Question about Sony VAIO GRZ660 Notebook
Cannot turn on my laptop
I cannot turn my laptop on at all because the DC IN outlet, or a part connected to it, does not carry a charge to the computer or the battery. I need an alternative solution to changing the whole motherboard such as a docking station that allows me to charge my laptop's battery and power up my computer by using the outlet at the bottom of the computer.But Would a docking station solve my problem? and where can i can i find it? i searched on the internet and could not find it.
i would appreciate your help,
Ab....
  • anamakam Mar 03, 2008
    The computer used to only turn on after i wiggle the cable and then put something on top of it to stabilize it in a position that kept the battery's indicator light on. thats how i knew i had the right position or enough of a charge for me to turn the computer on. That does not work at all now and no matter how much i wiggle it only one or two speratic flashes of light from the battery idicator would come on. And even after having the computer on for a while the battery indicator would turn off and the computer would loose power and shut itself down.
    thanks,
    Ab....
    Genius:
  • 3,587 Answers
Can you explain why the usual DC input is not working?
Posted on Mar 03, 2008
MSI S6000 power jack is very loose and does not make a connection to charge the battery or run off the electricity.
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 25, 2011 | MSI S6000017US Laptop
My Dell Latitude D505 will only charge the battery through the docking station. I have used mulitple chargers and none will charge batt outside of the docking station. Any suggestions??
Aug 25, 2011 | Dell Latitude C640 Notebook
I have an acer aspire one aand even though I plug it up it says (plugged in, not charging.) How do I make it charge?
Welcome to FixYa!
Jul 17, 2011 | Acer Aspire One PC Notebook
Battery is not charging
Hi, You maybe encountering errors such as plug in not charging or no battery detected. If so, there's a posibility that the problem is with the battery itself or the charger that you are using or worse, the DC port on the laptop. Here some steps for you to be able isolate the exact problem and which part is need to be replaced.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard or the Base Cover of the laptop itself.
Feb 18, 2011 | Gateway MD7818u Notebook
Advent k 200 laptop does not charge battery
Hope this will help...Your response is very much appreciated...
Feb 15, 2011 | Computers & Internet
Not charging
hi,
there are many possible reason why its not charging, for you to be able to isolate which is defective, follow these steps, removed the battery and connect the laptop directly to the power outlet then try to turn it on, if it turn on, that means that the charger is working fine and the battery is defective already, if it did not turn on, that means that there is a possiblility that the problem is with the charger or the DC port on the laptop...So if its the battery, you need to replaced it, do the same if it is the charger, but if its the DC port, you will need to replaced the Motherboard.
Hope this will help...Please rate...
Jan 19, 2011 | Acer Aspire 6920 Notebook PC
Yesterday I bought an STP-120 SIMA power inverter
you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
Jan 27, 2010 | APC DC to AC power inverter ( external ) -...
My laptop stop charging.
Batteries get old and wear out. Be use AC outlet is working. Check for power light on AC/DC charger box between laptop and AC.
It is common for Laptop charging/power connectors to get worn and/or loose(intermittent). Try to get charging light on PC by wiggling power connection to PC.
If not, if you have a VoltOhmMeter(VOM). check for 5V on barrel power connector on the charger side, that plugs into PC, Outside conductor is GND and Inner connector is (+5V). VOMs are cheap at RadioShack or AutoParts stores and are a handy tool to have around the house. Book shows you how to measure. PC is 120V AC on Wall side of PC Power Supply from Wall Outlet, and 5V DC on PC side of Charger.
Charger may be defective. Cheap on Ebay.
Feb 23, 2009 | Acer Aspire 3680 Laptop
I still cannot turn on my laptop...
maybe..maybe not..docking stations are not always the answer, if it's further down the line on the motherboard.
Mar 09, 2008 | Sony VAIO GRZ660 Notebook
Alternative to the DC in outlet
This wiggling has been both the temporary solution and cause of future issues, essentially what you are wiggling was once soldered onto the motherboard and now one contact broke off and you had to wiggle it to get it to touch on where it should, now both contacts are probably broken and will be impossible to line up onthe board again.
Either way it needs looking at by a technician to ascertain what needs repairing, and if it is motherboard issue then you'l need a specialist repair centre that can repair motherboard faults. Dont be scared the good ones run a no fix no fee policy, and usual price for a fix is £35 for DC Jack repair and £55 for motherboard repair. If you need pointing to a reputable company let me know.
And yes, there are docking stations that have their own DC Jack and that will be another temporary solution, look on ebay or ask a local technician to source you one.
Background: I run MCSLondon.co.uk and have 20yrs experience in IT.
Mar 06, 2008 | Sony VAIO GRZ660 Notebook
Sony VAIO GRZ660 Notebook Logo
52 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
