Back to:
Tags:
Jensen A600HLX Car Audio Amplifier
Bass boost/Gain
posted by kornkyd007 on Mar 03, 2008
I have a Jensen A600HLX, and I have the high-volume cutoff problem many other people do. I have the bass boost on the amp set to the full +12, and right now because of my weaker subwoofers, I have the gain get to around 4. For maximum output, it is best to have the bass boost set high, or the gain set high with the bass boost lowered?
Comment by kornkyd007, posted on Mar 03, 2008
Forgot to add, I have one 12" 4 ohm subwoofer bridged to the rear channel, set to 2ch mode with LPF. I have all the front channel settings turned down.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 05, 2008
Not Rated (0)
zzedly
Rank:Guru Guru
Rating: 88%, 154 votes
Both the bass boost and the gain generally do the same thing, except the bass boost is essentially "additional gain" at a particular frequency (in this case, 45Hz). I would suggest lowering the bass boost (10?) and adjust the gain. Honestly, you may have to play around with both settings until you find a happy medium. There is going to be a maximum the amp can provide no matter how you get there. Hope that helps!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Bass boost/Gain:
I don't want to Accept this solution
Can you Help with these Car Amplifiers problems?
Car Amplifiers
Hi ! I was wondering if someone can help me with cx475...
Car Amplifiers
you can request for more solutions by requesting solutions...
Car Amplifiers
burned 2 circurt on the power cable side on the top and on...
Car Amplifiers
code for a remote control universal for a pelisys tv
Car Amplifiers
need schematic
Loading problems.
Repair Service
Find Car Amplifier Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
