Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Stains between the glass on my oven.
I have drips on the glass. This is very strange since I rarely even cook. How did this get dirty? What can I do to clean it?
    President:
  • KitchenAid Master
  • 2,651 Answers
You would need to remove the door (specific instuctions for each model generally in user manual "HOW TO REMOVE DOOR".. once off a few scews alow the bottom and top the outerglass w/ handle shloud release giving you access to clean
Posted on Mar 10, 2008
I have a whirlpool range rf263lxtq the oven stays consent on what is wrong with it
Oven clicks as if it is relighting almost constantly.
· Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
· The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Feb 15, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Why won't my gas grill stay lit?
GAS OVENS
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
ELECTRIC OVENS:
Jul 04, 2014 | Zanussi Ovens
How do I clean beko oven door inside panel?
Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
Dec 28, 2013 | Ovens
White heat stains in a Broaster oven
Debruce polish works perfectly on these types of "stains". Also use on all glass surfaces: fire place glass, oven windows etc... you will be amazed. Yet not available at the retail level you will find this wonderful "green product" at debrucepolish.com
Aug 24, 2013 | Ovens
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Excessive smoke comes out from oven when cooking
hmmm sounds a bit strange is there anything at the bottom of your oven that has been spilled on it even on the heating coils? (if electric) (if gas there could be a very serious problem with the oven that needs fixing right away!)
Dec 17, 2017 | GE 30" Built-In Single Electric Wall Oven...
How do I take off the glass on my oven door to clean it?
I have a Kenmore oven and all I had to do was remove the screw at each end of the handle (accessed with the door open) and the very front section just opened up - SIMPLE!! Wiped it down put the screws back in. Did it all by myself - just have your cleaning cloth in reach before you start. Can't believe I looked at those drips for years and it was that simple!!!
Mar 21, 2009 | Maytag CWE4800A Electric Single Oven
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
111 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
