger then your charger workers.
If that still doesn't work then plug the charger into your phone and lightly press on the charger. If your phone springs to life it means the charge port is likely suffering from a poor connection. If this is the case then sadly there is nothing you can do unless you're very good at soldering.
Jul 24, 2012 | Cell Phones
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
May 12, 2011 | Cell Phones
I plugged my LG Cookie Plus in after the battery died and nothing happened. It won`t chrage turn on it`s basically a paper weight and it`s only 3 months old. Plugged it into the wall and plugged it in to...
spiderandy12 lisren rake the battery out of the phone, Next look at the contacts to make dutr their is no corrision on the phone. The charging port sounds like it is shot. Take another charger and plug it into your phone and see if it woks. You may need a micro charger
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Mar 11, 2011 | LG Cell Phones
Samsung SGH-d807 Cellular Phone Logo
157 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
