Question about Maytag Performa PAV2200
Detergent doesn't seem to rinse out
No matter how many times I rinse the washing or how little detergent I use the rinsing water is always sudsy and the washing doesn't feel 'rinsed'
  • Anonymous Mar 03, 2008
    How do I remove the spin bowl in order to remove the lint build up?
  • Anonymous Apr 10, 2008
    I have the same problem as Standish. I have a Maytag Performa washing machine (Purchased Dec. 1999) in which we replaced the water pump (Pump #21001906) in Dec. 2006. This machine is used VERY LITTLE. I cannot get a clear rinse cycle. There is always sudsy water. What could be the problem?
    Sergeant:
  • 351 Answers
Common problem you may need to remove the spin bowl and clean them they get lint build up around the top hope this helps.
Posted on Mar 03, 2008
RE Whirlpool Mod WTW8200YW0 top load, there is always soap left on clothes in the washer no matter type and amount of detergent my wife uses. Any ideas?
Check the water suppl lines to make sure they are not hooked up backwards the rinse cycle uses cold water if the temperature sensor detects hot water it will stop power to the log valve if hooked up correctly then place unit in a rinse cycle to see if rinse valve is opening
Jan 26, 2015 | Whirlpool Washing Machines
How do I fix a washing machine that doesn't fill with water, but spins and drains? Water enters the detergent holder, but doesn't seem to make it to the tub. Draining can be heard as well, even though
Hum for one a front load H.E washer should not be having very much suds as u claim it had. Are u aware the front loads are made to use very little soap and if u use to much soap hence alot of suds, ur SUDS SENSOR will act up and can shut down any wash cycle. a trick is to run just water and some vinagar trough a couple loads if u can get to wash at all. Another issue u may have is a plugged line somewhere. or loose unconnected water hose line hence the water on the ground effect. u may want to check ur flow line from the entry into the tub where the water at the moment I cant recall the name of the gadget but it can get clogged or damaged and hinder the water from entering the tub
Jan 15, 2015 | Kenmore Washing Machines
Seems like there should be a pump or sending unit the would be controlled by the cycle timer. ProbAbly went bad. Hopefully you got the extended warranty?
Our dishes are not being cleaned well with residue left on plates and cutlery and the light next to the rise aid is on at the end of the wash
I have had the same problem a time or two. Make sure that you don't overload the dishwasher and nothing is blocking the spout where the water comes out. Also if you haven't done so already, you may want to add some detergent to the pre wash. Make sure you have enough detergent for the regular wash cycle also....Hottest water possible (at least 140 degrees F). If all that doesn't help, try cleaning them on heavy wash. Check to make sure the rinse aid level is still full. I have also found it easier if you rinse the dishes or cutlery off before putting them into the dishwasher.If none of the suggestions work I say changing your dishwashing detergent and/or rinse aid.Good Luck!
Sep 08, 2011 | Dishwashers
I put rinse aid in but it seems to not be working or at least it keeps showing that it is full and it doesnt go down? Also it seems that there is always detergent left in the slots after it gets done...
The rinse agent dispenser holds up to 8 ounces of rinse agent and only 2-3 small teardrop sized drops are added in the rinse cycle ,thats all it takes per cycle so a full dispenser could take 2-6 months to become empty depending on how often ya run the dishwasher.
As far as some detergent remaining,check the filter in the bottom of the tub for some blockage,if the water cant spray forcefully because its hard getting into the pump from filter blockage it cant wash that well
I hope this helps
Gene
Aug 03, 2011 | Kenmore Dishwashers
I have a front loading Kenmore washer and when i put liquid detergent and fabric softener, the liquid flows into the machine - should the detergent and fabric softerner remain in their compartements until...
Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Jul 26, 2011 | Kenmore Washing Machines
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
When to add softner during wash
Hello, the softener is added during rinse circle but bleach needs to be added at the beginning. First add the detergent, then let the water get it nice and sudsy, then add the bleach then the cloths. It is when you get to the rinse circle that you add the softener.
Thanks
May 22, 2010 | Whirlpool Inglis IP4400 Washer
LG WASHER
Unplug your machine for a few minutes or more and plug it back in. This will fix the LE error most of the time.
Apr 27, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
103 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
