Question about ASUS P5RD1-VM Motherboard
Time setting faulty????
Using a P5RD1-VM M-board ,i notice the faulty of time even when it use to set it up..it returns to different time when i restart the computer.i change the m-board battery...but same problem occur .
it comes to an idea to reformat it for a new windows to set a new time..after all..it goes to the same problem..
somebody help me.....
hamlet
  • letni Mar 03, 2008
    anyway thanks alot, thats what i'm thinking before.but .i use to set the time sitting in cmos upon putting of new operating system (pressing del) &(f10 for saving)....after rebooting the system..it change again to diff. time....i'm thingking that i have a problem w/ my mainboard...anyway everything works fine with my system ,except for the time...thanks for the idea & more power!!!!!!!!!!
    hamlet
  • 57 Answers
Check timezone it's possible you are setup for the wrong one
Posted on Mar 03, 2008
P5rd1-vm - will RAID setting delete my data
Suggest you enter the bios and make a setting change. Open the manual to page 2-24.
The M1573 RAID function set this to [Disabled].
(This will stop the bios from loading the RAID controller.)
See boot menu page 2-31 section 2.6
Set section 2.6.1 Boot device priority as shown.
(The drive with windows installation on it should be in the boot order).
You can also unplug either the data cable or power cable of the slave drive to assure it does not boot. If you still receive a blue screen with the primary drive suggest you re-install windows or boot to the windows CD and create a new partition within the free space of the primary drive. Install windows complete including updating. When finished you'll be able to copy you're data to the new windows. Use windows disk manger program (diskmgmt.msc) in the run window to delete the old windows partition.
Some programs will need to be reinstalled.
Link to Asus; http://www.asus.com/Search.aspx?SearchKey=P5RD1-VM
Cheers'
Mike
Mar 14, 2010 | ASUS P5RD1-VM Motherboard
Is there any video card compatible to my ASUS p5rd1-vm ?
You ASUS mother board has 2 PCI slots.
1 PCI Express x16 <- this 1 is for video expansion
1 PCI Express x1
Jan 08, 2010 | ASUS P5RD1-VM Motherboard
Memory not recognisedrecognised
you can only expand to 2 gb think you have extended toomuch
Jan 10, 2009 | ASUS P5RD1-VM Motherboard
Install SATA HDD for asus p5rd1-vm
The motherboard will support this drive.
I will assume you simple need it as additional storage set up as an additional drive?
If you do not see it in My Computer after connecting power and SATA cables, you will need Activate the Drive and Format it
To do this go to Control Panel - Adminstrative Tools - Computer management - Storage - Disk Manangement
You will see the harddrive here, right-cick it, Activate as a simple Partition and then format it.
You will now see it in My Computer and will be able to store on it.
Jan 05, 2009 | ASUS P5RD1-VM Motherboard
I HAVE P5RD1-VM ASUS BOARD NOW COMPUTER STARTED PROBLEM
several reasons for this.
1:) CPU Overheating.
2:) RAM Overheating.
3:) Motherboard Component Overheating.
4:) FAN not operating correctly.
These are a few things that can shutdown a computer after a few minutes, also viruses/trojans et,c.
can shut off hard-drives. and even instruct the bios to change settings.
Check that the CPU And case fans work correctly.
Mike @ compurepair.
Nov 17, 2008 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM driver
i advise you to try and download driver magician from any torrent sites. if your lucky, youll see that and that will be a great help in locating your motherboards drivers.
Jun 11, 2008 | ASUS P5RD1-VM Motherboard
Faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
Faulty time???
Hello!
That's the first time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
may this help!
Mar 03, 2008 | ASUS P5RD1-VM Motherboard
Upgrade P5RD1-VM motherboard to the gaming PC
Your pc is not for gaming right now because you are using Intel Pentuim 4 Mother board and CPU. Amd Athlon is best for gaming. I have a AMD Athlon 4200+ X2 with 4gb Ram and Nvidia 6800 256mb OC. to upgrade your computer to a gaming pc. you will need to switch your motherboard and cpu for best performance on games. in order to do that, you might need a different case for your new motherboard. because the one you have might not be right for the AMD Athlon motherboard unless you have a custom made computer. other than that everything is set for you. if you have less than 1gb ram you might want to add more. because the games they are coming with right now is 1gb minimum or required.
i hope that answers your question.
Thank You
Dec 08, 2007 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
