Question about Car Audio & Video
Audi alpine cd changer
The Alpine CD changer in the trunk of my 1996 Audi A4 was working fine until I one day mistakenly tried to insert the magazine upside down. As soon as I met resistance I pulled it back out and inserted it correctly, but now I get a CD00 ERR reading on my Blaupunkt CD player when I try to go to CD mode. It seems as though this must be just a reset problem, as nothing broke. I've tried disconnecting the power line to the changer and the fuse to the CD player, but this fails to reset it and I continue to get the error reading. Can you tell me how to reset it?
  • Anonymous May 15, 2008
    i have the same problem
  1. if you are handy at fixing things unhook the cd player, unbolt it, carefully remove screws holding the unit and remove the actual cd player, now remove many tiny screws to open the unit out of the case, look for various wheels and try to turn them, do not force any of them. usually the wheel allowing the motion to move to various tracks on cd gets locked. if you can move it, most likely you solved your problem. put evrything back in the same order.
  2. Good luck.
Posted on Sep 10, 2008
My alpine CD player is showing a cd 3 error jam
Are all CDs in the magazine? If not, there may be one stuck in the changer
Sep 23, 2012 | Alpine Car Audio & Video
Error 01 the magazine does not eject
A lot of times there is a gear inside of the changer that gets jammed. If you can, remove the top cover of the changer. On the changer mechanism (it will be on the right side of the changer) there will be a large gear (probably black) with an arm attached to it. Use a flat blade screw driver or something like that and turn the gear counterclockwise until the tray is back in magazine. You should then be able to put the changer back together and it will probably work fine.
Nov 02, 2011 | Alpine CHM-S620 6-Disc CD Changer
I want to buy a Alpine CHM-S630 is it compatible with the audio sistem from a Audi A4 year 2000
the answer is yes. Its compatible with an audio system from Audi year 2000.
Good luck.
Jul 31, 2010 | Alpine CHM-S630 6-Disc CD Changer
Cd changer magazine does not eject
good day, you may want to do it manually if its jammed, you may find a pinhole on it and u can use a paperclip, insert it in the hole and it will open. hopefully it wont jam again. hope this helps, have a nice day
Feb 09, 2010 | Alpine CHM-S630 6-Disc CD Changer
Looking for magazine for alpine chm 5620
The Alpine CHA- and CHM- changers all use the same magazine. You can search eBay or google shopping for "Alpine CHM Magazine" and you should see a variety of sellers, with prices from 25ish for used ones up to 40ish for new ones.
Feb 05, 2010 | Alpine Car Audio & Video
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
Have alpine chm s620 ,error message say no disc magazine is loade
have you tried a different magazine.  Could this one be warped?
Apr 03, 2009 | Alpine CHM-S620 6-Disc CD Changer
My local Lincoln Dealership wanted to dismount the actual Clarion CD changer (I thought, and unfortunately reported to you, that the CD changer manufacturer was the same as the radio/cassettee unit that is installed in my dash, Alpine) from my 99 Town Car and ship the unit out for repair for a minimum of $130.00. Instead, I went to a local Radio Shack franchise who installs/repairs car electronic audio/video systems and they: dismounted the unit from the trunk; took the dismounted unit to their workbench; removed all the housing, etc. and finally were able to manually extract the fully populated 6 CD magazine stuck within the CD changer. Additional efforts (including inserting my spare magazine into the CD changer while it was on the tech's work bench) to determine exactly why the magazine would not eject while the unit was connected via the cabling to the car's power, etc. were not productive. So I now have a totally unassembled non-functioning CD changer on my hands. The "CDEJ Error" on the LED area in the dash when the eject buttoon on the CD changer is pushed.still persists. The technician said that it would be a waste of his time and my money to re-assemble the parts of the CD changer. He believes that the motor on the unit has been burned up.
So I am now checking with all the local auto parts salvage yards (we used to call them junk yards) to see if anyone has a usable Clarion CD changer for a 1999 Lincoln Town Car available that would be plug compatible with my existing Alpine factory installed Premium CD/Cassette audio system and the former factory installed trunk mounted Clarion CD changer. The Radio Shack franchise technician has already checked with the Clarion factory people and they iindicated that they no longer have my Town Car installed CD changer model available, new, used, refurbished or otherwise.
For what it's worth, here are the part numbers and other potentially important data that appear on the "cage"/sheet metal/housing that surrounds the working parts of the CD changer itself:
Assembly Part Number: F8VF-18C849-AE
Part Number (presumably the "cage"?): F8VF-18C830-AE
Date Code: 0998
Serial Number: 0201832
Mounting Orientation: Vertical
System Revision Level: 9.2
So it looks like I may have a potentially very expensive replacement of my whole audio system on my hands. I have been quite happy with my somewhat "obsolete" audio system and I have a very large collection of CDs which I migrate between my Sony 300 CD CDP-CX350 Mega Changer installed in my entertainment center, my car Cd changer and my Sony CD/Cassette player boom box in my master bedroom.
It was suggested to me that if I have to replace the radio/cd/cassette unit installed in the dash of my Town Car that I should consider a replacement model that offers a port to receive Ipod programming as a source of music.
So things have gotten somewhat complicated since the first instance of the Cd magazine not ejecting from the Clarion CD change mounted in the trunk of my car.
Maybe someone out there on your knowledge base knows where I can acquire a used Clarion model CD changer compatible with my car's setup at a reasonable price.
Nov 24, 2008 | Alpine CHM-S620 6-Disc CD Changer
Car Audio & Video Logo
302 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
