Question about Mitsubishi VS-6043 60" Rear Projection Television
Tv help When I turn the tv it keeps blinking in& out and it won't come on
    Sergeant:
    Champion:
  • 281 Answers
The power lighting is dead.
Posted on Mar 03, 2008
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
JVC LT46J300 Blue Light blinking TV won't come on all of a sudden
These blinks to standby light are fault indications, called blinking codes. From the number of blinks occur at one time switch on, you can get an idea about the faulty circuit stage inside it. Count it. Visit this site. It has details about blinking codes to many brand televisions.http://electronicshelponline.blogspot.com/Pull up older posts there, either by its left side bar, or see it in Timslide option
Jun 24, 2013 | JVC LT Televison & Video
The standby light keeps flashing on and off. The TV won't go on. Any help would be appreciated.
The inserted video have no details about the brand name of the TV. Anyway, understand that these blinking are fault indications. Count the number of blinks occur at one time switch on. If you wish to get more details about the blinking codes, check this link. Form the number of blinks, you can get an idea about which section circuit is faulty, and will make troubleshooting more narrower. Check the above linked site patiently. Blinking codes and troubleshooting procedure to many brand TVs are given.
Mar 09, 2013 | Televison & Video
Power button won't turn tv on. light keeps blinking on and off
Main board to your TV is faulty. Check the chroma and video processing section. In most cases, it will be due to an IC fault.
Jul 23, 2012 | Curtis-Mathis Televison & Video
Sony Trinitron KV-27FV310 won't stay on, standby button flashes around 10 times, help please?
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Jun 18, 2012 | Sony FD Trinitron WEGA KV-27FV310 27" TV
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
The infrared receiver light just keeps blinking red and TV won't power on. Tried unplugging for a little while but didn't help.
kindly count the blinking led to diagnose where the fault came from..
also try the initial check....open the back cover and inspect the power supply board for any bulged capacitors inside..
Jan 18, 2012 | Polaroid 4241-TLXB 42 in. LCD Television
I have a Sharp Aquos TV that started to turn on but shut off automatically. Tried it several times and it kept doing the same thing. Now the tv won't even turn on and the power light on the tv keeps...
It sounds like a bad capacitor. If you are handy, you can search on Youtube on how to replace them on your model. If not, have a proffesional look at it. The individual parts should be inexpensive. The service charge varies. Good luck!
Aug 30, 2011 | Sharp Televison & Video
I have a Panasonic model TH-42PZ80U Plasma Tv the red light keeps blinking 10 times and it won't turn on?help
hi,
In your tv there some problem with power supply. you have to check the followin voltages. Sub 5v SOS ,Main 3.3v SOS A-Board,DTV 9v SOS , Tuner Power SOS. If any one of the voltage fails it will shows 10 blinks.
ok
Jul 18, 2011 | Panasonic Viera TH-42PX80U Plasma TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Televison & Video Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
