Question about Mitsubishi VS-50605 50" Rear Projection Television
Projection television i just got a 62" mitsubishi projection and it works good except the picture has static on it like a bad cable connection,but it's hooked straight to a dvd player. I tried to take a look at it but i wouldn't know where to start. If any one has any ideas please help
  • 116 Answers
Most likely a high voltage leak. Is the static on menus as well? If there is a leak of high voltage, you should be able to hear it as well. Some of these sets leaked coolant from the picture tubes. A close visual inspection of all printed circuit boards should reveal this.
Posted on Mar 05, 2008
Mitsubishi VS-55609: No video/audio - just static
You are on the right track. If you cannot see a picture on either antanna A or B then the tuner is suspect.
You may try hooking the cable straight into the TV if you are using a cable box, if not then you should be getting a picture when your other video devices are turned off.
The fact that you get a picture on video tells me that the AV circuits are fine.
Thanks
asnowman
Jul 25, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Static in the picture
Light static in picture is usually caused by a bad cable connector.
- things to check/questions:
Does it happen with all sources DVD, VCR ?
Are you on Antenna, Cable, Cable box or Satellite?
Does it happen on all Channels?
Do you use the cable input or audio video inputs?
The problem is usually not serious and is usually external to the TV
Oct 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Has an overall green tint on a 62 inch hdtv
If you are using Coponet Cables from a Cable box or Satillite, make sure the blue connection is good and not backed off it's connector at both pieces of equipment. If it has a good connection at both pieces of eqipment I would
suspect the Optical block being faulty.
Let's pray for the loose cable connection.
Hope this helps,
Skyassoc
Jun 19, 2009 | Mitsubishi WD-62531 Projection Television
Audio is working, no picture
you have either a defcetive signal pwb, FMT pwb or light engine. Does the menus appear clear when you press menu?
May 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi 62" DLP Auto Sensing Gone???
yes - however, I recommend that u get it repaired professioinally so u don't get electrocuted
Feb 26, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Picture but no sound
OK, I don't have a 360, but are you sure the audio cable is connected, in the correct jack, and pushed all the way in? Sometimes it looks like the jacks are all the way in, but they are not. Thus, no audio. You could also try using Component 2 if that is an option on the TV. Maybe Component 1 ports are bad. Hope this helps.
Jan 24, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Hello, I Have a Mitsubishi WD-62725 (62") DLP rear projection TV. Ever since I changed the lamp the last time, the picture is jumpy when I turn it on, with all kinds of imperfections. It slowly goes away,...
This is a problem with bad capacitors on your FMT board inside the tv.. Not exactly a "do it yourself" type of repair unless you are very good with soldering and have electrical repair knowledge.
Jan 17, 2009 | Toshiba 50H72 50" Rear Projection...
Wavy diagonal lines only with component cables, not hdmi
You have a bad format board which is no longer available. the DM chassis can be sent in for repair by an authorized Mitsubishi servicer Call mit at 1 800 332-2119 they might help with cost of repair have receipt and purchase date available.
Jan 12, 2009 | Mitsubishi WD-62725 62" Rear Projection...
No picture
Somehow you have your inputs not on... but don't get ahead of ourselves. Check the cables in back... The video cable in... make sure it is fully connected from cable box / satellite box to input, then make sure the input is on where it is plugged in.
Feb 18, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
