Question about Intel Desktop Board D845GEBV2L (MBIND845GEBV2) Motherboard
I believe its my board....can you help please!!
I recently bought a this board from a friend and have since loaded an O.S. on it twice and changed out the HD to try and fix this problem. My keyboard and mouse stop working...or the machine freezes either way I cant do anything on my computer. The mouse light is still on and and the caps light or the Num Lock light, whatever was on from when I was using it is still lit, but I cant get any response out of either of them. I then have to restart the computer, and from there it works fine. I have only had this happen one time while I was using the PC, every other time it happens when I'm sleeping and cant use it when I wake up. This happens every time it is powered on. Please help in anyway....thanks!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Have you tried cleaning up your machine? try your sys tools, free up space, see if it needs to be defragmented, then try a freeware registry cleaner like Abexo. Sometimes so much garbage accumulates in the registry that the machine freezes and does other wierd things.
Posted on Mar 03, 2008
  • Richard Roberts Mar 07, 2008
    also, check your config sys on control panel--any yellow check will point to to the solutions
How do I change region code for HP Deskjet 2515 ink cartridges?
Try to find an internal batt at mini board remove turn off and turn off twice
Jul 24, 2014 | HP Deskjet Ink Advantage 2515 All-in-One
How can I get rid of the coloured lines?
you should do the following tasks:
Press the left side of the TV with your hand, if the colors got disappeared, fortunately the flat cable inside the TV causes the problem. But
If the problem still insists, the panel board inside the TV got corrupted and you must change it with a new one.
May 03, 2014 | Computers & Internet
Acer mbs8709003
please you att any lcd on load other person and change our system resolution 800 by 600 and att our monitor solve the problem
May 07, 2012 | Acer Aspire M1100-U1402A Refurbished AMD...
I have an F&P smart drive model GW709AU and have had to replace the Main Board and inlet valves twice. How long should the board and valves last as it costs around $500.00 each repair. It was a...
Hi just read your posting.From the information on your posting you have changed your Motor Controller twice and both valves twice in 4 years,Is this correct?And both times the cost of the repair has been in the range of $500,Is this correct?In my experience as a service tech the grey control modules and water valves should last a bit longer than 4 years.It also depends on how much you use the machine and how big the loads are.By the way did you ring Fisher and Paykel for both repairs or an independent service company?Please reply with additional information on the questions and I am sure I can help you further if needed.
Aug 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washer make noise to loud when It spin mode. how to fix it
what does the noise sound like is it a high pitch squeeling noise or grinding. need more info
Apr 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Overfilling then leaking through the door and drawer
Almost definitely the pump filter is blocked.
Its happened twice on mine. Tilt machine forward to expose filter, undo clips on flexible hoses and remove filter. clean it out and replace. problem solved. about an hours job.
Dec 22, 2009 | Hotpoint WMA64 Front Load Washer
Slugish hard steering, already changed pump twice,
I think I would look at the steering box and the pitman and idle arms. Your steering box itself may be gunked up with sludge causing the poor steering of the truck. I do not believe it to be a sensor. I would find out if there was a way to flush the steering box or if you have to just replace it. I hope this helps.
Nov 04, 2009 | 2004 Ford F150
Sony erisson k700i wont send or recieve
I don't really get the question right but, what i think your complain is, is that the green/dial key is not working properly.If that is the case, i want to believe that it is a problem from the board that is, the phone pane.All you need to do is to get a phone engineer around you to fix it up for you.
The engineer will either help you change the panel for another good one.
In a case were there is no compatible panel found, i suggest you get a new phone.
Jun 28, 2008 | Sony Ericsson K750i Cellular Phone
Intel® Desktop Board D845GEBV2.....having problems...can you help?
It could be either your power yuo are supplying is too low or may be your computer is getting too hot.... If it is too hot better if you get a another cooling fan and fix it to the system fan sloty on the mother board, if it is the power supply better if you get a power supply of about 450w or more........
Mar 03, 2008 | Computers & Internet
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
