Question about AOC CT720G 17" CRT Monitor
AOC 17" Flat Monitor (silver)
Kindly help me because my AOC monitor is just 1 yr old and it keeps automatically adjusting its view. I couldn't stop or exit it and all of a sudden i am hearing "clicking" sound at the monitor and swoosh!!! it changes the view and most times it is kinda distorted now. i don't know what to do. I have tried all the means possible to adjust it myself using the buttons at the monitor's lower front side but it kept automatically changing still. Help me pls...
Thanks a lot
secretwish4us@yahoo.com
  • mumud Mar 08, 2008
    Help me because my AOC monitor keeps
    Thanks a lot
  • soulforgex Dec 08, 2008
    Hi, My AOC crt flat screen 17" monitor's OSD keeps coming on and off plus sometimes the menu would keep switching by itself often times reducing the brightness to 0 then after a couple of mnutes sometimes longer it would return to normal.
Hello all.I had 2 AOC monitors with this kind of problem also and figured out the problem with this kind of monitor. All you have to do is to unscrew the monitor and get the control control switch buttons on its circuit board. There are four switch button that control the monitor with four pins each that attaches to the circuit board of AOC, another option is to replace the switch button with a brand new  control switch button which can be bought to your local electronic shop. Now i had no problem with my AOC monitor because i literally removed those switch control buttons from its circuit board.
Posted on Oct 18, 2008
  • Terautete Tareti Feb 17, 2014
    what rma stand for, pls clarify?
    Guru:
  • 859 Answers
It could simply be that you have a loose connection at the back of the monitor with the cable that comes off the PC. Power down the system and unplug the monitor, lay it flat on cardboard and use a flashlight to find the slots for the screwdriver and make them snug. If that doesn't help remove the cable from the monitor and inspect for a bent pin at both ends if need be. If you have a bent pin do not try to straighten it yourself it requires a special touch and tool, get a tech to help at that point. If this doesn't solve your problem you'll need to call the manufacturer and request an RMA or exchange for a refurbished model.
Good Luck.
Posted on May 10, 2008
AOC CT720G (Black, Silver) 17" CRT Monitor driver
The monitor probably doesn't require any special driver. There are drivers for your motherboard video chip, or if you have a graphics card. If you need to make adjustments to the monitor, the manual is here... http://www.manualslib.com/manual/8152/Aoc-Ct700g.html
Jul 10, 2014 | AOC CT720G (Black, Silver) 17" CRT Monitor
I have an AOC 22" lcd monitor, about 1 1/2 yr old. lower part of monitor is blinking non stop. can it be fixed?
You may have lamp failure due to poor soldering works at the end of the lamps or bad inverter ciruits for the lower lamps. You may have to open it up and inspect the inside to see if you can see any bad caps (bulging top/seal), burnt or over heated parts, poor solder joints on the PCB, etc. See common monitors failure pictures for guide: http://s807.photobucket.com/home/budm/allalbums
Mar 23, 2010 | AOC LM729 17" LCD Monitor
LEFT SIDE SPEAKER NOT WORKING
solution is that monitors with speakers are get damaged very fast.That speakers are low quality and usually not working after a week or month max
Jan 23, 2009 | AOC International 17".264 1280X1024 TFT...
Pincushion and h size problem on aoc 17" 771s
one of the buttons on your monitor is partially shorted. trust me, ive encountered this problem many times.
Jan 03, 2009 | AOC CT720G 17" CRT Monitor
Power blink
Horizontal output transistor is shorted or flyback problem
Oct 17, 2008 | AOC CT720G 17" CRT Monitor
AOC 17" Flat CRT Monitor
Could be problem of key switches!
Try replacing or check for leakage,high resistance across switches using ohmmeter.
Samir
Jul 26, 2008 | AOC CT720G 17" CRT Monitor
Aoc 17 inch silver black monitor problem
main regulator capacitor for the hot side of the power supply may need replacement, usually value is 220uf to 400uf 400 volts..
Apr 27, 2008 | AOC CT720G 17" CRT Monitor
Contrast window keeps on popping in the monitor
Hi, it might be that a sensor in the monitor is sensing change in ambient light and therefore reacts by auto adjusting the contrast. when you push auto, it will do just that and auto react. Why not try manual and set it to your desired setting and let it run that way. But then again, of course it is possible that something is really wrong with the monitor and you would need a qualified service personnel to diagnose/repair it. Hope this be of some help and pls post again how things turn up. Kind regards.
May 18, 2007 | AOC LM520 (Gray, Silver) 15 in. Flat Panel...
AOC CT720G 17" CRT Monitor Logo
259 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
