Item
Part Number
Description
Tachometer
LH turn indicator
Oil pressure gauge
Overdrive (O/D) off/tow haul indicator
5
Engine temperature gauge
6
Air bag warning indicator
7
Safety belt warning indicator
8
Fuel gauge
9
Tire Pressure Monitoring System (TPMS) warning indicator
10
Speed control indicator
11
Transmission temperature gauge
12
RH turn indicator
13
Speedometer
14
Malfunction Indicator Lamp (MIL)
15
Message center indicator display area
16
High beam indicator
17
ABS warning indicator
18
Brake warning indicator
19
Message center display area
20
Anti-theft indicator
SOURCE: need to replace busted tail lens on F150 2001 SuperCrew
open tailgate. on tailgate 'door jamb',next to light assembly,remove attaching bolts [I think 8mm?] outer edge of assembly has plastic 'pins' into fender.pull assembly straight out to access wires/bulb sockets.
Check and make sure your cooling sytem is ok
