Whirpool agitator agitator moves but does not churn the load like it should. I bought some plastic/ looks like clips/ and removed the plasic agitator by removing bolt in center but canot get it apart to replace these. do you have diagram on how or if it comes apart or how to get these out to replace them.thanks clueless! whirlpool model# 4213632 style master
  • Anonymous Jan 20, 2009
    I have removed the bolt but can't seprate the clothes mover from the agitator to replace the dogs.
    Sergeant:
  • 351 Answers
The parts are called agitator dogs,the top half of the agitator should pull away from the bottom half.
Posted on Mar 03, 2008
Mav39 fills, drains, wont agitate, makes loud riviting like noise instead of agitating. took off agitator and the mechinisim that would activate the agitator isn't moving, but making this loud noise....
There is a coupler if this is a direct drive machine. Tilt the unit back and look under for a pile of rubber shavings or a couple of broken plastic bits. The coupler is easy to change by removing the cabinet with the gold clips at the top. Then remove the clips from the pump and hold that out of the way. Remove the screws and clips from the motor after disconnecting the wiring harness. The coupler is on the shaft of the motor and the gearcase. Replace all three pieces...there are two hard plastic three fingered bits with a rubber isolator.
If you have a belt then it is very likely that you have a bad gearcase and you may consider a new machine for cost reasons. The coupler should be under $25.
Sep 18, 2010 | Maytag Dependable Clean Top Load Washer,...
My 2090 Kenmore model washing machine (serial #cj3302826) is slow on the spin cycle. If any clothes are on the agitator,it will not spin. Remove clothes off and along the edge, it will spin. Also, does the...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
As far as the agitator spinning during the spin cycle:
It's not supposed to. It may spin simply because of the oil in the gearcase turning the agitator shaft but it shouldn't be driven by the gearcase. See the following Whirlpool Service Manual on how the transmission / gearcase works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
What should happen is:
When the washer goes into spin mode, the gearcase reverses direction moving two plastic cams (Agitate Cams) together which push up against a spring which lifts the agitate shaft away from the agitate gear.
If the agitate cams (about $12.00) are worn (not necessarily broken) they may not lift the shaft high enough (about 1/8") so that the agitator will spin along with the drum.
Also see the Whirlpool Parts list for their Commercial washers, although the consumer models use the same transmission.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you suspect the agitate cams:
It's a bit messy to fix (16 oz. of oil in the transmission) but very inexpensive.
See the following for how to remove the transmission.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You don't have to remove the drum.
You can also see this site for removing the transmission.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
May 18, 2010 | Kenmore 24902 Top Load Washer
Washing mashine tub pounds when spinning on kenmore series 70
See the component section on the base of the washer.
There are springs and friction pads designed to keep the inner tub from moving too much when agitating and especially spinning.
One or more of the springs may have come loose or the friction pads may have worn.
Following is the Whirlpool / Kenmore installation and service manual for top load direct drive washers with a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also see the following for how to remove the cabinet in order to gain access to the springs and pads.
If the springs and pads are fine, I'd consider looking into the "agitator cam" in the transmission.
If the cam doesn't lift the agitator gear high enough during the spin cycle, (as we had) you would get a major vibration.
See the section in the Whirlpool manual on how the transmission works and the agitator cam.
We had to replace ours and the vibration stopped.
Only if you need to, look at the following.
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Oct 19, 2009 | Kenmore 22422 Top Load Washer
This Kenmore Elite Top Load Washing machine has
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This gets a little tricky.
It sounds as if, based upon the weight in the tub being reduced, the noise gets less. Something is pressing on something else due to the weight.
If you look at the gearcase parts section of the Sears site, you'll see parts called the agitate gear and agitate cam.
If the agitate cam wears (it's two plastic pieces) when the transmission moves to the spin cycle, the cam is supposed to lift the gear above it.
If it doesn't lift the gear high enough, you'll hear loud gear noise. This may lessen as the washer pumps water out and there is less weight on the spring.
We had the same problem with a washer and found that by replacing the cams, the noise went away.
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Sep 26, 2009 | Kenmore Washing Machines
The top load heavy duty mashine wont wash
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cuase this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
Aug 11, 2009 | Speed Queen AWS75NW Top Load Washer
How can one remove the agitator,it seems to move slower than it used to
If this a Whirpool manufactured washer (this includes Kenmore, Estate and Roper), the agitator can be removed by following these steps:
1, Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap. Some washers will have a fabric softener dispenser on the center post.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
If you have questions, or need additional assistance, please let me know.
NOTE: When reinstalling the agitator make sure you do not over-tigthen the bolt. This can damage the agitator and restrict its movement. Tighten until snug.
Jul 08, 2009 | Whirlpool WTW5500ST Top-Load Washer
Whirpool washer, only number on the back is 3357976
sounds like i could be a bad coupling, most whirlpool washers are direct drive so there is not a belt, there is however a linkage between the motor and transmission. Pull the machine out and tilt it back. check on the floor directly beneath the washer for a pile of blck dust (this can be an idication of a bad coupler) make sure you wedge something underneath it so it dont fall on you while working on it. remove the pump by levering off the 2 clips, push the pump aside then remove the 2 screws holding the motor clips...remove the wire harness on the motor and then remove the 2 clips holding the motor in plce with a screw driver. now you should be able to drop the motor out...the coupling is the tripod shaped plastic attached to the motor and another to the transmission, they have a black round rubber linkage with 6 holes...examine this for damage and replace if damaged. re-assemble washer in reverse order.
Jun 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator will not move unless you press down on it.
If the agitator is slipping, you may have worn out agitator dogs. Yes, there is such a thing. These are small plastic clips that act in the manner of a clutch for the agitator. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The link also explains how to remove the agitator. If you require addtional assistance, please let me know. I hope this helps you.
Jan 09, 2009 | Kenmore 22422 Top Load Washer
Kenmore top load will not spin or agitate
drive coupler is bad available on ebay or sears appliance parts little bit time consuming but not hard.remove the top agitator by grasping it and pulling up remove the plastic cover and the bolt under it ,remove the agitator. lay the machine on its side (water may leak out) remove the water pump by prying the clips from the top of the pump slide the electrical connector from motor and start capacitor ,move the clamps on the hoses down from tub and slide hoses off .remove the 3 9/19 bolts holing the transmission in place slide it out remove two 5/16 bolts from clips holding motor and slide motor off transmission replace rubber drive coupling ,installation is reverse of removal
Dec 08, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
485 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
