Question about Panasonic Workio DP-2500E Copier
Panasonic DP 2500 J81-J82 paper jam
When making a copy everything works fine. When I duplex the paper runs through the duplex and stops in the paper path in the door. The paper has no signs of catching on anything it seems to just stop. When I open the door to remove the jam the paper is usually stopped with the paper in the top feed roller assembly in the door. I recently rebuilt the fuser.
  • 1 more comment
  • laserp Mar 05, 2008
    Thanks, I will check out those areas. The duplexer has been on the unit for several years now and it has worked. I was called because it was jamming in the fuser and making a grinding noise. This was caused by the upper fuser roller bushing being fragmented into peices. I rebuilt the fuser and I have taken the dual path guide out and checked it over. The paper does reverse and is on it's way back down the duplex paper path in the door.
  • laserp Mar 06, 2008
    The paper is not catching on anything and most times completely out of the dual paper path. Typically the jam is coming down and stopped with the upper roller assembly in the door, right in the middle of the page. I wish the paper was catching on something I could see the problem then. The error says that the paper did not reach the sensor in time, sensor 2 for the 81 and sensor 3 for the 82. I am not sure which sensors those are. I assume the sensor 2 is the dual paper path and 3 is in the upper roller assembly in the door. But it is always past the dual paper path assembly sensor. So I am not sure that the upper roller sensor is 2 and the next sensor down is 3.
    I had thought about a wire being broke but when I remove the paper and close the door the jam clears and it will print the same page again before jamming in the same place. I would think that the jam would remain if a wire was broken. Unless the machine resets all sensors when you open and close the door.
    I swapped the upper feed rollers in the door and it fixed the problem. They had said that the problem only started when I rebuilt the fuser. After pointing out what the problem actually was. I told them that I have never seen rollers just completely stop feeding paper instantly and that usually they start having jams that gradually worsen. They then admitted that duplexing hadn't worked at all for a long time. Since this was a new customer. I had no history on this machine.
    The problem they had called me on was the fuser was grinding and jamming everytime, which it was. The bushings were completely gone. I had no way of knowing or testing the duplex option before doing repairs. Unfortunately it seems my biggest problem was the customer not being at all honest.
    Thanks Jxxx for your help
Ben kaça gidiyorum
Posted on Mar 31, 2008
Ben kaç kardeşim
Posted on Mar 25, 2008
Ben kaç kardeşim
Ben kaç kardeşim
  • 33 Answers
Check the sensor lever spring and cable on top of dual path guide (on top of fuser unit) also if the door stopper has been broken there is a good chance the door may be slightly deformed in which case a gentle adjustment may be reqd. check on the diverter solenoid there should be NO spring attached to the white guide. that is supposed to be removed when the adu option is fitted.
Posted on Mar 05, 2008
  • 1 more comment
  • J M Mar 06, 2008
    check sesor cable on top of dual path guide the come out easy when re-installing also check for any pinched wires. while youve got it all out you may want to swap tht sensor as that area gets hot and that sesor is not heat proof and can fail. if that doesnt work check jammed paper for any physical damage to see weather its catching on something. if still not fixed let me know
  • J M Mar 06, 2008
    sounds like a tricky one, i checked the description of the jam codes and was thinking that it may be pointing to the sensors on the door side, in which case check them (if you havent already) and try and follow the cables around the bottom of the door and onto pcb. does it do the same thing on different paper sizes, try pushing on the door a bit as it running...worth a shot
  • J M Mar 06, 2008
    Glad you got it sorted.
Duplexer problem
There are several thing which may cause unexpected jams in the duplex tray...,
1. first thing to do is eliminate all other possibilities by removing the netCard/Net connection Parralel connection so the machine is Stand Alone. make sure there is paper in the feed cassette 2 ( paper Tray)
press the TICK to enter menu
scroll down to diagnostic- press TICK
scroll down to paper path test - press Tick
scroll down to Source and select tray 2
scroll down to Duplex And select YES
( if the duplex option is not visible here then there is a connection/seating problem with the duplex tray)
Scroll down to copies and select 10
scroll up to print test page and press tick
the machine should now start duplexing 10 pages,
if you get the same error ( 1 page enters then jams)
it could be a dirty/snapped paper entry sensor,( looks like a little plastic match stick that protrudes into the feed path of the paper)
use a can of pressurised air to Blast any dust away from this arm and the surrounding area being careful to follow the Paper sensor Arm back to the sensor and blasting this as well-
Duplexer tray are cheaper than an engineer call out, if the fix above fails , your cheapest option may be a replacement Duplexer tray, available from most HP office equipment Stores as well as Belmonte Business Equipment.
Jul 23, 2013 | HP LaserJet 4250n Printer
Duplex jamming of copy paper
Clean the rollers and clean the clutches mounted in the duplex cover to the rear of the duplexer Also the fuser mite be bad the fuser inter connects with the duplexer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 01, 2010 | Minolta DiALTA Di183 Copier
Copy/Printing machine jams
This tells me your DUPLEXER is the one causing the jam, Ok like when you open the duplexer do you see the paper in their
second does your copier indicae that the duplexer is in stalled ?m print the config page to verify. if it worked ok until this incident then your paper feed tires in your Duplexer is worn and needs to be replaced, do not do this yourself call a Service tech or A dealer to do so, uf your in CT we can help.
Mar 06, 2009 | Panasonic Workio DP-3530 Copier
Panasonic DP 2500 paper tray error
Make sure that you don't have too much paper in the tray. There is an overfill idicator on the back of the tray. Push the tray in firmly. Then try to print. If not, reset the printer by pushing "reset" button.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 21, 2008 | Panasonic Workio DP-2330 Printer
Paper jams at finisher when making multiple copies. Using 20 lb. paper. Any suggestions? Copier is Panasonic Workio DP-4510 with detached finisher.
first try to eliminate the finisher. turn off main power switch and unplug from the power outlet. Now unplug the finisher cable from the rear of the copier, then slide the finisher out of the way. Check to see if you still are having jamming issues. if not then yes the issue is with the exit of the paper or the finisher.
Many possibilities try to narrow it down.
Good Luck
Sep 27, 2008 | Panasonic Workio DP-4530 Copier
Workio DP 2500
means that the machine needs a good cleaning because it reached so many copies. has to be serviced by a dealer
Sep 23, 2008 | Panasonic Workio DP-2500E Copier
How to re-set so that "Another Original? No-Yes" does not display after making one copy
You can look in the user's settings. But, I have not seen that display not show or had anyone ask about it.
Feb 06, 2008 | Panasonic Workio DP-2500E Copier
Paper Jam E54
The one crinkled at the end on the left door is the problem.
Since it jammed it stops the whole copying process, ( you were most likely doing duplex)
The reasons for the crinkled paper are
1- the fingers or claws at the exit are worn and catch the paper instead of sliding them out.
2- you are copying something that has a black edge and is getting caught on those fingers ( or claws)
3- The rollers at the exit are in bad shape :
anyway check out this link and go to error codes :
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Nov 17, 2007 | Toshiba e-Studio65 Copier
Getting J33 code on panasonic workio dp-2500
That's a registration sensor error. 9 times out of 10, the registration sensor's spring fell out of place and that sensor is not popping back. When you open the right door, you'll see a sensor flag (plastic flag) sitting in the middle of a rubber roller.
Nov 16, 2007 | Panasonic Workio DP-2500E Copier
Panasonic Workio DP-2500E Copier Logo
402 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
