Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon D80 with 400 IS lens
At times when I press the upper left view button to redisplay a picture that has timed out the picture does not reappear and the battery level indicator shows fully discharged and is blinking. A new fully charged battery does the same thing. If I turn the camera off completely and then back on I can then redisplay a picture with the view button but the same problems recurrs after a few more shots. Ted
  • Ted1934 Mar 05, 2008
    I have tried alternate good batteries. I am going to try another lens as it may be the contacts on this lens not making full connection at all times. Thanks for your help. Ted
  • Ted1934 Mar 09, 2008
    Thank you Canada Bruce. I currently have the camera at a local repair shop awaiting diagnosis. Expect an answer on Tuesday. Sorry I can not try your recommended fix right now. it sounds very plausible. Thank you very much for your suggestions. Ted
  • 58 Answers
Try a reset of the camera, and also reformat the SD card.  Then, turn the camera off and back on.
Check you battery info under the set-up menu, when you can see if the life of the battery may be too old.
Good luck.
Posted on Mar 09, 2008
  • 65 Answers
I think you should replace your camera battary with suaitable one.
Posted on Mar 03, 2008
Somehow my camera, a Nikon D60, is now displaying 4 smaller pictures on the monitor vs the full screen picture I just took. How can I change it back? I cannot find an answer in the instruction manual,...
You pushed the wrong button! On the left side of the LCD display, there are four buttons. One is labeled "ISO" and the other "QUAL". In the viewing mode, these buttons are used to allow you to scan multiple frames at one time. Each time you press the ISO button, it increases the number of images displayed. Each time you press the QUAL button it reduces the number of images displayed.
Oct 04, 2013 | Nikon D60 Digital Camera
Zoom on nikon d5100
In either mode, you're zooming by turning the zoom ring on the lens? In live view mode, if you zoom in by pressing the magnifying glass button, all you're doing is zooming the display, not the image itself.
Feb 26, 2013 | Nikon D5100 Digital Camera with 1855mm...
How do i get the bracket pictures just back to showing just one? i have a nikon d 70 camera
If you're seeing multiple thumbnail pictures, press the zoom-in button (marked with a magnifying lens symbol) one or more times. Alternatively, pick one picture and then select the OK button at the center of the cursor pad.
Sep 01, 2011 | Nikon D70s Digital Camera
Overview is turned on the monitor when pictures
Press up/down on the multiselector to go through the different views of your picture.
Apr 05, 2010 | Nikon D5000 Digital Camera with 18-105mm...
How to set the time
Try this procedure (works for most Casios)
Make sure that you are viewing the time mode, then press and hold the upper left button on your watch. Then you can adjust the flashing item in the display with the two right hand buttons. To advance the flashing cursor, push the bottom left button.
Then when you're done, press the upper left again.
Oct 25, 2009 | Casio AQ180WB Databank Watch
Nikon D80 - LCD screen goes blank in the mountains
In the mountains, are you subjecting the camera to wide swings of temperature or humidity? These could cause your symptoms.
Sep 04, 2009 | Nikon D80 Digital Camera with 18-135mm...
RGB Histogram will not turn off.
It's not hard... I had the same problem, but I found this solution on the internet and it worked.
First turn on the camera and press the play button.
You are now viewing your picture with the histogram.
Use the same joystick looking kind of button that you use to scroll left and right through the pictures, but instead of going left and right, go UP OR DOWN. That scrolls through the different display settings.
Hope that helps!
Dec 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D40X Pictures Flash Black In Playback
You've just turned on the "highlights" option in image review. Press the up arrow on the d-pad to get back to the normal setting.
Dec 24, 2007 | Nikon D40x Digital Camera
How to set watch
I just set the time on mine with these instructions 1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours) then you can use the upper right hand button to navigate thru seconds, minutes and hours. Then you can change the time with the lower right hand button you can only change the time forward. I hope this helps !!!
Apr 02, 2007 | Kenneth Cole RK5034 REACTION
Nikon D80 Digital Camera with 18-135mm Lens Logo
53 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
