Sewing Machines Logo
Posted on Feb 27, 2010
Model # 385,11206300 Having troube getting the
Model # 385,11206300 Having trouble getting the bobbin to wind. The bobbin will not spin.
zeumercat
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Mar 05, 2010
zeumercat
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
3725
Points
17
Go to sewusa.com they have threading diagrams showing how to use the bobbin winder.
Want to know why I'm having trouble loading the bobbin, machine sews fine
Trouble winding the bobbin, inserting into bobbin case, or other?
What's your experience with the machine? What make and model?
Could be wrong bobbin as they all look similar but minor size difference leads to big problems.
Please comment here if you'd like my further assistance.
1helpful
I have a Model 830 Bernina. The winder spindle will not turn with bobbin on it. It spins fine when bobbin is off but when holding with a finger it stops.
As you have probably deduced, something is defective with the bobbin winder mechanism. Other than taking it for service, there's probably not much that can be done.
For ~$30, a standalone bobbin winder (Sidewinder) can be purchased several places (JoAnn's, Amazon, etc) that is a very handy accessory. It winds bobbins quickly, saves wear and tear on the machine, and can be used without having to remove the thread from the sewing machine.
1helpful
The bobbin presser on my Juki 2000 Qi sewing machine is loose, it spins around and will not let me wind a bobbin. What can I do to fix this?
Be sure you are following the instructions completely. However, it sounds like there could have been a problem with the bobbin winding unit since you purchased it. You can probably take it for service--may be covered under warranty if it was just recently purchased.
However, there is also a standalone bobbin winder (Sidewinder) avlb from JoAnn's, Amazon, etc. for $30. They are usually battery and AC compatible. You can wind multiple bobbins quickly without having to unthread your machine and it saves wear n tear on your machine. Verify that your bobbins will work on the bobbin winder--some bobbins (mostly Singer) will not.
My Memorycraft 10000 is having difficulty spinning bobbins. When I load it up to spin, then start the process, the needle goes up and down, and the machine beeps and stops.
Hm, difficult to say. Perhaps the needle stop function for bobbin winding is not functioning properly. Perhaps taking it for service would be a good idea.
The other thing you can do is look for a stand-alone bobbin winder. They cost around $30-35 at the fabric stores (ie JoAnn's) or can be found online. Just verify first that it will take the bobbins for your machine. I have one and it's great because it saves wear n tear on my machine, plus I don't have to unthread my machine to wind the bobbin.
Amazon com Simplicity SideWinder Portable Bobbin Winder
3answers
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
2answers
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
3helpful
2answers
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
1helpful
2answers
Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
The winding sound is the rubber O-ring against the spinning pulley (back of hand wheel) - do not let this continue, it will wear out the O-ring.
I had the same problem and I found the shaft bushing of the winder dry and needed lubed. Use oil or spray lithium grease and it should work fine. Spin the bobbin shaft by hand (not the hand wheel) to get it freed up after oiling.
You can oil from the top and should take off the side case to clean the excess oil from the O-ring. The shaft bushing is a tight fit and any dry oil will get sticky and prevent winding.
4answers
Singer futura CE-200 Can not wind the bobbin thread
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
