Question about Frigidaire FEF366DC Electric Kitchen Range
Problem with oven
Bake element on oven will not shut off. the light shuts off but the bake element does not
  • 3 Answers
In order for the element to stay on when the control is turned off either the control has shorted or the contact that the control switch controls has shorted, if the the light goes off as usual it is most likely the contacts in the elements relay that have welded themselves in the closed position but both the switch and relay will need to be tested.
Posted on Mar 03, 2008
I have a GE 24 inch wall oven model number JRS04B0W5BB that when bake is selected the broiler element comes on and then after awhile it looses temp and does not cook anything.
Ovens often use broiler element to preheat, then shut off when set temp is reached. Check fuses for and bake element itself.
Dec 01, 2014 | Ovens
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
Feb 12, 2014 | Ovens
Oven elements do not heat?
The oven bake element has burnt out and needs replacing. Shut the power off to the range. Remove the element mounting screws located inside the oven above or below each end of the element. Carefully slide the element out, disconnect electrical wiring. Install new element.
Mar 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Maytag CWE 4800 oven bake element
Go to google and type in model and IOM and it should give you what you need. Replacing the element should not be hard. Just disconnect the power first. My main concern is that you said the oven won't turn off. You may have a control switch problem. Did the element melt at the terminals or in the middle of the element itself?
Feb 15, 2009 | Maytag CWE4800A Electric Single Oven
GE Oven JTP15BW Broil Element on, Bake Element off during baking.
I have the same problem. Just swap the 2 wires that are marked as 'broil' and 'bake' on the controller board. But sometimes it switches back, then I have to swap the wires again.
You might want to leave the 'broil' post unconnected to prevent burning food..
Nov 21, 2008 | Jenn-Air JJW8530C Expressions Collection...
Avanti er24aw1
Call avantiproducts.com sales (service didn't work) and get a replacement bake element. It was about $35 including shipping. Download the manual from the site and study the structure. Uncover the back cover using standard phillips screw. TO DO THIS, SHUT DOWN YOUR HOME BREAKER AND MAKE SURE THE OVEN OPERATION LUMP DOES NOT LIGHT. OTHERWISE YOU WILL BE EXPOSED TO HIGH VOLTAGE. Additionaly use multimeter to make sure the voltage is not there. Remove back inner cover. You can't remove this inner cover completely because of the thermostat line but try to make a work space in the lower part of the oven. The bottom element cover can be uncovered readily without any screw or pin. At this point you have access to baking element from the bottom of the oven. Loosen two nuts to remove the bad element. Reverse the procedure to install the new element.
Dec 03, 2007 | Avanti ER24AW-1 Electric Kitchen Range
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
Frigidaire FEF366DC Electric Kitchen Range Logo
91 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
