Question about Orion 2500D Car Audio Amplifier
*amp to sub wiring help...
I got a orion 2500d and a 12'' dd and want to run it from that.
why is there 2 + and 2 - for the power? also 2 - and 2 + for the speaker when its a monoblock?
how do u wire a single sub to it? suggestions?
12'' is a dual 2
    Sergeant:
  • 300 Answers
The 2500D has 2 "+" and 2 "-" power connections to help split the current between two smaller wires vs. one giant, hard to route wire. According the manual, for optimal performance, both "+" and "-" power connections should be utilized. They also recommend using 4AWG wire for these connections.
The 2 "+" and "-" speakers connections are only there to simplify the wiring of multiple speakers into the amp. Both "+" get tied together inside the amp, as do both "-" connections. In this case, with the dual 2 ohm voice coils on your 12" sub, you would wire one voice coil to one +/- set on the amp and the other voice coil to the other +/- set.
Posted on Mar 05, 2008
    Problem Solver:
  • 8 Answers
WHERE IS THE POWER FUSE ON A ORION 2500D
If the fuse is not on the outside of the amp, usually near the live input. it will be inside the amps casing. you may have to look around carefully as maybe under parts or hidden. if not on ouside of amp, 100% its inside the amp
Feb 27, 2011 | Orion 2500D Car Audio Amplifier
I have an Orion 2150sx and an Orion xtr2150 will either of these run on a one ohm load ? If not what is the best way to run either of these amps to get the most power out of them. I have two Orion xtr...
EITHER OF THEM WILL WORK AT ONE OHM WITH NO PROBLEM, MAKE SURE YOU MAINTAIN VOLTAGE INTEGRITY, USING EITHER 2 OR 0 GUAGE POWER AND GROUND AND A POWER RATED ALTERNATOR AND BATTERY.
Nov 03, 2010 | Orion 2500D Car Audio Amplifier
For da orion 2500d, what would be the difference between 10'', 12'', & 15'' orion hcaa subs besides a matter of price and inches? I have two of the orion 2500d amps and am ready for the subs. I would...
I honestly would go with 2 12 inch dual 2 ohm subs and wire them one per amp. That will give you a 1 ohm load to each amp and will give the HCCA's 2500 rms per sub... It will be stupid loud... 10s hit tighter than 12's usually and 12's tighter than 15's but u will get more air movement out of a 15 than the 12's and 10s... but... 2 10's require say a 4 cubic foot box to perform well... 2 12's require a 5 cubic foot box to perform well and 2 15's require about 7 to 10 cubic foot to perform to their fullest... no matter what if you put a sub in a box that's too small it will not perform or sound like what you want it to... go 2 12's and like a 5.50 cubic foot box or a 6 cubic foot box and you will love it...
Dec 01, 2009 | Orion HCCA-D5000 Car Audio Amplifier
How many svc subs at 4ohm does it take to get this amp to 1ohm stable and can you reccomend a good sub combo for this amp whether it be dvc or svc
It depends if your sub is 4ohm svc, or 2ohm svc. 4ohm would take 4 subs wired in parallel, 2ohm would take 2 subs wired in parallel. But for a amp that big, subs that'll handle it are definitely gonna be dvc. I'd recommend 2 Orion 4ohm dvc hcca's. They come in either 15in or 12in. the 15s are louder if you have the space for them. As far as wiring goes, wire the voice coils on the subs in parallel to 2ohm per sub, then wire the 2 subs in parallel to 1ohm. Goodluck and congrats on the equipment, Orion is about as good as you can go for subs and amps. just be ready to lay down some dynamat cuz this system'll bloww your vehicle apart! good luck...
Oct 08, 2009 | Orion 2500D Car Audio Amplifier
I have 2 jl-w6 subs n a orion hcca 250 amp how do i run wirering
Hello brianmitchel,
From what I am able to determine, the Orion HCCA250 is a bridgeable 2-channel amp that is stable to 1ohm when bridged and outputs 800 watts RMS into that load.
The JL W6's in both 10" and 12" versions are dual voice coil with 4ohm coils so they can be wired to present either an 8ohm load (series) or a 2ohm load (parallel). They can handle 600 watts RMS.
With this combination, the best configuration would be to wire the sub voice coils in parallel for a 2ohm load and then parallel both subs to the amp bridged terminals for a final impedance of 1ohm. The subs will each be getting 400 watts.
In any event, I would not recommend running subs in series. There is some evidence for distortion being caused by something termed "back EMF".
Hope this helps.
Aug 03, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Feb 27, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Im not get any loud base, even with the gain at full turn
an orion 2500d requiers 2 4 gauge power and ground wires to work properly.
Aug 22, 2007 | Orion 2500D Car Audio Amplifier
Wiring for 2500d orion amp
ground wires(heavy black)is connected when the red light lit.so no need check the red hot wire which is connected to battery terminal maybe loose.or theres no power comming in.thre are 2 hotwire in that amp one is red which is the main and yellow or sometimes orange which is the remote on. now if you sure that the power terminals is properly connected,ur speakers is working and input wires are good and still no sound. your amp is probably gone...do not try experimenting the wires or hook up two amp by any means..u might destroy all ur amp. hope this help u....
May 11, 2007 | Orion 2500D Car Audio Amplifier
My Orion 2500D amplifier turns off then back on at high volume
you need a # 4 gauge wire. check the subs conection no less than 1 ohm. check ground. and if the cap is good. 13.8 volts are for max ouput ......this is 1 ohm of charge at 13.8 volts they give 2500 watts butt only at 13.8 volts whit this relation. i¨n think you need other alternator. good look.
Feb 05, 2007 | Orion 2500D Car Audio Amplifier
Amp makes subs pop
It sounds like your amp chip has gone bad, here is some thing you can try turn on your unit then start tapping on top of with your finger not hard see if the any of the pops matches your finger taps some times when the chip starts to go out it well act like that.
Nov 04, 2006 | Orion 2500D Car Audio Amplifier
Orion 2500D Car Audio Amplifier Logo
237 people viewed this question
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Mark Skinner
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
