Question about HP PhotoSmart 7260 InkJet Printer
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help
  • 3 more comments
  • smaddrey Jun 26, 2008
    Haven't used pinter in a while--three months or so--just plugged in to my Mac (which it is installed on and worked beautifully last time)--all that is happpening is the red light is blinking next to on/off switch. Will feed paper through, though
  • twana12 Aug 27, 2008
    The print cartidge got stuck and I got it undone. It printed for a few pages, but then it stopped feeding the paper through and now it tells me it is out of paper every time I try to print, but the paper tray has paper in it...
  • lorri4624 Dec 30, 2008
    I have same problem with my HP 7260. My last printer (canon) did this also, was told to toss it and get a new one. Why do printers always die with full ink cartridges in them. Now I have a printer that doesn't work with $75 worth of ink I can't use in a new printer. I wish someone would design a printer that lasts longer than a couple of years. Frustrating!!!
  • Anonymous Jan 18, 2009
    my print cartridge cradle stuck
  • sugarpups26 Jan 31, 2009
    Everytime I try to print, my printer says there is a paper jam and it won't feed the paper through. I did what was suggested (rocking the cradle by hand) but it still isn't working. I am trying to print wedding announcements. Any help will be appreciated on this! I'm about to throw it out in the snow and buy a new one!
There seems to be a problem with the cradle not "lifting" itself up and over what appears to be some sort of guide. Rock the cradle gently back by hand (it will only move a few millimeters) and move it all the way to the right into its bay. Cycle the printer power and it should be fine.
Posted on Oct 02, 2008
  • 152 Answers
Replace encoder strip
Posted on Mar 03, 2008
3 Suggested Answers
myob247
  • 1342 Answers
SOURCE: HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Posted on Jun 26, 2008
SOURCE: print cartridge cradle stuck
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Posted on Dec 30, 2008
My printer keeps saying print cartridge cradle is stuck clear jam then press ok, but there is no paper jam
Because it's NOT a paper jam, but a cartridge cradle jam, I suppose it's an ink jet printer??? if so, check for debrie arround the cradle shaft that could prevent the printing cradle to move from left to wright... you could also lubricate the shaft by rubbing a little bit of grease on it with the tip of your finger (verry thin layer), as ink sometimes gets on it and tends to become sticky with time...
Aug 10, 2011 | HP Office Equipment & Supplies
Screen says cartridge cradle is stuck but it moves freely
Ok there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | HP PhotoSmart 7760 InkJet Printer
Print Cartridge stuck
Look at the pad on the right side of the printer under where the ink cartridges are loaded. It may have ink deposits built up into lumps which interfere with the movement of the cartidges on the rod. Clean the deposits by scraping the lumps and removing all debris. This worked for me.
Jan 23, 2010 | HP PhotoSmart 7550 InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Even thought there is NO paper jam, I still get an error message:
Please try this solution :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 19, 2009 | HP DeskJet F4280 All In One Printer InkJet
There is a print cartridge crudle is stuck...clear jam and press ok saying on the screen of my printer what should i do?i cleared the paper jam but it still says the same thing
Remove your cartridges, pull the power out see if the cradle moves freely around by hand. Check make sure that theres no paper that stayed behind. Did you rmove the paper by force? Maybe you dmaged the paper sensor.
Dec 08, 2008 | HP Photosmart 8150 InkJet Printer
HP8250 printer
Jun 26, 2008 | Office Equipment & Supplies
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
HP PhotoSmart 7260 InkJet Printer Logo
502 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
