Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
Digital Array We moved our tv and now we are having a problem with the colors. We were able to align all of the red + signs, but we're having a problem with the blue ones. A few of them are tilted and the analog is only working right to left on some and not at all on others. We can also pick one and it will move another one. Not sure what to do.
  • shellymm Mar 03, 2008
    Thank you......
  • 103 Answers
The unit needs the convergence ic's replaced.This is a common occurance with this set.It should cost no more than from an honest repair place.This problem was caused from a combo of poorly manufactured parts and vibration.They will probably install a factory mod kit for this unit.
Posted on Mar 03, 2008
Hello, My main color were out of alignment, as per instruction on manual. I pressed the button for digital array and proceded to align the blue color, then I proceded to align the red color but I could...
The red convergence IC has failed. There are I believe 3 total convergence IC in your tv. The prefix for all three is STK392-xxx. If you can solder you can try and replace yourself otherwise you need a tv tech. With Hitachi's sometimes some critical resistors will change value as well and have to be replaced with exact equivalents. Sorry wish it was an easy solution..
Oct 17, 2010 | Hitachi 55FX48B 55" Rear Projection...
Color wont move off of mute to align
maybe the degausing coil is defective or your tv is de magnetise or the color control is defective. if no just consult your problem to APEX service center near you
Jun 19, 2010 | Apex Digital GB4308 43" Rear Projection...
Colors do not line up on my tv ( left side of sreen looks like 3D) digital array "+" are only white on right side.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 11, 2010 | Hitachi 50FX20B 50" Rear Projection...
I can't align red or green bulbs with the digital array, how can I get them to move left/right they only move up/down.
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2009 | Hitachi 50UX57B 50" Rear Projection...
The colors don't line up on my projection tv, what
U have convergence prob.it dead.Tries these websites.Tv Repair World.com,Ebay.com to buy a convergence kit,repair what in that kit.U know how to solder right?
Oct 03, 2009 | Hitachi 50FX20B 50" Rear Projection...
I have double image I am looking at array but not
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 05, 2009 | Hitachi 50DX20B 50" Rear Projection...
Digital alignment on my Hitchi 46in projection tv
If the set cannot converge it self then the convergence ICs need to be replaced. Check local professional for prices
Apr 21, 2009 | Hitachi Televison & Video
The red square on the digital array alignment is moving up and down,but now side to side
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 04, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Color Allignment
press menu on the remote and then u will be able to align the blue
Oct 30, 2007 | Hitachi 50GX30B 50". Rear Projection...
Hitachi 50" - 50GX30B
You will need to replace the convergence IC inside the TV set.
Aug 12, 2007 | Hitachi 50GX30B 50". Rear Projection...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
56 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
