Question about Panasonic PV-D4743 DVD/VCR
DVD player is unable to play or open. The VCR side works perfectly. The dvd player just quit working, don't know what the problem is with it.
  • vakdj Mar 03, 2008
    I've opened it up and checked it out, there wasn't anything in there. the dvd wouldn't open when i press eject on the dvd player and the remote. when i use a pin to open the player, it seems sort of caught...not like how it use to be, i guess it could be the gears gone bad.
    still don't know what the problem is.
  • steveaiton Aug 24, 2008
    I have teh san\me issue. I opned the unit and there was no disc is in the drive. It appears as if there is no power to the drive.
  • 57 Answers
It's posible you have a cd stuck in, i will open the cover and check it you can also you use a lense cleaner
Posted on Mar 03, 2008
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
Magnavox vcr/dvd combo the vcr part only plays for 8 seconds
What you have is called a transport problem in the VCR unit--the mechanism is either jammed or something in it that loads the tape is bad.
Every time it is used it cycles to self check the mechanism--if it fails it is usually a belt bad or a gear assembly not working.
Someone would have to open unit to see what is happening.
May 28, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
CAN VIEW THE DVD ON A COMPUTER OR THE DVD RECORDER BUT NOT ON DVDS PLAYERS BOUGHT BEEFORE THE RECORDER
This is quite common of older players. Some only work with DVD+R discs and others with DVD-R discs.
Some player also does not read recordable discs (an early form to try prevent piracy)
Also make sure if recorded on your Recorder, that the disc is finalized before you try to play it on an older player. (See your menu / manual on the recorder for the procedure)
Feb 28, 2010 | Sony RDR-VX515 DVD Recorder/VCR
My Sony DVD/VCR combo will play cds but not dvds. I took the top of the player off and I can see that the dvd spins but it won't play. It used to play everything very well but just stopped working...
Please clean laser lens with good quality cotton bud gently and check dvd disc playback, if still does not play, replace optical lens block.
Let me know model number of your Sony DVD-VCR combo to provide you optical laser block part number info.
Thanks.
Nov 15, 2009 | Zenith DVP615 Portable DVD Player
DVDs won't play
Your laser is massively dirty or went bad
Company Site http://www.attechcomputers.co.cc
Jun 18, 2009 | Hitachi DVPF2U DVD Player / VCR Combo
Sylvania DVD/VCR combo
THERE ARE NO HEADS IN A DVD PLAYER! IT,S CALLED A
LASER. IF YOU TAKE THE UNIT APART DO NOT LOOK AT THE LASER IT WILL BLINED YOU BE CAREFULL WHEN YOU CLEAN IT. IFF WHEN YOU CLEAN IT IT STILL DON,T READ THE DVD,S IT MAY BE BAD. IF THATS THE CASE, IT,S TIME TO GET
ANOTHER DVD PLAYER. THE LASER COST TO MUCH TO REPLACE.
Jan 05, 2008 | GoVideo DVD-VCR Combo
No picture
Sounds really broken. Unless you can find a replacement DVD drive for low money , you may have to junk it.
Dec 12, 2007 | Sanyo DVW-7000 DVD Player/VCR
UUURRRG
Not spinning disc
If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A
Unable to detect discs
The laser head was the culprit. Replacing it fixed the problem. (Laser head code GRP6278A)
Difficulty reading cd, if it does read the sound is strange and sticks
Replace C101 (1000uF/16v)
Nov 24, 2007 | Philips DVD750VR DVD Player/VCR
Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Sep 06, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Unable to open my DVD player
i have same problem with vcr , all mecahnism ok but dvd ok but vcr does not work all mechanism ok beccause i check manul its and are ok let me know if you knw somethins , in your case chech manual it open the dvd internal and check for work manual . wilfred
May 27, 2007 | Panasonic PV-DR2714 27 in. TV/VCR/DVR...
Panasonic PV-D4743 DVD/VCR Logo
91 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
