Question about Sony KP-61S65 61" Rear Projection Television
Do you have instructions for replacing the outer picture screen?
I need to replace the screen on my 61" Sony rear projection television , model: KP-61S65. I was blowing out a candle & splashed wax on the picture screen :( I still can't believe that I did it! I was having a hard time in removing the wax because of the fragility of the screen, so I tried a solvent which then also had removed the coating on the screen. Now, I've got a large white streak with the remaining wax. The screen is ruined..
Sony says that I can purchase the part for around $200.00. I'm surfing the web to try & find a refurbished or used screen---My main idea is to atleast find the instructions for replacing the screen myself..... Do you or anyone have a solution for me...please??
thankyou :)
  • Anonymous Mar 12, 2008
    I experienced the same problem as muziclady. Who do I contact to purchase the screen.
  • Screen6 Mar 12, 2008
    I experienced the same problem as muziclady, wasted wax on the screen of my Sony KP-61S65 61 in Rear Projection Television and used a solvent to remove the wax and ruin the screen. Does anyone have a contact number so I can call and purchase the screen? Also, I need the instructions for replacing the outer picture screen.
I'm muziclady & I had three choices to choose for replacing the screen. The first was to purchase a new screen through Sony's parts dept. site
Secondly I found this this site that makes rear pro. screen antiglare screens: http://www.glarestopper.com/measure2.php
Also from this site, it has instructions for the removal of the screen to measure & re-install. [which is easy]. The actual screen size for the 61" is 58x30 inches, & it's referred as being a 61" Projection TV Screen Only [Lenticular Fresnel] .
My final choice was to Google for a screen replacement. I was fortunate to find a used one from an RCA television..It's the exact same size, etc.
Hope this helps... :)
Posted on Jul 29, 2008
My sony rear projection tv lost the color yellow
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Sep 08, 2009 | Sony KP-61HS10 61" Rear Projection...
I would like to buy a rca 61 P61960
Hi jkclay841 i live new york and have a RCA REAR PROJECTION TV 61" MODEL # P61960 CHASSIS NUMBER PTK195Y06T
IT POWERS ON BUT IT'S OUT OF ALIGNMENT ON ALL COLORS AND MISSING THE CLOTH THAT COVERS THE SPEAKERS HAVE THE REMOTE SCREEN IS IN GREAT CONDITION ALSO HAVE SOME NEW CRT COOLANT RUBER SEALS ,AND THREE NEW LENCES THAT I WAS GOIN TO REPLACE BUT CHANGED MY MIND PLUS NO TIME.
HERE IS MY NUMBER 347- 847 -3348 IM JOSE
Apr 03, 2009 | RCA P61960 61" Rear Projection Television
Screen broke on my Hitachi 61SDX01B, need replacement
Here's a link to order the original Hitachi screen assembly for this model (61SDX01B) from a major parts distributor:
Hitachi 61SDX01B Replacement Part Screen Assembly
Mar 19, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Replacement lenticular screen
Try here, the seem to be able to find replacement parts, including lenticular screens for these rear projections TVs: http://www.tvscreenfinder.com/services
Aug 06, 2008 | RCA P61927 61" Rear Projection Television
Sony 61" rear projection tv
is not hd ready,will need to send model and serial number later
Feb 22, 2008 | RCA P60921 60" Rear Projection Television
Sony KP-51HW40 51 Screen Protector
this tv has three parts to screen , the most outer part is called CONTRAST screen part # 408195411 for the model you gave.This is available @ sony.com (parts&access) Please make sure this what you need and model is correct..Good luck
Nov 29, 2007 | Sony KP-51HW40 51" Rear Projection...
Screen replacement
try contacting www.tvscreenprotectors.com for discontinued screen replacements
Nov 25, 2007 | Toshiba TZ50V51 50" Rear Projection...
Screen replacement
I replaced the screen on my 62 inch projection TV for about $50 and the the picture quality is good! Have a sheet of plexiglass cut to the EXACT size needed. BEFORE installation it MUST be frosted on both sides by either a fine particle sandblaster or by sanding it VERTICALLY on BOTH sides with a power sander and a fine grade paper.
If this is only an OUTER protective screen and the image is projected on the inner screen then DO NOT frost the replacement screen, just install it.
Nov 21, 2007 | RCA R52WM24 52" HDTV Projection Television
Sony screen replacement
go to sonytv.com parts see if you can get one cheaper there.i dont know how old the tv is but dealing direct with sony should bring the cost down somewhat.or you may waant to advertise in the local paper and see if someone out there has one theyd sell cheap.
Jul 22, 2007 | Sony KP-61V45 61" Rear Projection...
Rear projection picture problem on Sony 61" big screen tv
Sony had a problem with flickering, please confirm make and model number.
otherwise it sounds like a loose connection or bad convergance amp ic
Nov 13, 2006 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61S65 61" Rear Projection Television Logo
151 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
