Question about Asrock K7VM4 Motherboard
ASRock K7VM4 my pc stopped working for some reason, everytime i switch it on nothing comes up on the screen. i decided to test every component. I bought new memory DDR 256MB PC2700, but still when i switch on, the fan on the mob start spinning but there is nothing coming up on the screen. No even a single bip just a blank screen. last time this happened was a year ago i decided to buy a new Asrock K7VM4 Motherboard and the problem was solved. Therefore i'm not sure whether my motherboard is finished its time or what. it is sad that if i will have to keep on buying motherboard everytime this happens. Help please
  • jp_juanpa84 Sep 04, 2008
    modem
  • Anonymous Apr 09, 2009
    i turned on the computer and had no display thinking it might have been my screen i borrowed a mates screen to no avail. decided to change motherboard and no problem there after. think k7vm4 might have fault in manufacture but the what doesn't brake down after a while...
    Problem Solver:
  • 7 Answers
In addition to advice from Solution 1 the MB I had was same as yours. Turned on computer and all I had was a spinning CPU fan and power supply fan, nothing else. Turned out to be the ram slots not making contact. Try swapping ram to unused bank or cleaning contacts on plugs with Micro-scrub and or electronic cleaner (Iso Pro). I used very fine waterpaper, then a vacume and then ISO Pro spray to clean cause I can never find the Microscrub when I need it. Make sure all is dry before reinstalling and power up.
Posted on Sep 09, 2008
Your list of suspects:
1. Processor is cold dead.
2. Power Supply has got a problem. Just powering a fan is not a guarantee that it is powering everything normaly. Try a different one as you test agai.
3. I suspect your MoBo is good, but try a different video card also with your new DDR.
4. Do you hear the HDD cranking or whining when you turn on the PC? Keep ear near HDD and listen. It it whine-starts, it's a fair sign.
5. Try a different monitor while you test these.
Let us know what you find in clear detail.
Posted on Mar 03, 2008
Is the asrock k7vm2 motherboard easily replace by the k7vm4 asrock. my k7vm2 is dead and replacements are not easy to come by. I'm just looking for a new mother board to hook up to my hard drive and not...
You may be able to just swap out the motherboard for a K7VM4 motherboard but some of the specs are different like the chipset and graphics etc.
K7VM4 specs as follows >>>>
  1. Socket A(462) for AMD processor
  2. VIA® KM400 Chipset
  • ASRock U-COP
  • Hybrid Booster - a safe overclocking feature
  • FSB 333/266/200, DDR 333/266/200
  • Integrated UniChrome 3D Graphic.
  • 1 slot for AGP 8X/4X 1.5V
  • ASROCK I/O - default 4 ready-to-use USB2.0 ports on rear panel, default Game/MIDI port.
  • ATA 133 supported
  • On board default 10/100 LAN and 5.1-Ch Audio.
K7VM2 specs as follows >>>>>>>
  2. VIA® KM266 Chipset
  • ASRock U-COP
  • DDR 266/200
  • Integrated ProSavarage8 3DGraphic.
  • 1 slot for AGP 4X/2X universal.
  • Supports both DDR and SDRAM memory modules to provide you best flexibility and save your cost.
  • ATA 133 supported
  • On board default 10/100LAN and Audio.
As you can see the graphics and chipsets are different although the processor sockets are the same.
This could cause problems if you are going to plug the hard drive to another board but saying that is is possibe and has been done before.
This is a chance you take when you swap out a board for a different motherboard although i suspect that the transition should go smoothly.
A fairly old motherboard like K7VM4 or K7VM2 will not cost that much these days. You will find both motherboards for sale on eBay.
Regards.
May 27, 2010 | Asrock K7VM2 Motherboard
Hi, When I turn on the power switch nothing happens.
remove the RAM & CPU & reinstall them and try
if not, you might be looking at a dead motherboard
Mar 27, 2010 | Asrock K7VM4 Motherboard
What is U16 on K7VM4 Rev. 1.03 MoBo?
Changing the CD54/74HCT365. M is rated 25 on quality and MT is 100 and M96 is 2500 and probably cost a little more too. But, what bothers me is that something else could be wrong and driving it to burn up? Asrock k7vm4 Rev. 1.03 16 Ghz and K7VM4 is the BIOS
Sep 16, 2009 | Asrock K7VM4 Motherboard
No sound drivers
Go to the ASROCK website and download the driver there
May 05, 2009 | Computers & Internet
When i burn cd or copy paste something or during playing games a blue screen comes saying physical dump of memory?plzzzzzzzz anyone give me solution.
There seems to be a memory problem on your PC, you might need to replace your memory modules, please check if you have low latency memory since that type of memory needs a voltage adjustment made in the motherboard startup Bios to work correctly.
But first you can try opening windows CONTROL PANEL / SYSTEM look at the ADVANCED tab and click on the SETTINGS button at the STARTUP and RECOVERY section, a new window will pop up and select (NONE) at the WRITE DEBUGGING section in that window. And see if it gets better, if not try deselecting the 3 options above this write debugging section. All this is safe to do, if it works it works, if it doesn't nothing happens.
Jan 03, 2009 | Asrock K7VM4 Motherboard
Startup Issues with K7VM4
Yep ... memtest would be a good place to start. never seen faulty RAM corrupt the OS before though!
Jul 17, 2008 | Asrock K7VM4 Motherboard
Nothing on screen, fan running on processor, hard drive trying to load OS
did you try to replace your memory? do you hear a sound (click) once only,when you open your PC? if none, pls..try to replace your memory.but if still nothing happen,then thats the time to replace your Main-board.
Mar 27, 2008 | Asrock K7VM4 Motherboard
Graphics proble wihle working in 3D modeling software
in BIOS recheck your graphics MB capability. In windows, recheck everything in performance, let's be real that's an old board. try updating your graphics driver.
Sep 07, 2007 | Asrock K7VM4 Motherboard
Graphics problem
Hi, could you please give us more information. Are you using onboard graphics or a graphics card and if a card what type and capacity? Regards mistyman
Asrock K7VM4 Motherboard Logo
211 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
