Question about Apple Cinema Display 23" HD Monitor
Apple cinema display 23"
My apple cinema does not turn on. I want to see if I can fix it myself. Any sugestions?
  • 3 more comments
  • jovel94 Mar 03, 2008
    I have but still the same.
    Are you talking about the power adapter?
    No the light is not flashing . It looks like the monitor is not getting any power .
    Just to look at it apple is asking for $450 plus I don't want to pay that much. If can guide me I know I can fix it I'm not a novice I just need ideas of what can be the problem .
    Ok I'll go to an Apple store and check the power adapter hopefully is that. I'll let you know. thanks
    Master:
  • 555 Answers
Is the power light flashing at all? The Apple Cinema Dispays have error light sequences that can help you diagnose your problem.
Posted on Mar 03, 2008
  • Matt Jurach
    Matt Jurach Mar 03, 2008
    Well, then we've narrowed it down to a power problem.
    The Apple Cinema Displays have their power transformer EXTERNAL to the display itself. It is in the "power brick" that you plug into wall.
    If there is an Apple Store near you, just take the power supply in and ask them to test it. Hopefully it won't work, and you can just buy a new one to solve your problem (relatively) cheaply.
    Or if you have access to another Cinema Display, you can test the power supply on that instead.
    If the power supply proves to be fine, then your options get more daunting and/or expensive.
    Besides the inverter, there really aren't any user-serviceable parts inside. And we know it's not an inverter problem, since you aren't getting that (or indeed any) diagnostic power light blink.
    You will probably at that point need to turn to a repair technician.
  • Matt Jurach
    I've never even seen Apple display components other than the inverter and assorted screws for sale. Working on the internal power components is where I bow out. There are Apple display repair facilities that aren't quite as pricy, though.
  • 65 Answers
Change Power cable or check Power Input.
    Genius:
  • 1,226 Answers
Hello!
Please do and verify any fuse blownout in the inlet of the power from the wall, if it is not visible then maybe you open the the back cover and try to see any parts that has error or blown. you should replace it with genuine replacement parts. however it hard to do this by a novice tech, My suggestion is to bring the unit to the nearest service center maybe the unit got warranty service or else maybe its a cheap or resonable cost.
may this help!
best regards, melnavz
  • 1 more comment
  • Emelio Navaja
    Emelio Navaja Mar 03, 2008
    If you power adaptor, and sure that it is good, then the unit got error inside. is the power adaptor is good, Did you test and examine it?
  • Emelio Navaja
    so if the monitor flashing power or indicated power then maybe you should fix the some cable connection on all the system. but if the monitor is totally dead then refer to my first suggestion.
  • Emelio Navaja
    OK, jovel94 , please rate as "thanks for trying " so that your problems will be visible to some expert in fixya i recommend sulvisitor(maybe not the correct Usrname) he is expert in TV and monitor troubleshooting.
Blinking light on 20 inch apple display
Blinking light on Apple cinema display usually indicates insufficient power from the power supply. Test it with another power supply from ANY cinema display (23" and 27" power supplies are ok to test with).
Feb 03, 2014 | Apple Cinema HD 30" LCD Monitor
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
Power connector on cinema display is damaged. Can it be replaced?
Hello, GREAT NEWS!!! Yes you can replace it. Try going onto Ebay and punch in: A1097 Apple cinema display power ac adapter 90W 23" LCD.
May 05, 2010 | Apple Cinema Display 23" HD Monitor
Backlight is not working
eht coil generator which generates power for backlight tube is damaged change it
Nov 26, 2009 | Apple Cinema Display 23" HD Monitor
Apple 23" cinema display
thats supposed to mean theres a faulty powerbrick, however i have the same problem on mine and replacing that didn't solve it
Oct 28, 2008 | Apple Cinema Display 23" HD Monitor
Apple 23" Cinema HD Display went off
Hey - I just got done with 30 minutes of trying my cinema HD on my macbook pro and plugging and unplugging. When I plugged it into an extension cord in another socket the monitor started right up. I've had this configuration in my office for years with no problem...until today. Did mac send us a system upgrade that caused a problem with the monitor's power source???? Good luck!!!!
Jul 28, 2008 | Apple Cinema Display 23" HD Monitor
Blank screen (Apple Cinema HD 23"LCD)
damn gay i got t is 23 apple screen for 14month and it has a black screen now :( .. what can i do to fix this .?
Jun 06, 2008 | Apple Cinema HD 23" LCD Monitor
Apple Cinema Display 23" HD Monitor Logo
479 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
