Question about Mitsubishi VS-60601 60" Rear Projection Television
Pioneer wall mount
Help. my expensive mount wont line up with my wall studs
  • 59 Answers
There are only two solutions to your problem. The first is to use another location. The second one is to take out the section of drywall and put horizontal braces between wall studs where you want to mount the tv. Sorry there isn't a simple solution.
Posted on May 30, 2008
How to Wall Mount a Plasma TV?
For mounting your TV on a stud wall follow
the next few steps.
1. Locate the wall studs in the wall you wish
to hang the TV on.
2. When you find the center of a stud, mark it
with pencil on the wall.
3. Double check that the mount will be level using a level
4. Use big screws.
Oct 19, 2016 | Televison & Video
Can i mount a 50inch phillips tv on the wall model number 50pfp533/37
Yes...My 50inch plasma is mounted on the wall; has been for four years. You must be sure to screw the bolts for the wall mount which will suppport the TV are in the middle of the studs. you can get a cheap stud finder at home depot from under $10.00. It's usually only four bolts to screw into the studs and you're set.
Jul 28, 2012 | Philips 50PFP5332D 50 in. Plasma...
What is the remote learning code for my 32" TV
Mounting an LCD (Liquid Crystal Display) TV on the wall may seem a bit overwhelming at first; but it's not that difficult. With a few simple tools, a proper mounting kit and a helper, the job will be a breeze. With a little bit of patience and an hour or two, your LCD TV will look great. Follow these steps to learn how to mount an LCD TV on the wall.
Things You'll Need:
LCD TV
Mounting kit
Tools
Step 1
Find the best spot on the wall to mount the LCD screen. Think about how much room you may want on that wall, especially if you plan on mounting speakers, too. You could hang a poster or picture relative to the size of the television on the wall to see if you like the placement.
Step 2
Pick a mounting kit. You can purchase mounting kits online (see Resources below) along with many other sites. Look to make sure the kit and TV are VESA compatible so that you have standard measurements and quick, easy attachment during the mounting process.
Step 3
You may already have tools needed to mount the TV. You'll need a set of screwdrivers, a socket set, a saw capable of cutting into drywall, a drill and a measuring tape. Having a stud finder with a built-in level is also great to pinpoint the exact location of the stud. The stud finder will be useful if you'll be running wires through the wall.
Step 4
Get the location for the TV picked out. Check near the bottom of the wall to see if the area you plan on using to run the wires is free of obstructions. Using the stud finder for this will make it easy.
Step 5
Find the studs. You should use at least one stud when mounting the LCD screen to make sure that the mounting bolts are driven into something solid that will support the weight of the TV and the mounting bracket. Using two studs is ideal for mounting larger TV's, those with screens larger than 37 inches. Use a pencil to mark the drill holes for the anchors and stud location.
Step 6
Secure the mounting rails to the back of the LCD screen. Double check them for proper fit. Make sure that they're hidden behind the body of the television for a finished look.
Step 7
Cut the hole for the wires to come through by using a drywall saw. The easiest way is to pull them out at the electrical box. This avoids having to go into the basement, closet or otherwise. You can purchase a wall box at your local home improvement store to place in the exit hole of the wires.
Step 8
Drill the holes for the bolt anchors in the locations that you measured and marked previously. Place the bolt anchors into the holes and tap them in with a hammer.
Step 9
Secure the wall mount to the wall. You'll need a socket wrench to ensure that the mounting bolts get snugged down tightly to the anchors. Use a level to make sure you've done an even job.
Step 10
Grab a friend or family member to help you lift the LCD screen onto the mount. Make sure it's locked down tightly and the screen is set to go.
Hope this helps and Good luck
Sep 25, 2011 | Televison & Video
Need instructions
Flat Panel TV WallMounting Instructions
Currenttrends Flat Panel LCD and Plasma HDTV's are making TV's thinner, lighter andmore powerful. Superior high definition viewing, affordable pricing with addedspace and energy savings are only just a few practical reasons for purchasing anew HDTV. With newer thinner designs, LCD and Plasma HDTV's are ideal for wallmounting. Wall mounting your television frees up space and adds a new elementof aesthetic appeal to your home theater. Positioning Before getting into any hardware mounting,find the best possible position to mount your television. Because wall mountingan HDTV is more of a permanent solution, careful planning is needed whenintegrating the television into your home design.
Furniture placement, overall themes, viewing angles, and the best audiopositioning are all factors that will help determine the placement of the LCDor Plasma TV.
Once you have decided the general positioning of the wall mount installation,cut out a piece of cardboard or wrapping paper in proportion the of theflat panel television. Next, approximate the placement by taping the piece ofcardboard or wrapping paper to the wall where the TV will be placed and mark itwith a pencil.
Preparing the TV Removethe stand from the television and lay the TV on its face. Locate the fourmounting holes on the back of the television and remove the bolts. Next, removethe mounting arms or mounting plate from the wall mount packaging.
To attach mounting arms, line up the arms vertically and parallel to each otherusing the mounting holes on the back of the television. Make sure that they arein perfect alignment and bolt the arms using the bolts and washer supplied withthe wall mount.
If you are using a mounting plate, simply line up the holes with the mountingholes on the television. Secure the mounting plate with the bolts and washersincluded with your wall mount.
Preparing the Wall Locatethe studs closest to the desired position using a stud finder and mark themwith a pencil. Remove the wall mount from the package. Line up the wall mountup to the studs within the center of the marked position you determinedearlier. If it is not perfectly centered, wall mounts can be adjustedhorizontally at a later time.
Using a level, line up the wall mount and mark the positioning of where hebolts will go. Drill holes into the stud about 1" deep, drill bit depends on the of bolts supplied with the wall mount. Bolt the wall mountto the wall with bolts and washers, but don't tighten down the boltscompletely. Adjust the position of the wall mount left or right to center it toyour desired position. When you are done, tighten the bolts the rest of theway. Mounting the Television Attachingthe television to the wall mount takes two people. Simply lift the televisionand hook it to the wall mount. At this point you can further adjust thepositioning horizontally to center it perfectly. Once the desired position isacquired, tighten down the screws that attach the mounting arms or plate to thewall mount.
mike_alozie.jpgWallMounted LCD
Apr 21, 2011 | Televison & Video
How to mount a conia CL3201HDR on the wall, no screws in box and not sure what thread size to purchase.
You need to purchase the wall mount separately. They range from a simple "on the wall" mount to swivels and extending mounts, and can be very expensive for the fancy features.
First, make sure your set is wall mountable. In the center of the rear of the set there will be a square arrangement of bolt holes. I do not know of any newer sets without them, but it does not cost anything to take a look and make sure.
Next, you need to decide on a mount. Personally, I did not want to spend allot, so I found a very inexpensive, yet good quality, "straight" mount at Sears for around $25.00. It does not extend or swivel, but all I wanted was to get it on the wall. Different screws and bolts were supplied with it and I was able to match up what worked for the back of my set.
Now, THE MOST IMPORTANT PART!!!!!
You ABSOLUTELY MUST find where your wall studs are! This is CRITICAL! DO NOT use any kind of expanding bolt to mount your set or it will eventually come loose and FALL!
I had an inexpensive "stud finder" (around $10-15) to show me where the wall studs are... Sears sells them too....You want to bolt your TV wall mount to the studs using 1/4" stud or lag bolts (they look like oversized wood screws) for maximum strength, if your mount will accept bolts that thick. Also use flat washers on the bolts. If your TV mount has its mounting bolt holes too wide apart for bolting to a standard 2" wide stud, mount a 6X6" piece of 1/2 plywood through your wall to the stud, using at least 4 #10 deck screws...it may be overkill, but it will be secure... my personal saying is, "If I can't hang from it, neither can my TV!" This is critical if you want to use a fancy swiveling mount that extends out since it will add stress to where you bolt it to the wall.
My mount was in two pieces.... a section that bolted to my wall, after I mounted a piece of plywood as I described above. This piece has a large pin that sticks up, and the part that mounts to my set (with the screws provided by the manufacturer of the mount) has a receiving hole that slides over the pin. When I need to take my set down, I simply lift it straight up.
I hope my long-winded solution did not bore you, and I wish you the best in hanging your set. Please take a minute and rate my solution.
VA
Jan 30, 2011 | Televison & Video
I have an ULPT-X Omni Mount that I will be using with a Samsung 65" LED. How do I mount the ULPT-X to make sure that the exact center of the TV will be in the center of the wall space it will be hung on. ...
What do you mean by centered on the top and bottom? It doesn't need to be centered in the exact part of the wall for the tv. it all depends on what your viewing height is for where you want the tv vertically. Once you figure that out you mount it where you want it for your personal viewing preference.
Thank you,
Lee
Oct 26, 2010 | Televison & Video
How do I mount my Soyo MT-SYTPT3227ABMS on the wall
Things You'll Need:
LCD TV
Mounting kit
Tools
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Aug 03, 2010 | Microsoft MT-SYTPT3227AB 32 in. LCD TV
How do I find the wall support or inner support in my wall? I want to mount a crt tv on my wall, I want to be sure it is completely secure.
there are a few ways. If u mean the studs in the wall just use a stud finder sold at lowes or tap on wall till you here and feel a solid sound. Tap a small nail through if u want to b sure. Also outlet boxes are nailed to studs. So tap on the wall near an outlet and u should find one fast. Then using a tape measure go 16" off that stud in the direction you want to hang the tv mount.most studs are in the wall every 16". hope this helpd
Sep 26, 2009 | Televison & Video
My wall studs are wider than my television mount
Attach finished 1x4s to the two studs. Attach telelvision bracket to the 1x4.
Dec 28, 2008 | Samsung 46 in. LCD HDTV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
