LG projecter TV
The screen is showing a green or yellow circle in the middle lower section of the screen the rest of the picture is perfect a repair man told me that it was the LCD drive engine but after reading differant forams I just dont know anymore can any of you please help
  • fbmullet Mar 04, 2008
    The TV is a LG RT44SZ80LB
    Thank you for your fast reply I'm pretty sure the voltage is correct and the repair man all he did was tun the TV on look at the screen say that it was the drive engine and had me a bill but after reading some other comments online they talk a lot about the polarizing filter has this got any merit.
    Genius:
  • 1,226 Answers
Hello!
That color cause by a not correct voltage drops, this may cause by parts that is not functioning properly, Please try to regulate the power supply of your tv. But maybe the repairman is correct in his speculation.
melnavz
Posted on Mar 04, 2008
  • Emelio Navaja
    Emelio Navaja Mar 04, 2008
    He tell that the drive engine, Did he recommend for replacement the drive engine? Drive engine maybe its a general term that all assembly of the TV to project pictures on screen. This is a short expalanation of polarizing filter:
    Light travels from the back of the TV toward the front from a large bright light.
    1. A horizontal polarizing filter in front of the light blocks out all light waves except those vibrating horizontally.
    2. Only light waves vibrating horizontally can get through.
    3. The liquid crystal for this pixel is switched off, so light travels straight through it unchanged.
    4. Light waves emerge from the liquid crystal still vibrating horizontally.
    5. A vertical polarizing filter in front of the liquid crystal blocks out all light waves except those vibrating vertically. The horizontally vibrating light that travelled through the liquid crystal cannot get through the vertical filter.
    6. No light reaches the screen at this point. In other words, this pixel is dark.
    1. The bright light at the back of the screen shines as before.
    2. The horizontal polarizing filter in front of the light blocks out all light waves except those vibrating horizontally.
    3. Only light waves vibrating horizontally can get through.
    4. A transistor switches on the liquid crystal for this pixel. The crystal rotates light waves by 90° as they travel through it.
    5. Light waves that entered the liquid crystal vibrating horizontally emerge from it vibrating vertically.
    6. The vertical polarizing filter in front of the liquid crystal blocks out all light waves except those vibrating vertically. The vertically vibrating light that emerged from the liquid crystal can now get through the vertical filter.
    7. The pixel is lit up. A red, blue, or green filter gives the pixel its color.
    In that case, you TV got small error but it is negligible,
    However maybe be resolved by certified LG Technician, or at LG service center. But do not worry about that, that is tolerable.
    melnavz
Color red,green and blue is making a circle on the screen
Hello, please replace the PTC resistor. It is positioned at the primary side of mains converter. Best regards, Arpi
Aug 23, 2007 | Zenith B27A11Z 27" TV
Yellow circle in the middle of the screen. It has
Not sure if this will help...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba 42H83 42" Rear Projection...
Sony 43 inch rear projection tv, I have lined up the convergence but still seeing red and green around edge of the tv on the images, seems fine in the middle of the screen though.
Always start at the vary center of the screen with Green. Position Red over Green, then Blue over what now will look yellow. If all is perfect except the outside, you will need to adjust "Mid-Size" until the middle is just as far off as the outside lines. Then adjust the main "Size" adustments to match. Go very slow or you can make a mess of it.
Mar 06, 2009 | Sony KP-51HW40 51" Rear Projection...
Yellow and blue on screen
I am slightly confused about the model of the television, because a 46F500 is a rear projection set that doesn't have a lamp. It has 3 picture tubes and I have a few of them in my shop right now that have the problem you reported. What we do to this set when it develops a convergence issue is to check each resistor around the convergence chips for discoloration, and replace any of them that have changed in value, along with the STK392-150 ic's. If you don't have an ohm meter and solder/desolder equiptment, you can usually get a shop to do this repair for 150.00 to 350.00. Parts will be 50.00 and labor , the rest, depending on the quality of repair shop that you use. Good luck, Russmann.
Nov 16, 2008 | Hitachi 46F500 46" Rear Projection...
Colors off. blue and yellow not lined up
try to set the convergance if you cant you can adjust the color tubes from inside the tv but have to be very careful to do this. There is actually only 3 colors in the tv red, blue green so I would say your blue and green need lined up
Sep 30, 2008 | Televison & Video
No Red color on Phillips tv model 60PP9202/17F
one of the picture tubes inside the went bad you 'll need a tech
Aug 13, 2008 | Philips 60PP9202 60" Rear Projection...
HELP! Can you help me Slinte?
Can you post the board location number of thr resistor that is circled in yellow such as R8006 and I will post the rating of that resistor as thats what the problem is usually one or two of the resistors will burn when the ICs go out.
May 10, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Sony KP-57HW40 57 in. Green Circles
well just remember the in the electrical industry its not 100 percent all of the time. you might just want to buy a new one.
Apr 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
