Question about Dryers
The flame is the problem
The flame dosnt go on but when i move or shake wires by the coil plug it clikes then the flame goes on for a short time maybe a minute or les ??? any guses it looks like it is the coil or what???
  • adrian22 Mar 10, 2008
    Dryer is cold-flame is on only for 1 min regardless the cycle selected.
    ** problem displayed on screen.
  • 156 Answers
Possible coil lose connection on coil
Posted on Mar 03, 2008
Whirlpool dryer heating sporadically?
Remove the lower front panel and turn dryer on. The ignitor should glow bright orange first. After Ignitor glows brightly the next thing will be the flame lighting as the gas valve opens with a click. All this should happen within about a minute or so.
If flame comes on but goes off quickly It's likely one of the Gas valve coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The coils are purchased as a kit.
If ignitor goes off and no flame comes on the coil kit is likely needed because one coil is fully broken inside its case. If flame goes on but shuts off shortly the problem is as described above and the kit is needed.
There is a flame safety assembly on the can above the burner. If the airflow is poor. the flame tip may activate that safety and turn the flame off. Or the flame switch may be open and not allow the flame to come on at all.
The Flame switch can be tested for continuity with an ohmeter but the valves may ONLY show bad with power applied and can not be tested with a meter as they will test good.. Good Luck
Nov 18, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
I have a GE gas dryer DBVH512GF1WW. The heat is inconsistent. I noticed the ignitor glowing and then a flame shortly after on the initial time I turned the dryer on. Then after the flame going out after...
sounds like bad gas coils located on top of the gas valve,when the coils start to fail the ignitor will glow,the coils let the gas in until the coils heat up and then ignitor glows but no gas.when the coils cool down they might work again for a short time until they heat up and fail again.if the flame lights and goes out after like 30 seconds and goes out and keeps doing this you have a block either in the dryer or the vent line but it sounds like you have bad gas coils.unplug the dryer,get at the valve,pull off the wires going to the coils and check them with a meter,one should be open,just remove the two phillips screws pull off the cover and slide the coils up off of the posts,unplug them and put the new coils on,you'll see like a little piece of plastic on the top of the coils,this fits intoo the cover so they line up correctly and holds them in place,also on the larger coil there's a spacer on the post,if you don't see it look inside the old coil,poke out the spacer and slide it onto the post and then install the coil.
Oct 23, 2013 | GE Dryers
Code p0302 did plugs and wires still comes back
Move the coil to plug 3 and plug 3 coil to plug 2. That will prove faulty coil pack.
Nov 18, 2017 | 2002 Hyundai Elantra GLS
Whirlpool Cabrio Gas Dryer. Will heat for a short time then stops. usually gets stuck around the seven minute mark and wont move from there. Cothes are soaked. I checked all internal parts with multimeter...
If what happens is the flame comes on when it first starts,after the flame goes off you see the igniter glows then goes off but no flame,the coils that open the gas valve are working while thier cool but once thedryer gets running,when warm to hot the gas valve coils wont open the gas valve so when the igniter comes on and no flame the coils have failed to open gas valve and need to be replaced, all manufactures use the same coil supplied by one parts supplier, and them not opening the valve when warm is a very common occurence regardless of what brand gas dryer it is.
The part number for the coils is 279834 they could be picked up from your local appliance parts store for under $20 or online at;
repairclinic.com
searspartsdirect.com
assuredparts.com
apdepot.com
appliancepartspros.com
Gene
Aug 11, 2011 | Whirlpool WGD6200S Gas Dryer
When i got the bike it wasnt running .it had no coils ,no plugs .iv bought new ones and need to know what lead goes were from waht coil .
The coil for the #1/4 spark plugs is mounted on the left side of the bike, and has the solid orange (ground) wire and the red-with-white-tracer-stripe (hot) wire input leading to it.
The coil for the #2/3 spark plugs is mounted on the right side of the bike, and has the solid grey (ground) wire and the red-with-white-tracer-stripe (hot) wire input leading to it.
Mar 23, 2011 | Yamaha XJ 900 F Motorcycles
When started, the dryer works normally. Then the
Good day,
This is a common problem. The gas valve has 2 black coils mounted to the top. One has partially shorted.
You need to replace the coils as a kit.
Remove both wire plugs, remove the 2 screws holding the coils in place, and lift off.
The clip I've included does not apply to repairing the coil kit, but does show you how to access the area. It is a Whirlpool product.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Thank you for using FixYa
Jan 19, 2010 | Kenmore Dryers
2000's F-150 5.4 L shakes during acceleration
Visit your local Auto-Zone or similar auto parts outlet, they should scan your system for you for free and tell you what the "check engine" code(s) indicate. I am suspecting it will report a "misfire" condition. That could be a result of a bad injector, spark plug or coil/wire problem. Sometimes the code(s) is/are specific as to which of those things is the problem.
Jul 28, 2009 | 2000 Ford F150 Flareside SuperCab
My Kenmore Elite Dryer 110.72066102 starts, the igniter come on, flame comes on runs for a short period of time, flame goes out, and igniter comes on again but no flame.
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim. And please don't forget to give me your rating for my help.
Jul 07, 2009 | Kenmore Dryers
Dryers Logo
37 people viewed this question
Top Dryers Experts
Marvin
Marvin
