Washing machine.Fisher and Paykell Kelvinator
Fisher and Pykel Kelvinator (058) 5.5kg Machine wont run.powers up but wont start. even when advance button or pause used. Wont go no matter which temperature/spin configurations selected. Machine is half full of water which it wont pump out either.machine is ten years old. last year it stopped working on hot or warm (stopped and alarm sounded. I put in some warm water from the tap before programming and switching on this time and it has not gone since. Any ideas thanks. Cant really afford a new machine so hoping its an easy glitch. Paul
  • paol01 Mar 03, 2008
    Thanks a lot for your help greendude. I thought  I'd sorted the problem when I over-rode the lid switch. Machine now starts but stops between the wash and rinses and spin wont engage for more than 1/4 turn! I wonder if the machine sends a test to the lid switch between functions? Not sure if I should get a replacement switch part. dont want to give up after my earlier (short lived) success. No corrosion on the board which appears fine.
    Sergeant:
  • 351 Answers
Check the lid switch under the lower board they rust and the fault is normally not starting,or the display board can rust inside near the start/pause button if so try and unsolder a button you dont use and replace the start button.
Posted on Mar 03, 2008
  • Ian Greenland Mar 04, 2008
    is the clutch dirty at the bottom of the bowl
Does the clutch slide up and down on the shaft may be dirty
Posted on Mar 04, 2008
WONT OPEN AFTER WASH
is it a fisher and pykel front loading washing machine ?
What make and model is it ?
Try cancelling program and wait 4 minutes and try to open door.
Feb 01, 2015 | Washing Machines
Kelvinator smart drive 085 washing
Your lid magnetic reed switch could be faulty.
May 09, 2014 | Fisher and Paykel Washing Machines
Error 49 on a Fisher and Pykel washing machine, what can i do to resolve this?? Thankyou.
Your cold valve is faulty. The rubber membrance inside the valve can damaged after certain period of time. The problem may be inside the controller if replcement valve can't fix the problem. There is a resistor on the current path to the valve. It is on the control board. Some timems it can go open. Good luck with the repair
Regards
Sarath
Apr 15, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and pykel EcoSmart won't start
You can find a service manual at the link below to assist in repairing your machine.
Download the smart drive mw511 manual
Link:
Mar 10, 2012 | Fisher and Paykel GWL11 Top Load Washer
Error code 136 Fisher & Pykel washing macine
Hi just read your posting.Now Error code 136 means you have a motor stall fault.This means the motor controller cannot start the motor turning.Has your machine been noisy on spin?The things that cause this fault are,seized or faulty bearings, wiring to the motor faulty,faulty motor,faulty rotor position sensor, or faulty motor controller.Do you have or can borrow an electrical test meter ?If the answer is yes I can guide you throe the testing of the components to track this fault done.Please reply with additional information about the spin cycle and if you can get a meter and I will help you further.
Jun 19, 2010 | Fisher and Paykel (IWL12)
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fischer Paykell 7.5kg Smart Drive top load washer
Have you checked the lid micro switch under the motor controller which activates when you close the lid to start the machine?
Jul 24, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
440 people viewed this question
Top Washing Machines Experts
