Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Problem for Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn-air svd48600w
By jims68 on Mar 03, 2008
cannot read control panel at all but light and fan work fine
Same Problem
Mar 10, 2009
-   My display completely gone. Do you know how to fix this? Ed-   edshiue
Mar 10, 2009
-   just replaced my front control panel. with labor it was $385. you don't need to panel if you know which buttons to push. -   Guest
Feb 11, 2009
-   Same deal. Been gradually losing the display. Now it's gone completely. Please let me know if anyone discovers a solution. Thanks!
-   kevello
Dec 02, 2008
-   I have the same problem....I know where the numbers are so I can still bake and clean....but the digetal display gradually dimmed....I read about a fuse but I cannot locate any -   Guest
Apr 10, 2008
-   I've got the exact same problem Clock became dimmer over time, now almost illegible. Everything else works fine. Assuming I need a new clock but not sure where to get one.-   jradin
Best Solution
posted on May 18, 2009
Very Helpful)
srfandtrf
Rank: Apprentice
Rating: 96%, 6 votes
If your display has gone dimmer and dimmer or just gone out it is probably the display board. There are a few capacitors on the back of the board. There is one that is 68 Microfarad 35 Volts. It is common for this one to go bad. I replace it with a 68 Microfarad 50 Volt rated one and that usually solves the problem.
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for Jenn-Air SVE47100 Slide-In
Questions and Unsolved Problems for Jenn-Air SVE47100 Slide-In
Do you recommend Jenn-Air SVE47100 Slide-In Electric Kitchen Range?
Answer
Answer
when i try to turn my oven on it reads "feature not available" whats wrong with my over?
Answer
F I appears on screen along with a beeping noise after oven is turned off
Answer
all digital gauges are blank. Oven light works as does fan, burners.
Answer
Had to clean my oven because of a pie spill. Now a fan continues to blow and the oven won't turn on.... (More)
Answer
Trying to self clean oven F-9 code comes on with a beeping sound. What do I do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Jenn-Air SVE47100 Slide-In...:
Top Kitchen Range Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Kitchen Range Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
