Question about Iolo Technologies System Mechanic 5 Professional for PC
Need help about screen resoulution....
I have a Celeron 1.1 GHz, VIA chipset based pc, I faced a problem in display setting. I can't set its resoulution to 1024*768 with highest(32 bit) colour quality, when i select 32 bit the resolution automatically set to 800*600. both the resoulution supports only with medium colour quality.
Is this possible to set resoulution 1024*768 with highest(32bit) colour quality. I use Packard Bell 17" monitor which is launched in year 2000.
Thanks in advance.
  • 68 Answers
Try out these simple steps
1. download latest graphic drivers of your graphic card
2. orchange your monitor refresh rate to minimum like 60 HZ
Posted on Mar 03, 2008
What to do next after upgrading CPU
Hey;
Start your computer and right after the hp logo, keep pressing the F8 button until you see a large list of options.
Select
"USE LAST GOOD KNOWN CONFIGURATION"
and press enter. Let windows load and it should work just fine.
Feb 03, 2014 | HP Compaq 6720s Notebook
CPU and chipset no.
First time I have heard of a medion Mim2310, Steve.
Some Medions, yes. Mim2310, no.
Not exactly a lot of these in the States.
L@@KED everywhere on the 'net for info, and it's like looking for Hen's teeth.
1) First; what is the socket number on the white CPU socket?
http://www.ebay.co.uk/itm/MEDION-MIM-2310-INTEL-MOTHERBOARD-411818360001-/120937492341?nma=true&si=7UyoBmEk2gpzdrec7jp1kTJOtpE%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Scroll down to large photos. At LEAST I found a motherboard, sheesh!
Now to the 'Chipset'.
The motherboard chipset.
Before I go further;
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The motherboard chipset technology as used on your laptop motherboard, consists of a Northbridge chip, and a Southbridge chip,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[Trivia:
Looking at a -> desktop computer motherboard as a Map, the CPU sits due North, the Ram Memory slots due East, and the expansion slots due South.
The Northbridge chip sits close to the CPU, therefore -> North
The Southbridge chip sits closer to the expansions slots. Therefore -> South ]
The Northbridge chip handles the Faster capabilities of a computer.
The Processor, Ram Memory, and HIGH-speed graphics.
[HIGH-speed graphics is the AGP technology, and PCI Express technology.
A graphics card inserted into a white long PCI slot, is NOT high-speed graphics.
Nor is using Integrated Graphics ]
The Southbridge chip handles the Slower capabilities of a computer.
Anything using the;
A) PCI bus, plus Integrated Graphics
B) IDE (PATA) bus
C) SATA bus
D) USB bus
E) Ethernet
F) Audio (Sound)
Point?
Yes, you need to know what the Northbridge chip is, along with what CPU socket is used.
The Northbridge chip is, as you probably know; under that finned aluminum Heatsink, sitting close to the CPU socket.
The Heatsink is glued onto the Northbridge chip.
You COULD use a hair dryer set to low heat, and soften that glue, to assist removing the Heatsink, and see what the ID numbers are.
JUST, a suggestion.
The nozzle of the hair dryer is moved around on the Heatsink, and not left in one spot. Use a glove on your hand, and try to GENTLY twist the Heatsink, back, and forth.
Once the glue is soft enough it should twist easily, then remove.
Problem here is the residual glue may mar the ID numbers.
May be able to remove glue, and save ID numbers.
Once the glue is softened use a thick old credit card, to scrape the glue remnants off. Use Q-tips dipped in Isopropyl Alcohol to clean.
Heatsink bottom, and top of Northbridge chip.
Takes a LOT of alcohol dipped Q-tips.
(Rubbing Alcohol)
91 or higher percent is best, but 70 percent will do.
50 percent = No IMHO
50 percent water now, and 50 percent Alcohol.
CAUTION!!
Isopropyl Alcohol is EXTREMELY FLAMMABLE!
Use in a WELL ventilated area with NO sparks or flames present!
http://www.ebay.com/itm/Thermal-Heat-Sink-Silicone-Compound-Paste-Grease-Glue-For-Computer-PC-CPU-Cooler-/170953660131?pt=US_Thermal_Compounds_Supplies&hash=item27cda1d6e3
Thermal GLUE to put back on.
List of Intel chipsets,
http://en.wikipedia.org/wiki/List_of_intel_chipsets
Just did that to get you started.
What you want is list of Intel 800 series chipsets, for Mobile,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4-M.2FPentium_M.2FCeleron_M_mobile_chipsets
or 900 series Intel mobile chipsets,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_M.2FCeleron_M_mobile_chipsets
I'm also going to include three other chipset manufacturers. If not needed perhaps it will be reference for the future,
http://en.wikipedia.org/wiki/Comparison_of_AMD_chipsets
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_chipsets
http://en.wikipedia.org/wiki/VIA_chipsets
Out of curiosity, what is the letter/number on that VIA chipset?
Want to see what it is used for.
Post back in a Comment.
Hold the phone!
I just ran into a supposed schematic,
http://laptop-schematics.com/view/5992/
Clicking on the schematic enlarges it, and shows a;
1) CPU - Intel Yonah Core / Celeron M, that fits a Socket 478 processor socket.
Intel Celeron M410 uses a Socket M CPU socket,
http://en.wikipedia.org/wiki/List_of_intel_celeron_microprocessors#.22Yonah-1024.22_.2865_nm.29
http://en.wikipedia.org/wiki/Socket_M
Yep. 478 socket holes, for a CPU with 478 contact pins.
Only it's for a Mobile CPU.
The Intel Celeron M410 is Yonah Core based, and is an Intel Celeron M.
Going with your statements, and the 'schematic', (It's a Block Diagram), I concur.
CPU socket is Socket M.
If that VIA chipset IS the Southbridge chip, and it is a VIA VT8237A, then it may be safe to assume the Northbridge chip is as the 'schematic' states -> VIA VN890 / VN896
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#VIA_processors
Go to the bottom of this chart, to the bold black subheading ->
VIA VN896 (Mobile)
"VIA VN896(Mobile) can support Intel Pentium M / Mobile Core Duo Processor"
Hmmm,................
Celeron M that fits a Socket M CPU socket, and Yonah Core technology based,
http://en.wikipedia.org/wiki/List_of_intel_celeron_microprocessors#.22Yonah-512.22_.2865_nm.29
You can use a Celeron M 450 with no sweat.
http://www.ebay.com/itm/Intel-Celeron-M-450-2-GHz-LF80538NE0411ME-Processor-SL9KX-/221169813802?pt=CPUs&hash=item337ebf892a
Just for fun I did a quick search.
However to go on...................
Lets see if there is a compatible Intel dual core CPU.........
VIA VN896 Chipset Specifications;
http://www.via.com.tw/en/products/chipsets/v-series/vn896/index.jsp
If this holds true that it is a VIA VN896 Northbridge chip, the Intel CPU's it can support are listed. Just not by Name/Model Number.
Scroll down a little more than 1/3rd page to the blue chart,
Features of VIA VN896;
1) Intel;
Pentium M
Celeron M
Core Solo, (Misprint on their part)
Core Duo
Core 2 Duo
Front Side Bus (FSB) Support;
Either 400MegaHertz, or 533MHz, or 667MHz.
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Core_2_Duo_2
To ME, IMHO, I think the Intel Core 2 Duo Mobile processors can be used, but ONLY in the Merom, Merom-2 Core.
The one's that have NO higher FSB, (Front Side Bus) of 667MHz.
(Ahem. MT/s stands for MegaTransfers per Second.
Brought out to be more concise in explaining this technology.
I still use MegaHertz. MHz.
Mega stands for 1 Million.
Hertz stands for Cycles per Second.
Much easier for me to explain the technology, than using MT/s ]
Also we can see the Voltage Range of the Celeron M410 through Celeron M450, is 1.0 Volts to 1.3 Volts. (DC)
All the Merom, Merom-2 Core processors, that are in that chart I linked, have a voltage range of 1.0375 Volts to 1.3 Volts.
Therefore any that have a 533MHz, or 667MHz FSB, should work.
This concludes my case your honor, defense rests....
(What?)
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 10, 2013 | Medion Computers & Internet
What kind of processor does a dell dimension 1100 have?
Dell 1100
Single core 478 Celeron D 2.80 GHZ
The best I can tell it has a an Intel 865GV chipset based motherboard, according to intel's website (http://compare.intel.com/PCC/showchart.aspx?mmID=135,138&familyID=10&culture=en-US) you can install a Pentium D (dual core :) ) processor.
Dec 19, 2012 | Dell Dimension 2400 PC Desktop
I want information about modem.is this modal
http://xpdrivers.com/intel/_2_135610.cfm
The link show above is for all intel desktops and laptops drivers.
Yes, the model in your laptop or desktop is an internal modem.
Here's a full specification of the laptop you have stated in your problem.
  • Intel Celeron-M?370 (1.6 GHz)
  • Integrated Wireless LAN 802.11b/g
  • 15.4"Colour TFT ;
  • Express Slot /Card Reader In-Built
  • CDRW/DVD Combo Drive
Microprocessor
-Intel Celeron-M370 (1.6 GHz)
Cache Memory
-1 MB Integrated L2 Cache
Chipset
-Intel 915GM Chipset
Memory
-256 MB DDR2 (533 MHz)
-2 SODIMM Slots (Expandable to 2 GB with discard)
Hard Drive
-40 GB Ultra DMA (ATA 100) 5400RPM
Optical Drive - CDRW/DVD
-24X/10X/24X/8X Combo Drive
Video Graphics
-IntelGraphics media accelerator (GMA) 900 / DVMT 3.0 upto 128 MB
Widescreen Display
- 15.4"XGA TFT
Speakers
-Stereo Speakers
Audio
-16 bit Stereo(Sound Blaster Pro Compatable)
Fax/Modem
-High Speed 56K Modem
Network Card
-Integrated 10/100 BaseT
-Broadband Ready
-Integrated Wireless LAN 802.11b/g
Battery
-6 Cell Lithium Ion
Interface
-1 Headphone / Line Out -1 Microphone In
-3 USB 2.0 Ports
-1 S-Video TV-Out
-1 RJ-11 - Modem
-1 RJ-45 - NIC
-1 DC Power In
-1 VGA Out -PC card slot-PCMCIA Type II?
Pointing Device
-Touch Pad with On/Off button
-Right/Left button
-Four way Scroll Zone
Keyboard
-87 Keys layout
-12 Function Keys
Dimensions - (H x W x D)
-330 X 275 X 25mm -Note: Height varies depending upon where on the notebook the measurement is made
Mar 16, 2010 | Intel Computers & Internet
EMACHINES T1740 Intel Celeron 1.7 GHz
The following shows specs for your system to get http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T Series&model=T1740
I was able to get as far as the Intel 845GL chipset and now i need the actual type of motherboard. Take off the cover and it should be something like S2098AGN. You can do a google search for your "Motherboard model + manual + download" and you should be OK. Hope this helps, Best Regards, -md
Nov 12, 2009 | E-Machines eMachines Desktop PC
Je veux savoir les caracteristiques de mon pc
Merci pour votre demande.
Voila les details demander
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} desktop
i
OLIVETTI OLIVETTI
OLIVETTI DESKTOP AD200N-1245 OLIVETTI DESKTOP AD200N-1245
Processeur Intel® Pentium® Dual Core E2180 (2x 2.00 GHz, 1 Mo L2 cache), Chipset VIA® PM900, Mémoire DDR2 1024 Mo, Disque Dur SATA 160 Go Intel ® Pentium ® Dual Core E2180 (2x 2.00 GHz, 1 MB L2 cache) Chipset VIA ® PM900, DDR2 1024MB, HDD 160GB SATA
Prix public : 6100DHS Retail price: 6100DHS
OLIVETTI DESKTOP AD200N-1210 OLIVETTI DESKTOP AD200N-1210 Processeur Intel® Celeron® 420 (Core 1.60 GHz, 512 Ko L2 cache), Chipset VIA® PM900, Mémoire DDR2 512 Mo, Disque Dur ATA 80 Go Intel ® Celeron ® 420 (Core 1.60 GHz, 512 KB L2 cache) Chipset VIA ® PM900, DDR2 512MB, HDD 80GB ATA
Oct 19, 2009 | Computers & Internet
Problem with Audio Driver
download astra free edition from the net and run the software....get the sound/audio chipset details from the software and do a google search for it
you would be good to go...if you cant still get the driver get me the audio chipset details from astra and ill send the link to download
keep me posted
May 08, 2009 | Computers & Internet
Agp.vxd driver for p25g ??
base on what youve said the video card should work properly without any problems because almost all brand new video cards have an exact drivers and application to support your computer. try to see the configuration of your video card and try to set the options of it. if not ill give you a link to download a driver for your video card. just choose the compatibility and download. hope that helps!
http://www.nvidia.com/Download/index.aspx?lang=en-us
CHARCOIS
Jul 27, 2008 | PC Chips P25G Motherboard
Laptop
here are some details below find the right one and take it
Model No: TM 2403NWXCi
Platform: Intel Celeron-M Processor 370 (1.5 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
RAM: 256 MB DDR2 400 RAM
HDD: 40 GB
Optical Drive: DVD-Rom/CD-RW Combo Drive
Display: 14.1" Wide Screen XGA TFT w/1280 x 800 resolution
Graphics: Intel GMA900
Other Features: Ethernet / Integrated 802.11b/g Wireless LAN/ 56K Fax-Modem/ 3 USB Ports
Weight: 2.38 KG
Battery: 6-Cell Lithium Ion Battery
O.S.: Linux
Warranty: 1-Year Global Warranty
Price: Rs. 27,999*
Model No: TM 2424NWXCi
Platform: Intel Celeron-M Processor 380 (1.6 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
HDD: 40 GB
Weight: 2.35 KG
O.S. : Linux
Price: Rs. 28,499*
Model No: Aspire 5002NWLMi
Platform: AMD Turion 64 ML-30 (1.6GHz)
RAM: 256 MB DDR333 RAM
HDD: 60 GB
Optical Drive: DVD-Dual Double Layer drive
Display: 15.4" WXGA Acer CrystalBrite TFT Screen w/1280 x 800 resolution
Graphics: N.A.
Other Features: 10/100 Ethernet, 56K Modem, Integrated 802.11 b/g WLAN with Acer SignalUp, Integrated Bluetooth
Weight: 2.9 KG
Battery: 8-Cell Lithium Ion Battery
O.S. : Linux
Price: Rs. 37,999*
Model No: Aspire 5004NWLMi
Platform: AMD Turion 64 ML-34 (1.8GHz)
HDD: 60 GB
Graphics: N.A.
Weight: 2.9 KG
O.S. : Linux
Price: Rs. 38,499*
Apr 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
To u my friend
nothing much buddy ...
HDD: 40 GB
Weight: 2.38 KG
O.S.: Linux
Price: Rs. 27,999*
HDD: 40 GB
Weight: 2.35 KG
O.S. : Linux
Price: Rs. 28,499*
HDD: 60 GB
Graphics: N.A.
Weight: 2.9 KG
O.S. : Linux
Price: Rs. 37,999*
HDD: 60 GB
Graphics: N.A.
Weight: 2.9 KG
O.S. : Linux
Price: Rs. 38,499*
Model No: Aspire 5502ZNWXCi
Platform: Intel Centrino Mobile Technology based Processor Pentium M 735A (1.7 GHz / 2MB L2 Cache / 400MHz FSB) / Intel 915GM Express chipset.
HDD: 60 GB
Optical Drive: DVD+CDRW Combo Drive
Display: 14.1" WXGA CrystalBrite TFT with 1280 x 800 resolution.
Graphics: N.A.
Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 2 USB Ports.
Weight: 2.38 KG
Battery: 6-cell Battery
O.S. : Linux
Price: Rs. 40,499*
Model No: AS 1641NWLMi
Platform: Intel Centrino Mobile Technology based Processor PM 725A (1.6 GHz / 2MB L2 Cache) / Intel 915GM Express chipset
RAM: 256 MB DDR2 533 RAM
HDD: 60 GB
Optical Drive: 8X DVD-Dual Double Layer Drive
Display: 15.4" WXGA CrystalBrite TFT with 1280 x 800 resolution
Graphics: N.A.
Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 3 USB Ports
Weight: 2.38 KG
Battery: 4-cell Battery
O.S. : Linux
Warranty 1-Year Global Warranty
Price: Rs. 42,499*
Apr 14, 2008 | Computers & Internet
Iolo Technologies System Mechanic 5 Professional for PC Logo
80 people viewed this question
Top Iolo Technologies Computers & Internet Experts
Jax Planet
Jax Planet
Alun Cox
ray gallant
Are you an Iolo Technologies Computer and Internet Expert? Answer questions, earn points and help others
