Question about Video Cameras
PC & notebook wont recognise DV connection
My comupters wont recognise that my camera is connected. I have bought 2 separate firewire cables and still nothing happens. I have tried different programs, it was sent away for warranty but returned because it was apparently working. I cant get my PC to recognise the camera so that I can capture....run out of ideas and options.
  • 2 more comments
  • dwb991 Mar 05, 2008
    I have tried that and found that the IEEE 1394 is enabled. My PC tells me that my IEEE 1394 is functioning properly aswell in device manager. When I connect the camera the LCD screen on the camera blinks and the PC also blinks as if it detects something, however the camera is not listed on the PC and the programs cannot detect it...
    The camera is a Samsung VP-D371Wi. Has anyone else had problems with this camera? I am just about to give up really, becuase Samsung wont help me because warranty found the camera to be functional, the store wont help me, and I have no where else to go...
    Any ideas are extremely welcome
  • Mazen22 May 23, 2008
    I have the same problem with my samsung vp-d371i camcorder. I tried on xp sp2 and vista. It just nothing happened. It shows DV sign on the camera when plug it but nothing happen on the PC.
    also I turn off firewall and restart my computer.
    I have on-board ieee1394 and 4-pins to 6-pins cable.
  • indian raja Sep 24, 2008
    Has anybody been able to decipher. Now I m seriously thinking of changing the camea rather than struggling with it. But need to convert some precious videos first.
  • Anonymous Feb 23, 2009
    I have just bought this cam corder (sumsung d371wi) and have no idea how to get my movies onto the pc, so I can put them on dvd. Can any one help, i am very green!
I'm also facing the same problem for this model of camera. in my case, i don't have any on-board firewire port. so i've bought a firewire card, and connected my camera to that. but my camera shows the dv sign, though my pc don't recognise it. please, can any one help. i really need that.
Posted on Aug 11, 2008
  • 593 Answers
Is your firewire controller turned on or enabled in the BIOS? Maybe its off. when your PC boots up, use the F2 key or del to get into th e BIOS, under peripherals, there may be a firewire controller that can be disabled/enabled. Check that and get back to us.
Posted on Mar 04, 2008
I bought my camera used online. The DV cable input does not work. (Unfortunately I was not told about this problem.) I cannot pass the tape to my computer now because of the DV input problem. Does...
I recommend you, test the cable, the Firewire ports. test connection.
Plug the firewire into the camcorder BEFORE turning it on,
You must use a Firewire cable and FW ports (Firewire to Firewire) NOT USB port
Check the cable no bend.
1.- Try with other cable
2.- Try connect a different Firewire port on your PC (or connect to other PC)
3.- To test the FW port on your PC connecting other devices by example external hard drive
If the Hardrive work fine the problem is with your camcorder
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Panasonic DVX-100 Camcorder
I have the sony DCR-HC26E handy cam i'm trying to connect it with my pc (windows 7) by using usb cable it wont work my pc doesn't recognise my camera ....thanks
USB connection will allow still photos ONLY to be capture to a computer. To capture the footage from the tape you will have to connect with a firewire cable, also called iLink or IEEE1394a. Windows Movie Maker will be one program that can capture the footage.
May 19, 2011 | Sony DCR-HC26E PAL Mini DV Camcorder
Sony PC110E video camera that is not recognised by PC
Buy a 4 to 4 pin or 4to 6 firewire cable (depending of Your PC model). Connect it to PC. In any case, the system must to recognize firewire device and capture the images. If PC don't want to see Your cam via direct firewire connection it means the firewire out is broken and needs to be repaired.
Sep 10, 2009 | Sony Handycam DCR-PC110E Mini DV Digital...
I have a JVC GR-D250 camcorder. When I connect firewire cable (that has come with the camera) to the PC it gives message "USB device not recognised". If I check the Device Manager it shows "Unknown...
You should have a DV Cable 4-pin to 4-pin firewire (part number VC-VDV204U ) which came with your camera. It would not have firewire on one end and usb on the other. They are two seperate technologies. see http://www.wisegeek.com/what-is-a-firewire-to-usb-adapter.htm
May 02, 2009 | JVC GR-D250 Mini DV Digital Camcorder
How to connect JVC GR-D820E camcorder to PC
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Canon MV800 - FireWire connection
firewire is also called 1394 or dv port-card can always be added to older computer to support-cables are 4 pin to 4 pin or 4-6 pin-cam is always 4 pin -mac and most towers 6 pin-laptops are 4 pin-look for a port that looks like usb but has a trapezoid shape end
May 22, 2008 | Canon MV800i Mini DV Digital Camcorder
Camcorders problems
It seems you've tried some of the steps I would suggest already. However, to avoid any confusion I'll mention them anyway:
-When you connect a camcorder using DV cables, you have to use the playback mode rather than the PC Connect mode. The firewire connection is a p2p interface for streaming.
-The camcorder sometimes does not show up under "My Computer" when using DV connections as no removable drive needs to be installed. In this case, the camcorder may still be recognized and you should use the "capture" feature of whichever software you prefer.
-Most camcorders require that the AC adapter cable be used during capture operations for various reasons. If you are not connected to AC power, this could halt some functionality.
-Generally camcorders require a cable and IEEE1394 card that are OHCI compliant. Very rare you would find any that aren't, but it may be worth checking into if you're still having issues.
-Obviously, as you've mentioned, checking the device manager and BIOS configurations to ensure your hardware is operating properly was a good call.
Mar 08, 2008 | Panasonic NV-GS5B Mini DV Digital...
Jvc digicam gr-d370as
I HAVE A JVC GRD370 AS ITS USB NOT CONNECT TO PC HOW IT IS CONNECTED/
Dec 23, 2007 | JVC GR-D20EK Camcorder
My Panasonic Palmcorder PV-GS19 does not connect to my pc
if you want to transfer the video to the computer, I use a firewire cable that I had to buy separately, make sure ur computer has a firewire port. The usb cable is only good for downloading pictures.
Dec 17, 2007 | Panasonic Palmcorder PV-GS9 Mini DV...
Video Cameras Logo
470 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
