Question about Canon S520 InkJet Photo Printer
Canon S520 Printer
I have tried everything to print. Uninstalled, reinstalled CD for Canon S520.
Still have 7 blinking orange lights and one green. Can't see any paper jam.
Have all new ink cart's. took them out, put back in. Turned printer off and on, etc.
Jim
jmarbe2387@aol.com
  • Helpless Jim Mar 03, 2008
    I tried taking the cartridges out and replace them. Paper is in the right tray.
    Is there another solution?
  • Canon Expert
  • 1,326 Answers
Do the printer heads move out of home potion. Do the move into the middle to replace the cartridges? How about this, do you have paper in the right tray? Need a little more info on problem
Posted on Mar 03, 2008
  • 1,512 Answers
Try powering it down for a couple of hours for a full reset.
  • Graeme Ross
    Graeme Ross Mar 03, 2008
    this can be done by disconnecting from the power completely. I would suggest that you remove and reinsert your new cartridges, and do a deep clean from the pritners menu. Other than that, i could only suggest getting the latest version of the driver and again try to reinstall it.
    regards
    Graeme
  • Graeme Ross
    all things you have done... no Joy from there suggests a problem internally with the printer... and these days, they are not really worth repair. Maybe you can get a new machine that uses the same ink cartridges... worth a try to save that much at least.
    regards
    Graeme
Canon S300 printer. 7 orange blinks, 1 green. I
According to the manual found here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=330&modelid=6609
7 orange lights represents a bad print head, and the printer will need serviced or replacement. Since printers are so cheap lately, I would just go shopping. Hope this helps! Thanks!
Oct 21, 2009 | Canon BJC S300 InkJet Printer
Canon i950 won't print
Starting with printer in off condition holding reume and then power respectively,now press resume twice and and release power button le green light blink until printhead has finished moving
now is the most crucial information that has to be followed
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Thanks And Regards
May 12, 2009 | Canon i950 InkJet Photo Printer
Canon S520 printer won't print
there is a encoder strip in the printer to which the cartridge head carriage reads .if this encoder strip is dusty or loose the carriage cannot read so it bangs from left to right.and due to this printer cannot get set to its position.and the orange error light blinks.that transperant long strip with blacl vertical lines on it has to be checked.
Jan 29, 2009 | Canon S520 InkJet Photo Printer
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
one by one
Jan 25, 2009 | Canon i9900 InkJet Photo Printer
Canon S520 blinks 7 times yellow then once green over and over, won't print
Read the info on the link below:
Solutions for flashing lights Issue: Alarm / Power light flashes orange 7 times consecutively (Print head error)
1. Reseat the print head S520 / S750 2. The Print Head may need replacing - S520 3. The S520 may require repair
spacer.gif http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=231&modelid=6611
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 17, 2008 | Office Equipment & Supplies
Flashing green light prevents printing.
hi!!!!
try to pull out the cardtridge and put it back properly
sometime the cartrigde is place properly on the printer!!!
try to email me ronaldsuboc@gmail.com
Aug 08, 2008 | Canon S520 InkJet Photo Printer
Canon s520
I had the same problem. tried resetting the "waste ink tank" counter and it didn't work. I ended up taking out the printhead (pull up on the Grey lever) when I put it back in the printer worked! Good Luck!
Apr 27, 2008 | Canon S520 InkJet Photo Printer
Canon s520 problem
I solve mine (4 Yellow Flash + 1 Green) by pushing on the white gear, located at the end right inside, where the cartridges are cleaning. This help the movement of the gear, it was stuck or gem. Do this when you just turning on the printer, then you ear the cycle noise, Your fingers will sense the movement of the gear. Tips: Push the cartridges block to the left to let you enough space to put your hand inside.Now it work normally.
Feb 12, 2008 | Canon S520 InkJet Photo Printer
HELP!
hi, the blinking is caused by a fault in the printer, means it needs to be serviced, its usually more expensive for them to fix it than buying a new one, but you can get there number off the canon website.
Happy New Year
John
Dec 28, 2007 | Canon BJC S300 InkJet Printer
My canon s520
The user guide for that product says that 7 flashes means the printhead is defective and that you should contact Canon's customer care. If you've recently replaced the print cartridge(s), try putting the old one(s) back in. If the printhead is truly defective, there may be no choice but to contact Canon or replace the printer.
Aug 21, 2007 | Canon S520 InkJet Photo Printer
Canon S520 InkJet Photo Printer Logo
150 people viewed this question
old marine
old marine
