Question about Toshiba Satellite M35X-S109 Notebook
Internal Speakers Without warning, my speakers quit working. I have done the troubleshooting, but still no sound!
  • 3iron Mar 12, 2008
    yes, i have the same problem. after installing a new hard drive and loading XP PRO, i no longer have any speaker sound from the speakers or a headset. I suspect i do not have the correct driver installed for the sound card. Does anyone know what driver is supposed to be used and where can i find it.
    Device manager tells me all audio devices are working as well as the CD drive, but no sound of any type can be heard.
    Thanks for the help
    PDG
My computer is not working why do you want me to post solution?
Posted on Oct 11, 2008
    Sergeant:
    Champion:
  • 281 Answers
Did you dropped water or a kind of liquids ?
Posted on Mar 03, 2008
No Sound, Windows 7 laptop
Is the speaker plug it the right connector and inserted all the way? Are you using the headphones jack? Do headphones work in the jack? Is the sounds section in Control Panel function properly ? TroubleShooting? What? Drivers? Power on speakers? Check connections/wiring?
Nov 24, 2012 | Computers & Internet
Dv6000 no sound from internal speakers
If the stereo jack works, then there is no problem with the sound card or its drivers. Your speakers have played their last, most likely some internal wiring broken as speakers themselves rarely just quit.
Jan 12, 2012 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Distored sound
distorted sound from external speakers or internal speakers?
isolate please. remove external speakers if you have one. just troubleshoot on the internal speakers alone.
uninstall the audio drivers. install the latest one. if fails. download then flashed the latest bios.
run diagnostics extended test to check the internal speakers. if also fails then replace the internal speakers.
Dec 05, 2009 | Computers & Internet
I have a 37 inch sansui flat screen television model # HDLCD 3700. The sound just quit working; the picture is fine? Is thier any trouble shooting that can be done?
Please unplug TV from AC wall socket for couple of minutes, replug back in and turn it On and check sound.
If problem still exist, check internal speakers are enable / ON in Menu.
If speakers are ON and yet no sound, then need to check sound at Audio Out jacks at back of TV, hook audio cable (white-red rca pins) in audio out jack in TV and receiver/ amplifier to get TV sound in receiver/ amplifier speakers. This is a test/ check and you can use it to get TV sound through receiver speakers.
And if still no sound in audio out jacks in TV then TV needs main board replacement. Check with local TV repair shop for that.
Thanks.
Nov 15, 2009 | Televison & Video
No Sound From Internal Speakers
go to prefrence pane select sound then output bar and arrange the volume labeling , can you hear some sound.
Jul 02, 2009 | Apple MacBook Air
External speakers don't work but internal speaker works fine.
Try your speakers on another system to make sure speakers are working.
Make sure volume control on PC is not set on mute.
Make sure onboard sound is enabled in BIOS
Try re-installing the sound card driver.
If all this fails and you have a spare slot on your PC just purchase a new sound card for about $10.00 or so.
May 21, 2009 | HP RT987UAABA - HP Compaq dc5700...
Radio Problem
did you splice a higher wattage subwoofer in the line without a amp and proper wireing if so you can burn the internal amp on the radio thus causing a pair of speakers not to work
Feb 14, 2009 | 2007 Dodge Ram Truck
No sound from my HP G6000 Notebook PCs internal speakers, (mute is not on) although sound is going through a set of external speakers. Checks have been carried out on all sound settings which state...
well since the external speakers are working then the problem is with the internal speakers and thats a hardware issue so they need to be replaced if you have warranty then take it in to be fixed nothing else can be done
Sep 24, 2008 | Computers & Internet
Speakers do not work but rearly they will?
What type computer? Vista or XP? I take it you have X-530 speakers?
Go to control panel,and check device manager to see if you have any problems. If not, click on Hardware and Sound, then on Sound, and you will see the "Playback" tab. Highlight "speakers" by clicking on it, then click on "configure" to see how your laptop speakers are configured. If you have a laptop, your internal laptop speakers should be turned off. Configure them for your external speakers and test the sound there. If you need to use your laptop speakers (say you take your laptop somewhere without your external speakers) you will need to reconfigure your sound to the laptop speakers. Let me know if you have further problems--you may need to update your sound driver.
Have you done maintenance on your computer, such as getting rid of unnecessary files and defragmenting the hard drive? If not, go to "applications" in your program files to do so.
Jun 20, 2008 | Logitech X-530 Computer Speakers
Toshiba Satellite M35X-S109 Notebook Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
