Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch SHU3300 won't run
I have a 5 year old Bosch SHU 3300 in a house we bought a year and half ago. It ran fine for about 6 months then just shut down. I fiddled with all I could get at (filters,etc. below) to no avail. A couple of days later it stared running again. Now a year later it has done it again. I fiddled and nothing, it's been over a week and it still won't work. Lights will come on but nothing happens, I've unplugged/tripped the breaker to reset but nothing?
Any ideas?
  • 1 more comment
  • DM3308 Mar 03, 2008
    How do you check the control module?
  • DM3308 Mar 04, 2008
    I understand Sergio's first response- check control module but the second response didn't seem to be addressing my issue? If it does, please clarify?
    Assuming it is the control module, can someone estimate how much ($) for a tech to test & replace? Verses just replacing the unit with something more reliable.
  • 57 Answers
As it is an intermittant problem, just double check the door latch switch, make sure it is clean and seems to be working properly.
Slamming the door once or twice, although not very proffessional, sometimes makes you feel better, and even sometimes works. (Don't tell anyone I said this ;-) )
Also, there have been reports of poor soldering on the control modules (very expensive to replace if you purchase). There have been certain cases where Bosch has replaced them after some considerable nagging. (Bosch (800) 921-9622).
Hope this is helpful. Good Luck!
Posted on Mar 04, 2008
    Genius:
  • 3,587 Answers
Sure...parts and labor will run you around 300.00, depending on your location
    Genius:
  • 1,226 Answers
Hello!
Only service tech can check the control module if there a control module of your phone.
Take the advice of ser71 so that everything will be resolve.
melnavz
  • Emelio Navaja
    Emelio Navaja Mar 04, 2008
    Hello DM3308 !
    since your unit is 5 year old, i guess that when getting to tech they don't charge high enough because the model is maybe old. i am sure that cost you cheap in repairing the unit.
    You know DM3308 I experience same( but not same unit) that unit was mulfunctions and let repair to the service center. the unit was repaired and function well, but it does not last long, its only 2months and i seat a side i did not use the unit.
    But your unit is different from my why don't you try.
  • 818 Answers
Check your control module.
Thanks
Sergio
Posted on Mar 03, 2008
  • Sergio Scalfaro
    Sergio Scalfaro Mar 03, 2008
    http://www.greenbuildingsupply.com/Docum...
    also
    The problem is the polymer was the wrong type for the high heat and
    humdity. The poorly engineered plastic activator fingers got brittle
    and broke off.
    Well the replacement lasted another 3 years and this time I had to
    order the part (264946) but it is only the front half. In order to get
    the back part of the coer you have to order the complete unit(266746).
    If your top arm stops spinning it could be the back feed tube is cracked (350321). Also the wrong polymer.
    please ask to bosh support, they can give the peace for free.
    Sergio
Zdis15
check hot gas valve to make sure it is not bypassing when in freeze mode this will not let the evaporator plate get cold enough. need to check refrigerant pressers.
Jun 07, 2013 | Kitchen Appliances - Others
Model 917.370410 won't start
Sounds to me like this model is a POS. I also have this same model, purchased last August have used only 5 or 6 times , has the same symptoms: hard pull, puff of smoke, won't run , etc. Even brought this to an authorized dealer to get it to run, but then it only ran a couple more times, dead again. Does anyone know of any recalls fro this lemon? I can appreciate everyone troubleshooting , but you shouldn't have to tear apart a 5 month old lawnmower which will only result in your warranty being voided.
Oct 04, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
2005 ford expl sport trac...after going 5-6 miles and stopin twice...then stopping cuts off engine with no engine warning light before it shuts down, it will restart fine but ..put in drive and it shu
Will it stay running in neutral if yes sounds like bad converter if it stops then I would clean the Throttle body with tb cleaner and tooth brush if no air is getting through the engine will not idle
Dec 31, 2011 | Cars & Trucks
I have a 6 year old Goodman "GPG10481151A" single
try turning the t-stat all the way down then kill electricity to unit wait ten min and turn everything back on, see if this helps. let me know.
Mar 02, 2011 | Amana Heating & Cooling
Our Bosch SHU 4300 dishwasher does not drain fully
There is a recall on the control board of many of these models, butyour problem is likely not related. A sticking impeller indicates that the pump may be failing, but you are welcome to try my guide to help. It is here. Thanks!
Jun 15, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Weed wacker worked fine a week ago. tried to start it up today and nothing happens. I followed step by step instructions and still got nothing. Only had it a year and only used it three times.
I have a two month old red max weedwacker that just decided to start shutting off when i give it gas. I hold idle no problem. Aircleaner=good, spark=checked, primer=good, dumped fuel and got same problem, I am upset because when redmax hit the scene with the backpacks they were solid. I just replaced a magneto on a year old red max blower and I am waiting on a crankshaft for a redmax set of gas shears: I hit a fence and in the past with other companies shears that was not a major problem. The redmax shears crankshaft broke and sheared two bolts of hardened steel on an irregular, recessed angle in the aluminum housing. After shelling out 450 bucks i am not the happy camper. I went old school and bought electric little wonders--know what: I forgot what a pleasure they were: light and no fumes. Any helpon the whip would be greatly appreciated. TOM 39 accounts long island ny
May 25, 2009 | Troy Bilt Tb70ss Gas Trimmer
Car running rough when raining
check the spark plug wires, put water in a spray bottle and spray along the wires,especially by the coil,if the car starts to run bad or you see sparks, the wires are no good, hope this helps, Ray
Apr 03, 2009 | 1999 Mercury Villager
Bosch dlx series SHU 3300
you need to remove the outside of the door to give you more room remove the six torx screws on the inside of the door sides only do not remove the top ones then the out side of the door will come off on give you room to work on it
May 04, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch nexxt 500 series dryer
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
Jul 30, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
364 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
