Question about Toshiba 50H72 50" Rear Projection Television
Picture gone. I have a Toshiba 50H72 rare projection TV and face the same problem now. Two weeks ago, I found that the letters or pictures at left bottom of TV became two line or ghosted that always red color was out of alignment. I was told that I could try align the convergence.So I opened front and adjusted the convergence. I did not see big improvement. This morning, I just tried to adjust it again. Unfortunately, all of sudden, picture was gone. I tried to torn off and on directtv satellite and TV several times. The TV light and sound were OK but there was no picture at all. Is anyone can help me to figure out what could be the reasons and I am wondering how much it could cost to fix this problem?
  • Daniel Jackson Apr 29, 2008
    I have a Toshiba TheaterView but really do not know the model ( i cannot find the model number ?) Now let me describe the unit, it stands 50" tall, the dia measurement is also 50". Black wood frame, flat front.
    I bought this unit at a yard sale for $ 5.00 (get what u pay for right ) it was working, played with it, went into the convergence setup, (maybe i messed up here, not knowing what i was doing) worked for several days, the picture went out, unplugged it, after 24 hours the picture came back in. Then turned it off with remote, day later turned it back on NO PICTURE, but there is sound, even went into the channel setup, again sound galore, but no video. so i took off the plastic front, looked at the three ( R G B ) colour guns, the red, green guns are very bright, but the blue (far right gun) is very faint, can anyone tell me what i did wrong, if anything, or is it in the hardware ?
    daniel_jackson1@yahoo.com
  • 103 Answers
You have bad conv. ic's.On these sets when the ic's go bad it will usually pop a fuse or burn up a few safety resistors,causing ith video to go away.
Posted on Mar 03, 2008
  • mike ireland Mar 07, 2008
    The cost should be about 300.00 for repair
How to i change the picture from antenna to cable?
TV/CABLE function
1 Press MENU, then press S or T until the SET UP menu appears.
2 Press up/down arrow button on remote until "TV/CABLE" is highlighted.
3 Press to highlight either "TV" or "CABLE", whichever you use.
Hope these info will help you.
Let me know if you need user manual free copy of Toshiba 50H72 tv.
Thanks.
Jan 05, 2011 | Toshiba 50H72 50" Rear Projection...
Power but no picture
the Y-SUS BOARD is for picture in tv.if the picture is not coming or not proper the Y-SUS board needs replacing .but if the picture is blurry or with linings reparing helps.but in your case the tv does not turns on with y-sus board connected only error led comes on.this means y-sus board needs replacement.
you can get it from www.partstore.com
if you are not familiar with replacing the y-sus board its advisable to get it done by local tv repair technician familiar with your brand/model.
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya.
Oct 26, 2009 | Toshiba 50H72 50" Rear Projection...
TOSHIBA 50H72 50IN. REAR PROJECTION TV BLUE COVERGANCE PROBLEM
you have a convergence ampliphier ic failing that will need to be changed and then adjusted
average repair cost for this are 280.00 to 320.00
Jan 20, 2009 | Toshiba 50H72 50" Rear Projection...
I have a toshiba model 50h72 double vishion
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 12, 2008 | Toshiba 50H72 50" Rear Projection...
Tv picture
Does the image appear to be 3D? Let me know as it sounds like convergence issues. Is there anyway you can post a picture of what the screen looks like?
May 17, 2008 | Toshiba 50H72 50" Rear Projection...
Violent shaking picture initially but slowly tapers off but still shakes
Do you have a service manual for your tv? If not I would suggest you get one because there could be several things causing this I will post a website whre not only can you get a manual for your tv but they also supply free online tech support to help you troubleshoot and fix your problem
http://servicemanuals.vstore.ca/
May 06, 2008 | Toshiba 50H72 50" Rear Projection...
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Flashing picture when start up
What i would do id purchase a can of freeze from radio shack
wait till the picture is good then freeze one ic at a time till the problem shows up, once it shows up let it warm back up and refreeze to make sure you got the correct part.
found this on anther site:
My first guess is an electrolytic cap in the main power supply and/or a voltage regulator that feeds the deflection amplifiers.
The cost of repair is not much; the greatest challenge is finding the bad cap because there are so many of them and scattered through out the sections.
If you have a scope and can look at some waveforms and voltages around the deflection and power supply feeds you may be able to zero in on it right away
Oct 11, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
