Question about ZT Group CISNET A7050 PC Desktop
Trying to connect comp to a router get message not connected
I have tried to install my comp on with my sisters who has a router, i am using my inthernet cord from the back of my comp to her router which is what i was told to do but still get the message not connected
  • Anonymous Apr 13, 2008
    ethernet continues to say no connection and after talking with cable internet provider everything looked good but i still could not connect. after i played with the ethernet connection on the computer it began to come on and off but will not operate properly. it continues to flash the disconnect message and no cable internet can be used.
    Sergeant:
  • 239 Answers
Go into your network devices and inable it there should work for you fine then. thanks
Posted on Mar 03, 2008
When I tpye in 192.168.0.1 always says page not available,
Yes connect your PC and Router with Ethernet cable and try again.
Your router's manual is here, refer it for reset your router, it's best idea to reset and whole solution. http://www.dlink.com/-/media/Consumer_Products/DIR/DIR%20655/Manuels/DIR655B1manual070312v23pdf.pdf
Sep 26, 2012 | D-Link DIR-655 Wireless Router
When my sister got her laptop he bought this DIR-615 Wireless N Router and now i got a Iphone and tryed to connect it to the Router via WI-FI and the name apears but it needs a code and when my sister...
The code they are talking about is the WEP Key. If the code was changed from factory default when you installed the router the only way to see that code would be to access the router with the computer and look at what the code is set to.
Feb 16, 2011 | D-Link DI 514 Wireless Router (DI-514)
I m using a toshiba L310 laptop & it was fine with a wireless internet connection but suddenly it lost connection & its not connecting anymore. what can I do now?
restart your comp and your router, if that doesnt help try and update your drivers to your wireless card in your comp., if everything is updated and the wireless in you comp is searching then it might be the router, they commonly overheat for heavy use
Sep 18, 2010 | Internet Computers & Internet
Cant connect old comp to new router
go to > control panel >network connections > in left hand pane.under Network Tasks..click..Create A New Connection... that will start a wizard and will guide you thru the process. you will also need to install the drivers as well for his computer to be able to use the modem/router.
i hope this has helped
Sep 09, 2009 | HP Pavilion a330n (Refurbished)...
Dell xp wont connect to the internet thru this router.
I think that the settings in your sister laptop is the problem. See if it is using static ip ad and if it is using it, try to use dynamic to get an ip to the router.
Apr 14, 2009 | Computers & Internet
My sister has a Motorola SP4200 router with a Netgear WPN824v2 wireless router/accesspoint/switch connected to it. Previously she had the SP4200 connected to port 1 (not WAN) port on the Netgear as it is...
it might be asking for a WEP password in order for you to use it which is on the botom of the router or the game sistem is the one causing the trouble and should not be conected to any wirless or eathernet internet routers.
Jan 03, 2009 | Computers & Internet
Cant get internet connection with linksys wrt54g, getting message
This is an issue which happens when the DHCP server on the router does not assign any IP address to the computer trying to connect to it.
-might have to do with settings on the router or the computer itself.
but if everything on the router and your network connections section in cotrol panel is in factory state then following procedure should help.
-Try power cycling your router.
-once router is back on try connecting to it again.
this should resolve it.
Dec 22, 2008 | Linksys Wireless-G WRT54G Router
I have a laptop comp i just got a desk top comp i have embarq broadband internet which comp do i pit the cd into to install and which comp do i hook up the embarq box to?
It sounds as though you will need to get router to allow the sharing of the Internet between the two computers. Using a router makes it much easier to share an Internet connection between multiple computers. You would connect the Embarq box to the router on the WAN port, and then connect your computers to the LAN ports of the router. You may also want to get a wireless router in the event your laptop has a Wi-Fi connection.
Oct 06, 2008 | Computers & Internet
Router not being recongized
if your running windows xp then you should remove any programs that you installed to run router then look into hardware manager and uninstall router and restart computer . then try once again plug in router once comp boots and let win xp load the correct drivers if this doesnt work go to windows update website and get all available updates including all hardware updated then try installing again good luck with it
Jul 13, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting problems
First of alll on your comp...
click start>run>type in run box as cmd>it will open up a command prompt screen....
in that screen type in lowercase as ipconfig and press enter
it will give you a message like
ipaddress as 192.168.0.2
default gateway....192.168.0.1
if you get this message...then open internet explorer....
type in addressbar as 192.168.0.1
and try opening the page if page doesn't open up then...
1... unplug all the cables from your router...turn off your comp..
now connect just the power light in your router...and at the back of your router you'll get a rteset hole...in there is a reset pin you need press that pin woth a ball point pen for 15 seconds after that..connect the cables one that connects your router and phone socket and connect the ethernet cable as well it will connect your router and comp...
now open up internet explorer page again and try the same 192 address if you still don't get the page...
then if you're using windows xp.....
click start>run>type cmd>in the command prompt screen type in this command"netsh winsock reset catalog" without quotes and press enter...and after that restart your computer...
then again try opening the router page...
the page will open up......do this stuff and let me know about this i will send the screenshots for config the router....
thnks
Feb 20, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
ZT Group CISNET A7050 PC Desktop Logo
177 people viewed this question
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
